    Firmware update woes. Duet3
    Firmware installation
    1.7k
    • Danalundefined
      Danal
      Oh, and do you have any expansion or tool boards?
      Demiundefined 1 Reply Last reply Reply Quote 0
      • Demiundefined
        Demi
        @Danal said in Firmware update woes. Duet3:
        It also sounds like that firmware is not compatible with the DSF (duet software framework) on the Pi.
        I thought that too, but when I remove the SD card from the pi and put it in the board, it works, but Ethernet is disabled on every startup and I have to send M552 S1 to get it to connect again. I added it to the config.g (M552 S1) but it doesnt enable it, and I still have to connect via Pronter and send it.
        Can you run an M115 via the USB?
        SENDING:M115
        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC7 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-14b3
        Source for bin: https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC7
        • Demiundefined
          Demi @Danal
          @Danal
          No. No expansion boards.
          • chrishammundefined
            chrishamm administrators
            1. A SD card must NOT be present in the Duet 3 when connecting a Raspberry Pi to it
            2. RRF 3.01-RC7 is incompatible to the latest stable DSF release. You have to stick with 3.0 until the next stable version is out
            3. Firmware updates generally do not need to be installed manually. This is done automatically when the system components (packages) of the DuetPi OS are updated
            If you can confirm all of the above, please check the wiring between the Pi and the Duet 3 once more and send the output of M122 from the Duet 3 itself (connect via USB).
            Duet software engineer
            • Demiundefined
              Demi
              https://forum.duet3d.com/topic/15551/duet3-pi-flashing-diag-led-after-wiring-24v-dcs-is-unavailable/80
              This thread seems to be following a similar issue. I have been getting my pi imagine from:
              https://pkg.duet3d.com/DuetPi-lite.zip
              From the Start Here guide.
              • Danalundefined
                Danal
                Chris is the author of much of this, and anything he says (instantly!!) overrides anything I say. I am a technically literate end user who sometimes tries to help.
                As he said, RC7 is going to be incompatible with certain releases (including the latest stable) of DSF.
                Also, as he said, installing firmware with bossa is really a fallback procedure. Once you get to the point where DSF, DWC, and the Firmware are all at releases that talk to each other, you should never have to bossa.
                One of the reasons why I wanted the output of sudo apt list duetcontrolserver -a is it will tell us what DSF release is installed, and which feed your Pi is on.
                • Demiundefined
                  Demi @chrishamm
                  @chrishamm
                  Thanks for the help everyone.
                  "A SD card must NOT be present in the Duet 3 when connecting a Raspberry Pi to it"
                  It is not, Im using the same card for both the board and the pi, and bouncing back and forth.
                  "RRF 3.01-RC7 is incompatible to the latest stable DSF release. You have to stick with 3.0 until the next stable version is out"
                  Okay, if I am understanding correctly, the GPIO control method cant be used at this time with the newest firmware. No biggie for me, the intent is to run the board through USB control from a pi running Repitier as a front panel. I was just doing basic setup with the pi in this config.
                  "Firmware updates generally do not need to be installed manually. This is done automatically when the system components (packages) of the DuetPi OS are updated"
                  How is this accomplished? Do I need to SSH into the pi and update, or do I need to flash a new OS to the SD card for the pi? The only reason I went down this road was I was having issues with deployprobe.g not being called for M401 and related. These Duet3s are being used in a production facility, and Im the guy that got picked to implement them, so I really do appreciate how quickly you all have jumped in to help me. Im at pucker factor 5.5.
                  Danalundefined A Former User? 2 Replies Last reply Reply Quote 0
                  • Danalundefined
                    Danal @Demi
                    @Demi said in Firmware update woes. Duet3:
                    @chrishamm
                    Good.
                    If I understand your statement correctly... no... "the GPIO method" is available at every release, if DSF and the firmware match. Longer answer: Tthe firmware (on the Duet board itself) and the DSF (DuetSoftwareFramework) on the Pi must be at release levels that are compatible with each other. We know that you have RC7 on the firmware. We don't know, at this moment, what DSF you have.
                    Further complicating this answer: There is a "stable" release path on the install servers, and an "unstable". I don't know which one you chose back at the time you built the SD card. If you used the "out of the box" card, you are on "stable".
                    To finish this thought: We MAY need to bossa one more time. After that, everything will keep itself in sync.
                    This may be a unique requirement of your production environment, but... generally everybody in Duet land recommends against this. It un-does most of the advanced function of the Duet (web, onboard files, onboard monitoring), and leaves you with an expensive board that is forced to be dumb.
                    Anyway, not all that relevant to the learning curve here...
                    Correct. ssh into Pi, then sequence is always:
                    sudo apt update
                    sudo apt upgrade
                    (or, if for some reason you don't want the Pi to upgrade itself 'sudo apt upgrade duetsoftwareframework')
                    We will get you going. 🙂
                      A Former User @Demi
                      It does depend on the DuetSoftwareFramework (or probably specifically duetcontrollserver) already working; if you have an incompatible firmware on the Duet apt update will not update the firmware.
