    Duet3/pi DCS is unavailable after wiring 24V
    duet 3 rasberry pi
    8
    166
    11.3k
    • fractalengineerundefined
      fractalengineer @A Former User
      @bearer Thank you; that's an informative thread, unfortunately the Duet is currently running RRF 3.0 already; still no use.
      Here's what the command @chrishamm mentioned returns:
      pi@duet3:~ $ sudo journalctl -u duetcontrolserver -e
      Apr 12 13:32:35 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
      Apr 12 13:32:40 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
      Apr 12 13:32:40 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
      Apr 12 13:32:40 duet3 systemd[1]: Stopped Duet Control Server.
      Apr 12 13:32:40 duet3 systemd[1]: Started Duet Control Server.
      Apr 12 13:32:41 duet3 DuetControlServer[1405]: Duet Control Server v1.2.4.0
      Apr 12 13:32:41 duet3 DuetControlServer[1405]: Written by Christian Hammacher fo
      Apr 12 13:32:41 duet3 DuetControlServer[1405]: Licensed under the terms of the G
      Apr 12 13:32:43 duet3 DuetControlServer[1405]: [info] Settings loaded
      Apr 12 13:32:44 duet3 DuetControlServer[1405]: [info] Environment initialized
      Apr 12 13:32:45 duet3 DuetControlServer[1405]: [error] Duet is not available
      Apr 12 13:32:45 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
      Apr 12 13:32:50 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
      Apr 12 13:32:50 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
      Apr 12 13:32:50 duet3 systemd[1]: Stopped Duet Control Server.
      Apr 12 13:32:50 duet3 systemd[1]: Started Duet Control Server.
      Apr 12 13:32:50 duet3 DuetControlServer[1445]: Duet Control Server v1.2.4.0
      Apr 12 13:32:50 duet3 DuetControlServer[1445]: Written by Christian Hammacher fo
      Apr 12 13:32:50 duet3 DuetControlServer[1445]: Licensed under the terms of the G
      Apr 12 13:32:53 duet3 DuetControlServer[1445]: [info] Settings loaded
      Apr 12 13:32:54 duet3 DuetControlServer[1445]: [info] Environment initialized
      Apr 12 13:32:54 duet3 DuetControlServer[1445]: [error] Duet is not available
      Apr 12 13:32:54 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
      And thank you for your response @Danal ; I already Bossa the board to RRF3.0 but I will try to update DSF to 1.2.5
      Railcore II ZL
        A Former User @Danal
        @Danal said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
        Your photo shows Duet power by VIN (which is good!).
        No it shows the board powered by usb, albeit with VIN connected. And with nothing else connected a single USB power source isn't going to cause a problem and is easier to relay than the alternatives, while keeping the potential for damage to a minimum.
          fractalengineer
          @bearer said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
          apt list 2>/dev/null | grep duet
          Well observed; I forgot to mention but while always plugged in both VIN and USB, I never powered the Duet through both; either plugging USB to the laptop or turning on the PSU, never both.
          Railcore II ZL
            A Former User @fractalengineer
            @fractalengineer said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
            please confirm the board is actuallt running RRF firmware by sending it M122or M115 first over a serial terminal.
            I support that, eliminates the risk of a ground loop, which is why I suggested using the Pi like I did.
              A Former User @A Former User
              ( you could try timeout 1 cat /dev/ttyACM0 & echo -e "\nM122" > /dev/ttyACM0)
              I've only tested that command with ssh on a Pi against a Duet 2, but no reason it shouldn't work with a Duet 3 as well if you don't have a serial terminal installed (most arent very user friendly on the Pi)
              fractalengineerundefined 1 Reply Last reply Reply Quote 0
                @bearer thank you for sticking with me
                Ok so I downloaded and configured YAT to use as a terminal according to this guide: https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                It seems to be connecting to it, but every time I enter one of both M122 or M115, the interface disconnects and reconnects.
                Likewise, your command doesn't seem to be working on mine either
                pi@duet3:~ $ timeout 1 cat /dev/ttyACM0 & echo -e "\nM122" > /dev/ttyACM0
                [1] 4220
                -bash: /dev/ttyACM0: Permission denied
                pi@duet3:~ $ cat: /dev/ttyACM0: No such file or directory
                [1]+  Exit 1                  timeout 1 cat /dev/ttyACM0
                Railcore II ZL
                  which image are you running on the Pi, pretty sure the default has the pi in the dialout group to allow permissions. the other alternative is the file isn't there.
                  sudo solves permisions, and lsusbshows us if the duet is detected by the Pi.
                    @bearer I tried with sudo prefix as well; same result
                    The image is the Duet Pi from the Getting Started guide
                    I also updates all packages according to the thread you mentioned earlier; everything is now running those versions:
                    pi@duet3:~ $ apt list 2>/dev/null | grep duet
                    duetcontrolserver/unstable 1.3.1 armhf [upgradable from: 1.2.4.0]
                    duetruntime/unstable 1.3.1 armhf [upgradable from: 1.2.4.0]
                    duetsd/unstable 1.0.6 all [upgradable from: 1.0.5]
                    duetsoftwareframework/unstable 1.3.1 armhf [upgradable from: 1.2.4.0]
                    duettools/unstable 1.3.1 armhf [upgradable from: 1.2.4.0]
                    duetwebcontrol/unstable 2.1.1 all [upgradable from: 2.0.7-1]
                    duetwebserver/unstable 1.3.1 armhf [upgradable from: 1.2.3.1]
                    The code recommended the unstable releases...
