Solved Difference between M28 and manual upload of Gcode
@lepetitmort said in Difference between M28 and manual upload of Gcode:
Newest firmware used.
Please be specific. What version of firmware and DWC are you using. And what board?
@Phaedrux said in Difference between M28 and manual upload of Gcode:
Duet Web Control 2.0.7
Duet 3 Main Board 6HC
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-03b3 -
Thanks, that's helpful. I'm not sure if this is intended/expected or not. That will be for @dc42
Uploading files using M28 should not remove any command lines. However, AFAIR it does remove comments. Are you certain that your G4 lines are not commented out with a semicolon at the start?
Yes I am sure that nothing is commeted out.
Here is an example:
If i send the following gcode
M106 S1.0 G4 P25 ;M106 S1.0 M106 S0.0 M106 S1.0 M106 S255 M106 S1.0 G00 Z0.000000 G00 X105.324704 Y211.976535 M106 S1.0 G01 Z0.000000 F100.0(Penetrate)
the final file on the duet looks like
G4 P25 ;M106 S1.0 G0 Z0.000000 G0 X105.324704 Y211.976535 G1 Z0.000000 F100.0;Penetrate
I am not understanding what is happening here.
Are you running your Duet 3 in standalone mode or with an attached RPi?
@dc42 Attached RPI on which a python script sends the commands.
I'll ask @chrishamm to take a look at this.
@dc42 Great thanks a lot!
Thanks for reporting this, I've got a fix ready that will be published as part of DSF 1.3.2.
