    3.01 RC6 Extrude button does not come active
    Beta Firmware
    • xnaronundefined
      xnaron
      3.01 RC6 Extrude button does not come active. I have upgraded to 3.0 then to 3.01. I can heat the hotend up and print but the extrude button in duet web control 2.1.0 never becomes active. I tried setting M302 S160 R160; but it doesn't make a difference. Any suggestions?
      • xnaronundefined
        xnaron
        ; Configuration file for testing Duet Ethernet and Wifi
        ; Communication and general
        M111 S0                            		; Debug off
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        M555 P2 ; Set firmware compatibility to look like Marlin
        M550 PXnaronDelta				; Machine name and Netbios name (can be anything you like)
        M551 Preprap                   			; Machine password (used for FTP)
        ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
        M540 P0xBE:0xEF:0xDE:0xAD:0xBE:0xED		; MAC Address
        ;*** Networking - Enable for both WiFi and Ethernet boards.
        M552 S1						; Turn network on
        ;*** Ethernet networking: Adjust the IP address and gateway in the following 2 lines to suit your network
        M552 P192.168.0.14				; (0 = DHCP)
        M554 P192.168.0.255				; Gateway
        M553 P255.255.255.0				; Netmask
        ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
        ;M665 L311.000 R154.000 H423.8 B140.0 X0.000 Y0.000 Z0.000; SHORT ARMS Set delta radius, diagonal rod length, printable radius and homed height
        M665 L348.000 R153.700 H379.590 B150.0 X0.000 Y0.000 Z0.000; LONG ARMS Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
        M208 Z0 S1 ; Set minimum Z
        M574 X2 S1 P"xstop"   ; X min active high endstop switch
        M574 Y2 S1 P"ystop"   ; Y min active high endstop switch
        M574 Z2 S1 P"zstop"   ; Z min active high endstop switch
        M558 P1 X0 Y0 Z0 H5 F120 T9000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
        G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
        M557 R140 S20 ; Define mesh grid
        M569 P3 S0 ; Drive 3 goes forwards
        M350 X64 Y64 Z64 E32 I1 ; Configure microstepping with interpolation
        M92 X640 Y640 Z640 E840 ; Set steps per mm x32 360
        M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
        M203 X9000 Y9000 Z9000 E6000 ; Set maximum speeds (mm/min)
        M201 X2000 Y2000 Z2000 E1500        ; Accelerations (mm/s^2)
        M906 X2000 Y2000 Z2000 E600 ; Set motor currents (mA) Bondtech
        M84 S0 ; Disable motor idle current reduction
        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 R4700 ; configure sensor 0 as thermistor on pin bedtemp
        M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
        M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
        M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                        ; map heated bed to heater 0
        M308 S1 P"e0temp" Y"thermistor" T100000 B4388 C0 R4700  ; configure sensor 1 as thermistor on pin e0temp
        M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
        M143 H1 S300                                   ; set temperature limit for heater 1 to 280C
        M307 H1 B0 S1.00
        M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
        M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
        M563 P0 D0 H1 ; Define tool 0
        ; Custom settings
        G1 S2 X0.1 Y0.1 Z0.1;
        G28;
        • xnaronundefined
          xnaron
            Please upgrade Duet Web Control to 2.1.1 from https://github.com/chrishamm/DuetWebControl/releases/tag/2.1.1. I think that will resolve the problem. Alternatively, you can revert to DWC 2.0.7.
            xnaronundefined 1 Reply Last reply Reply Quote 0
            • xnaronundefined
              xnaron @dc42
              @dc42 2.1.1 worked. Thank you.
                DWC 2.1.2 and RRF 3.01-RC7 are now available too.