                    Lastly here's the lsusb result:
                    pi@duet3:~ $ lsusb
                    Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp.
                    Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
                    Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
                    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                    I just redownloaded a duetpi image; I'm keen to reflash everything from scratch.
                    However the DIAG LED blinking without the PI connected tells me the issue might come from the Duet board rather than the Rpi?
                    Railcore II ZL
                      it has its challenges, which is why i linked to the previous thread.
                      anyways, Pi isn't detecting the Duet.
                      Don't suppose its any different on your computer in Device Manager?
                        and it should show up as one of these two entries, for either running RRF or in the bootloader.
                        Bus 001 Device 004: ID 1d50:60ee OpenMoko, Inc.
                        Bus 001 Device 008: ID 03eb:6124 Atmel Corp. at91sam SAMBA bootloader
                          @bearer I see; well my windows is showing just fine:
                          I can connect to it via YAT just fine; just any command I send disconnects it
                          Railcore II ZL
                            can you open that device properties and look at the hardware id?
                            (this is why i prefer using the pi:)
                              @bearer sure there it is
                              Railcore II ZL
                                A Former User
                                Looks like the Duet 3 vid and pid. Can you check out which driver it uses and/or update to the one Duet3d provides?
                                fractalengineerundefined 1 Reply Last reply Reply Quote 1
                                  @bearer wow ok we are getting somewhere; thank you for your excellent insights
                                  I updated the drivers with the ones provided on the RRF github, now YAT is working and commands are responding.
                                  A first M115 showed that the board was indeed in 3.01 RC6; Bossa'd back to 3.0, here's what M115 and M122 returns finally
                                  M115
                                  FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-03b3
                                  ok
                                  M122
                                  RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0 running on Duet 3 MB6HC
                                  Board ID: 08DJM-956L2-G43S4-6J9F6-3S86T-KA5LD
                                  Used output buffers: 1 of 32 (1 max)
                                  Static ram: 152720
                                  Dynamic ram: 148504 of which 0 recycled
                                  Exception stack ram used: 280
                                  Never used ram: 91712
                                  Tasks: NETWORK(ready,1984) HEAT(blocked,1456) CanReceiv(suspended,3808) CanSender(suspended,1476) CanClock(blocked,1424) TMC(suspended,252) MAIN(running,4656) IDLE(ready,160)
                                  Owned mutexes:
                                  Last reset 00:00:30 ago, cause: reset button
                                  Last software reset at 2020-04-04 15:59, reason: User, spinning module LinuxInterface, available RAM 79620 bytes (slot 0)
                                  Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                                  Error status: 0
                                  Free file entries: 10
                                  MCU temperature: min 37.5, current 40.9, max 41.0
                                  Supply voltage: min 0.3, current 0.3, max 0.4, under voltage events: 0, over voltage events: 0, power good: no
                                  12V rail voltage: min 0.2, current 0.3, max 0.3, under voltage events: 0
                                  Driver 0: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                  Driver 1: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                  Driver 2: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                  Driver 3: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                  Driver 4: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                  Driver 5: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                  Slowest loop: 0.22ms; fastest: 0.08ms
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                                  Segments left: 0
                                  Stack records: 1 allocated, 1 in use
                                  Movement lock held by null
                                  http is idle in state(s) 0
                                  telnet is idle in state(s) 0
                                  file is idle in state(s) 0
                                  serial is ready with "M122" in state(s) 0
                                  aux is idle in state(s) 0
                                  daemon* is idle in state(s) 0 0, running macro
                                  queue is idle in state(s) 0
                                  lcd is idle in state(s) 0
                                  spi is idle in state(s) 0
                                  Code queue is empty.
                                  === Network ===
                                  Slowest loop: 0.15ms; fastest: 0.01ms
                                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                  HTTP sessions: 0 of 8
                                  - Ethernet -
                                  State: 0
                                  Error counts: 0 0 0 0 0
                                  === CAN ===
                                  Messages sent 0, longest wait 0ms for type 0
                                  === Linux interface ===
                                  State: 0, failed transfers: 0
                                  Last transfer: 30316ms ago
                                  RX/TX seq numbers: 0/1
                                  SPI underruns 0, overruns 0
                                  Number of disconnects: 0
                                  Buffer RX/TX: 0/0-0
                                  ok
                                  Railcore II ZL
                                    A Former User
                                    Curious, did it affect the blinking led?
                                      not at all unfortunately; blinking led still present, still unable to connect to DWC; no progression of the symptoms since the original post
                                      Railcore II ZL
                                        A Former User
                                        But we know the board is mostly working at least.
                                        that means the firmware has to be running RC6 (or there is a link in the thread above on how to specify 1.2.5 and use RC5 due to issues with RC6)
                                        • Danalundefined
                                          Danal @A Former User
                                          Got it! Thanks for the clarification.
                                            fractalengineer
                                            But the M115 just above shows it's running 3.0
                                            I don't know what else to do I think I will nuke the card and redo a fresh install
                                            Railcore II ZL