                      Specifically apt update will also update the package RepRapFirmware, and as part of its script it will ask the Duet board to run the update just like you would run M997 S1 from a console - but if the board isn't connected or otherwise unable to communicate with the running version of DSF the update will not succeed, and as far as I know it will not retry - but once communication is sorted you can run M997 S1 as it will read the firmware file that was part of the RepRapFirmware update.
                      • Demiundefined
                        Demi
                        Ohhhh. Headslap. Alright standby, working on it now. Yeah I know the front panel deal is weird. Its a long and strange story, but we have some printers that were purchased that already have front panels that underperformed in their shipped state, and a safety requirement that they can be controlled physically. Ill update the pi and report back in 5.
                        • Demiundefined
                          Demi
                          Before:
                          pi@duet3:~ $ sudo apt list duetcontrolserver -a
                          Listing... Done
                          duetcontrolserver/stable,now 1.2.4.0 armhf [installed,automatic]
                          duetcontrolserver/stable 1.2.3.0 armhf
                          duetcontrolserver/stable 1.2.2.1 armhf
                          duetcontrolserver/stable 1.1.0.5 armhf
                          duetcontrolserver/stable 1.0.4.1 armhf
                          duetcontrolserver/stable 1.0.3.1 armhf
                          After
                          sudo apt-get update
                          sudo apt-get upgrade:
                          Listing... Done
                          Its...the same? DCS error persists. Restarting.
                          • Danalundefined
                            Danal
                            Thanks @bearer, very good clarification!
                              A Former User @Demi
                              Its...the same?
                              need to switch to the unstable packge list.
                              edit:
                              #comment out stable list
                              sudo sed -i '/ stable/s/^/#/g' /etc/apt/sources.list.d/duet3d.list
                              #add unstable list
                              echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.list
                              • Danalundefined
                                Danal
                                Yep, or regress the firmware on bossa. I believe forward is better, I'm going to give him instructions for that.
                                • Demiundefined
                                  Demi
                                  You guys are awesome. Im a babe in the woods over here, and thank you Danal for anticipating that I didnt know how to switch to the unstable package list. Lol. I sure didnt.
                                  Trying it now.
                                  • Danalundefined
                                    Danal
                                    Yeah, you probably found it on the Wiki, here is a cut paste, you can just run these exactly as shown:
                                    wget -q https://pkg.duet3d.com/duet3d.gpg
                                    wget -q https://pkg.duet3d.com/duet3d-unstable.list
                                    sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
                                    sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
                                    sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
                                    sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
                                    AFTER those run, one more time:
                                    sudo apt update
                                    • Danalundefined
                                      Danal
                                      Once all that finishes, Duet Web should suddenly work.
                                      A reset should not be required... but... if things still won't connect, first action is power cycle. That sequence above is pretty solid.
                                      • Demiundefined
                                        Demi
                                        Oh, whoops. I may have jumped the gun. I ran with Bearers instructions, followed with an update/upgrade. Now returning:
                                        Listing... Done
                                        duetcontrolserver/unstable,now 1.3.2 armhf [installed,automatic]
                                        duetcontrolserver/unstable 1.3.1 armhf
                                        duetcontrolserver/unstable 1.3.0 armhf
                                        duetcontrolserver/unstable 1.2.5.0 armhf
                                        duetcontrolserver/unstable 1.2.4.0 armhf
                                        duetcontrolserver/unstable 1.2.3.1 armhf
                                        duetcontrolserver/unstable 1.2.3.0 armhf
                                        duetcontrolserver/unstable 1.2.2.1 armhf
                                        duetcontrolserver/unstable 1.2.2.0 armhf
                                        duetcontrolserver/unstable 1.2.1.0 armhf
                                        duetcontrolserver/unstable 1.2.0.0 armhf
                                        duetcontrolserver/unstable 1.1.0.5 armhf
                                        duetcontrolserver/unstable 1.1.0.4 armhf
                                        duetcontrolserver/unstable 1.1.0.3 armhf
                                        duetcontrolserver/unstable 1.1.0.2 armhf
                                        duetcontrolserver/unstable 1.1.0.1 armhf
                                        duetcontrolserver/unstable 1.1.0.0 armhf
                                        duetcontrolserver/unstable 1.0.4.1 armhf
                                        duetcontrolserver/unstable 1.0.4.0 armhf
                                        duetcontrolserver/unstable 1.0.3.5 armhf
                                        duetcontrolserver/unstable 1.0.3.3 armhf
                                        duetcontrolserver/unstable 1.0.3.2 armhf
                                        Restarting.
                                        • Danalundefined
                                          Danal
                                          Our instructions looked different but did the same things. Your status looks GOOD
                                            A Former User @Danal
                                            almost; but chrishammn never confirmed or denied if stable and unstable list should co-exist after not too long ago asking someone to remove the stable list.
