    Duet Web Control 2.1.1 released
    Duet Web Control
    19
    51
    3.6k
    • c310undefined
      c310 @chrishamm
      @chrishamm it was 3.01RC4 with invisible symptoms ... after i upgraded to RC6 it is visible now.
      why thermostatic fans are invisible?
      how i can input into localization / correct some minor mistakes ?
        droftarts administrators @c310
        @c310 said in Duet Web Control 2.1.1 released:
        Because if they're under temperature control, you can't change their speed, so there's no point having a control over them that doesn't work. If send the gcode to make them non-thermostatic, they will appear. Also (not sure exactly if it's true with the current version), fans linked to specific tools usually don't show until that tool is enabled.
        • smoki3undefined
          smoki3 @smoki3
          @smoki3 said in Duet Web Control 2.1.1 released:
          @SIam said in Duet Web Control 2.1.1 released:
          @smoki3
          M122 is working here
          6.4.2020, 20:32:50 	m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC6 running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y
          Used output buffers: 4 of 24 (22 max)
          Static ram: 28052
          Dynamic ram: 94208 of which 24 recycled
          Exception stack ram used: 576
          Never used ram: 8212
          Tasks: NETWORK(ready,116) HEAT(blocked,1244) DUEX(suspended,136) MAIN(running,1608) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 11:14:43 ago, cause: software
          Last software reset at 2020-04-06 09:18, reason: User, spinning module GCodes, available RAM 8532 bytes (slot 3)
          Error status: 0
          Free file entries: 10
          SD card longest block write time: 133.8ms, max retries 0
          MCU temperature: min 21.7, current 39.7, max 41.7
          Supply voltage: min 24.0, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, SG min/max 0/981
          Driver 1: standstill, SG min/max 0/1023
          Driver 2: standstill, SG min/max 0/1023
          Driver 3: standstill, SG min/max 0/1023
          Driver 4: standstill, SG min/max 0/1023
          Driver 5: standstill, SG min/max not available
          Driver 6: standstill, SG min/max not available
          Driver 7: standstill, SG min/max not available
          Driver 9: standstill, SG min/max 0/1023
          Date/time: 2020-04-06 20:32:48
          Slowest loop: 312.35ms; fastest: 0.12ms
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 107, MaxWait: 5922743ms
          === MainDDARing ===
          === AuxDDARing ===
          Heater 0 is on, I-accum = 0.0
          Heater 1 is on, I-accum = 0.7
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 789.12ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(2) FTP(0) Telnet(0)
          HTTP sessions: 2 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address 2c:3a:e8:0b:06:33
          WiFi Vcc 3.44, reset reason Unknown
          WiFi flash size 4194304, free heap 15424
          WiFi IP address 192.168.188.36
          WiFi signal strength -49dBm, reconnections 0, sleep mode modem
          Socket states: 4 0 0 4 0 0 0 0
          === Filament sensors ===
          Extruder 0 sensor: ok
          I just get this without an output. Are you on Duet 2 Wifi?
          @chrishamm can you help here? Looks like for some it is working. I already tried a reset of DWC but it is not working.
          • Danalundefined
            Danal
            When trying to load heightmap, getting:
            HeightmapPanel.vue:415 TypeError: Cannot read property 'add' of null
                at o.showHeightmap (HeightmapPanel.vue:313)
                at o.showCSV (HeightmapPanel.vue:258)
                at HeightmapPanel.vue:413
                at c (runtime.js:45)
                at Generator._invoke (runtime.js:274)
                at Generator.forEach.e.<computed> [as next] (runtime.js:97)
                at Dt (asyncToGenerator.js:3)
                at o (asyncToGenerator.js:25)
            (anonymous) @ HeightmapPanel.vue:415
            c @ runtime.js:45
            (anonymous) @ runtime.js:274
            forEach.e.<computed> @ runtime.js:97
            Dt @ asyncToGenerator.js:3
            o @ asyncToGenerator.js:25
            Promise.then (async)
            Dt @ asyncToGenerator.js:13
            (anonymous) @ asyncToGenerator.js:32
            (anonymous) @ asyncToGenerator.js:21
            getHeightmap @ HeightmapPanel.vue:396
            isConnected @ HeightmapPanel.vue:479
            ni.run @ vue.runtime.esm.js:4568
            Zn @ vue.runtime.esm.js:4310
            (anonymous) @ vue.runtime.esm.js:1980
            ct @ vue.runtime.esm.js:1906
            at @ vue.runtime.esm.js:1933
            pt @ vue.runtime.esm.js:1990
            b @ vuex.esm.js:602
            v.registerModule @ vuex.esm.js:498
            addMachine @ index.js:157
            (anonymous) @ vuex.esm.js:744
            (anonymous) @ vuex.esm.js:392
            (anonymous) @ vuex.esm.js:391
            v._withCommit @ vuex.esm.js:526
            v.commit @ vuex.esm.js:390
            commit @ vuex.esm.js:335
            (anonymous) @ index.js:58
            c @ runtime.js:45
            connect @ index.js:43
            (anonymous) @ vuex.esm.js:751
            v.dispatch @ vuex.esm.js:442
            dispatch @ vuex.esm.js:332
            F.forEach.n.<computed> @ vuex.esm.js:964
            mounted @ App.vue:212
            nt @ vue.runtime.esm.js:1854
            Nn @ vue.runtime.esm.js:4219
            insert @ vue.runtime.esm.js:3139
            E @ vue.runtime.esm.js:6346
            (anonymous) @ vue.runtime.esm.js:6565
            On.e._update @ vue.runtime.esm.js:3945
            i @ vue.runtime.esm.js:4066
            ni.get @ vue.runtime.esm.js:4479
            ni @ vue.runtime.esm.js:4468
            In @ vue.runtime.esm.js:4073
            Mi.$mount @ vue.runtime.esm.js:8415
            e._init @ vue.runtime.esm.js:5018
            Mi @ vue.runtime.esm.js:5085
            56d7 @ main.js:20
            n @ bootstrap:19
            0 @ app.f1b8ca4b.js:1
            n @ bootstrap:19
            (anonymous) @ bootstrap:83
            (anonymous) @ app.f1b8ca4b.js:1
