    Duet Web Control 2.1.1 released
    Duet Web Control
    19
    51
    3.6k
    • Danalundefined
      Danal
      When trying to load heightmap, getting:
      HeightmapPanel.vue:415 TypeError: Cannot read property 'add' of null
          at o.showHeightmap (HeightmapPanel.vue:313)
          at o.showCSV (HeightmapPanel.vue:258)
          at HeightmapPanel.vue:413
          at c (runtime.js:45)
          at Generator._invoke (runtime.js:274)
          at Generator.forEach.e.<computed> [as next] (runtime.js:97)
          at Dt (asyncToGenerator.js:3)
          at o (asyncToGenerator.js:25)
      (anonymous) @ HeightmapPanel.vue:415
      c @ runtime.js:45
      (anonymous) @ runtime.js:274
      forEach.e.<computed> @ runtime.js:97
      Dt @ asyncToGenerator.js:3
      o @ asyncToGenerator.js:25
      Promise.then (async)
      Dt @ asyncToGenerator.js:13
      (anonymous) @ asyncToGenerator.js:32
      (anonymous) @ asyncToGenerator.js:21
      getHeightmap @ HeightmapPanel.vue:396
      isConnected @ HeightmapPanel.vue:479
      ni.run @ vue.runtime.esm.js:4568
      Zn @ vue.runtime.esm.js:4310
      (anonymous) @ vue.runtime.esm.js:1980
      ct @ vue.runtime.esm.js:1906
      at @ vue.runtime.esm.js:1933
      pt @ vue.runtime.esm.js:1990
      b @ vuex.esm.js:602
      v.registerModule @ vuex.esm.js:498
      addMachine @ index.js:157
      (anonymous) @ vuex.esm.js:744
      (anonymous) @ vuex.esm.js:392
      (anonymous) @ vuex.esm.js:391
      v._withCommit @ vuex.esm.js:526
      v.commit @ vuex.esm.js:390
      commit @ vuex.esm.js:335
      (anonymous) @ index.js:58
      c @ runtime.js:45
      connect @ index.js:43
      (anonymous) @ vuex.esm.js:751
      v.dispatch @ vuex.esm.js:442
      dispatch @ vuex.esm.js:332
      F.forEach.n.<computed> @ vuex.esm.js:964
      mounted @ App.vue:212
      nt @ vue.runtime.esm.js:1854
      Nn @ vue.runtime.esm.js:4219
      insert @ vue.runtime.esm.js:3139
      E @ vue.runtime.esm.js:6346
      (anonymous) @ vue.runtime.esm.js:6565
      On.e._update @ vue.runtime.esm.js:3945
      i @ vue.runtime.esm.js:4066
      ni.get @ vue.runtime.esm.js:4479
      ni @ vue.runtime.esm.js:4468
      In @ vue.runtime.esm.js:4073
      Mi.$mount @ vue.runtime.esm.js:8415
      e._init @ vue.runtime.esm.js:5018
      Mi @ vue.runtime.esm.js:5085
      56d7 @ main.js:20
      n @ bootstrap:19
      0 @ app.f1b8ca4b.js:1
      n @ bootstrap:19
      (anonymous) @ bootstrap:83
      (anonymous) @ app.f1b8ca4b.js:1
      three.module.js:15728 Uncaught TypeError: Cannot read property 'precision' of null
          at a (three.module.js:15728)
          at new bM (three.module.js:15760)
          at se (three.module.js:23461)
          at new kk (three.module.js:23510)
          at o.init (HeightmapPanel.vue:185)
      RepRapFirmware height map file v2 generated at 2020-04-08 00:35, min error -0.099, max error 0.095, mean 0.002, deviation 0.046
      xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
      -225.00,225.10,-225.00,225.10,300.00,75.00,75.00,7,7
            0,  0.055, -0.039, -0.019, -0.006,  0.010,      0
        0.046,  0.095,  0.006,  0.000, -0.011, -0.062,  0.018
        0.086,  0.055,  0.020, -0.010, -0.041, -0.001, -0.045
        0.077,  0.020,  0.054, -0.019, -0.079, -0.051,  0.001
        0.070,  0.056,  0.020, -0.000, -0.055, -0.015, -0.099
       -0.002,  0.070,  0.068,  0.021, -0.020, -0.065, -0.075
            0,  0.002, -0.007, -0.002, -0.024, -0.006,      0
      • c310undefined
        c310
        @chrishamm two more bugs:
        1. Turn Everything OFF does not work (once button is pressed nothing happens)
        2. after pressing emergency stop button system halts and does not return control to DWC
        this is where DWC hangs:
        once i switch to DWC1 in the interface, both function work fine:
        1. heatbed and extruder are set to OFF
        2. after emergency stop button pressed it shows window as below. Once I press YES - system reboots and returns control to web UI
        • GrodanBundefined
          GrodanB
          Why do this annoying messages never time out?