            three.module.js:15728 Uncaught TypeError: Cannot read property 'precision' of null
                at a (three.module.js:15728)
                at new bM (three.module.js:15760)
                at se (three.module.js:23461)
                at new kk (three.module.js:23510)
                at o.init (HeightmapPanel.vue:185)
            RepRapFirmware height map file v2 generated at 2020-04-08 00:35, min error -0.099, max error 0.095, mean 0.002, deviation 0.046
            xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
            -225.00,225.10,-225.00,225.10,300.00,75.00,75.00,7,7
                  0,  0.055, -0.039, -0.019, -0.006,  0.010,      0
              0.046,  0.095,  0.006,  0.000, -0.011, -0.062,  0.018
              0.086,  0.055,  0.020, -0.010, -0.041, -0.001, -0.045
              0.077,  0.020,  0.054, -0.019, -0.079, -0.051,  0.001
              0.070,  0.056,  0.020, -0.000, -0.055, -0.015, -0.099
             -0.002,  0.070,  0.068,  0.021, -0.020, -0.065, -0.075
                  0,  0.002, -0.007, -0.002, -0.024, -0.006,      0
            • c310undefined
              c310
              @chrishamm two more bugs:
              1. Turn Everything OFF does not work (once button is pressed nothing happens)
              2. after pressing emergency stop button system halts and does not return control to DWC
              this is where DWC hangs:
              once i switch to DWC1 in the interface, both function work fine:
              1. heatbed and extruder are set to OFF
              2. after emergency stop button pressed it shows window as below. Once I press YES - system reboots and returns control to web UI
              • GrodanBundefined
                GrodanB
                Why do this annoying messages never time out?
                No matter what I change these messages do not time out...
                I think they are from the M117 but I cannot find how to get rid of them after a time...
                • chrishammundefined
                  chrishamm administrators
                  @Danal That heightmap loads without problems on my printer. Is there any way to reproduce this problem? What browser are you using?
                  @c310 "Turn Everything Off" will be fixed in the next version. What board are you using? DWC reconnects nicely on my setup whenever I do an emergency stop.
                  @GrodanB It's because you are using M117 instead of M118 S"msg". Messages sent from M117 are supposed to be sticky.
                  Duet software engineer
                  c310undefined Phaedruxundefined GrodanBundefined 3 Replies Last reply Reply Quote 0
                  • c310undefined
                    c310 @chrishamm
                    @chrishamm said in Duet Web Control 2.1.1 released:
                    Board is duetwifi 1.03, emergency stop in GUI works, issue is with physical "emergency stop" mushroom button.
                    That button generates M112. Once DWC1 receives M112 it generates a window asking "Do you want to restart". Once user agrees, it sends M999.
                    In fact, if i issue m112 in DWC2.1.1 printer halts and DWC stucks at "please stand by" without ability to enter M999. The only way to recover in that situation is to power cycle the printer....
                    So, i kindly ask you to make that window asking for M999 and reenabling the UI
                    That should resolve the issue with non-responsive interface
                    Many thanks in advance
                      Phaedrux Moderator @chrishamm
                      Another user was having a similar problem in this thread https://forum.duet3d.com/topic/15436/printer-freezes-at-start-of-print/23
                      When using G29 S1 (or M375) to load a heightmap it would hang. When doing a regular G29 and reprobing it would work ok. (duet3+pi)
                      • GrodanBundefined
                        GrodanB @chrishamm
                        ahh.. so thats why... did not know M118. The scripts are since I built my BigBox... and they had M117 all over...
                        Nice thanks finally I can get rid of those annoying messages...
                          Phaedrux Moderator @GrodanB
                          @GrodanB M117 has its roots with the older LCD displays that had a single line for message display. They would stay displayed until the next M117 command came to replace it.
                          • Danalundefined
                            Danal
                            Chris, you nailed it! Heightmap works fine on Chrome.
                            Failure was on Brave, with default settings that defend against trackers and such. Turn these off for printer URL and heightmap works fine on Brave as well.
                            • hunterbrightonundefined
                              hunterbrighton
                              I am experiencing a very strange problem when upgrading from DWC 2.07 to 2.1.0 or 2.1.1
                              Immediatly after uploading the new DuetWebControl-SD.zip folder for either 2.1.0 or 2.1.1 all of my defined tools disappear from the screen. I can run macro files to redefine each tool, and use gcode commands like T0 or T1 to select a tool, but I cannot see the temperatures, (both actual and target) or anything else to do with the tools for that matter.
                              I recently upgraded from 3.0 to 3.01RC6 and it was recommend for me to also upload the new DWC version. Below are images of before (using DWC 2.07) and after (DWC 2.1.1). I made no changes to my configuration file between changing DWC versions.
                              If I click {Revert to DWC 1.xxxx} my tools show up again, but I loose all the features of the new DWC
                              • wilrikerundefined
                                wilriker @hunterbrighton
                                @hunterbrighton DWC 2.1.0 and 2.1.1 have problems if tools are not numbered consecutively. This will be fixed with 2.1.2.
                                Until then you could renumber your T3 to T2 and you should see your tools again.
                                Manuel
                                My Tool Collection