          No matter what I change these messages do not time out...
          I think they are from the M117 but I cannot find how to get rid of them after a time...
          • chrishammundefined
            chrishamm administrators
            @Danal That heightmap loads without problems on my printer. Is there any way to reproduce this problem? What browser are you using?
            @c310 "Turn Everything Off" will be fixed in the next version. What board are you using? DWC reconnects nicely on my setup whenever I do an emergency stop.
            @GrodanB It's because you are using M117 instead of M118 S"msg". Messages sent from M117 are supposed to be sticky.
            Duet software engineer
            c310undefined Phaedruxundefined GrodanBundefined 3 Replies Last reply Reply Quote 0
            • c310undefined
              c310 @chrishamm
              @chrishamm said in Duet Web Control 2.1.1 released:
              Board is duetwifi 1.03, emergency stop in GUI works, issue is with physical "emergency stop" mushroom button.
              That button generates M112. Once DWC1 receives M112 it generates a window asking "Do you want to restart". Once user agrees, it sends M999.
              In fact, if i issue m112 in DWC2.1.1 printer halts and DWC stucks at "please stand by" without ability to enter M999. The only way to recover in that situation is to power cycle the printer....
              So, i kindly ask you to make that window asking for M999 and reenabling the UI
              That should resolve the issue with non-responsive interface
              Many thanks in advance
                Phaedrux Moderator @chrishamm
                Another user was having a similar problem in this thread https://forum.duet3d.com/topic/15436/printer-freezes-at-start-of-print/23
                When using G29 S1 (or M375) to load a heightmap it would hang. When doing a regular G29 and reprobing it would work ok. (duet3+pi)
                • GrodanBundefined
                  GrodanB @chrishamm
                  ahh.. so thats why... did not know M118. The scripts are since I built my BigBox... and they had M117 all over...
                  Nice thanks finally I can get rid of those annoying messages...
                    Phaedrux Moderator @GrodanB
                    @GrodanB M117 has its roots with the older LCD displays that had a single line for message display. They would stay displayed until the next M117 command came to replace it.
                    • Danalundefined
                      Danal
                      Chris, you nailed it! Heightmap works fine on Chrome.
                      Failure was on Brave, with default settings that defend against trackers and such. Turn these off for printer URL and heightmap works fine on Brave as well.
                      • hunterbrightonundefined
                        hunterbrighton
                        I am experiencing a very strange problem when upgrading from DWC 2.07 to 2.1.0 or 2.1.1
                        Immediatly after uploading the new DuetWebControl-SD.zip folder for either 2.1.0 or 2.1.1 all of my defined tools disappear from the screen. I can run macro files to redefine each tool, and use gcode commands like T0 or T1 to select a tool, but I cannot see the temperatures, (both actual and target) or anything else to do with the tools for that matter.
                        I recently upgraded from 3.0 to 3.01RC6 and it was recommend for me to also upload the new DWC version. Below are images of before (using DWC 2.07) and after (DWC 2.1.1). I made no changes to my configuration file between changing DWC versions.
                        If I click {Revert to DWC 1.xxxx} my tools show up again, but I loose all the features of the new DWC
                        • wilrikerundefined
                          wilriker @hunterbrighton
                          @hunterbrighton DWC 2.1.0 and 2.1.1 have problems if tools are not numbered consecutively. This will be fixed with 2.1.2.
                          Until then you could renumber your T3 to T2 and you should see your tools again.
                          Manuel
                          My Tool Collection
