    Firmware update woes. Duet3
    Firmware installation
    1.7k
    • Danalundefined
      Danal
      Chris is the author of much of this, and anything he says (instantly!!) overrides anything I say. I am a technically literate end user who sometimes tries to help.
      As he said, RC7 is going to be incompatible with certain releases (including the latest stable) of DSF.
      Also, as he said, installing firmware with bossa is really a fallback procedure. Once you get to the point where DSF, DWC, and the Firmware are all at releases that talk to each other, you should never have to bossa.
      One of the reasons why I wanted the output of sudo apt list duetcontrolserver -a is it will tell us what DSF release is installed, and which feed your Pi is on.
      • Demiundefined
        Demi @chrishamm
        @chrishamm
        Thanks for the help everyone.
        "A SD card must NOT be present in the Duet 3 when connecting a Raspberry Pi to it"
        It is not, Im using the same card for both the board and the pi, and bouncing back and forth.
        "RRF 3.01-RC7 is incompatible to the latest stable DSF release. You have to stick with 3.0 until the next stable version is out"
        Okay, if I am understanding correctly, the GPIO control method cant be used at this time with the newest firmware. No biggie for me, the intent is to run the board through USB control from a pi running Repitier as a front panel. I was just doing basic setup with the pi in this config.
        "Firmware updates generally do not need to be installed manually. This is done automatically when the system components (packages) of the DuetPi OS are updated"
        How is this accomplished? Do I need to SSH into the pi and update, or do I need to flash a new OS to the SD card for the pi? The only reason I went down this road was I was having issues with deployprobe.g not being called for M401 and related. These Duet3s are being used in a production facility, and Im the guy that got picked to implement them, so I really do appreciate how quickly you all have jumped in to help me. Im at pucker factor 5.5.
        Danalundefined A Former User? 2 Replies Last reply Reply Quote 0
        • Danalundefined
          Danal @Demi
          @Demi said in Firmware update woes. Duet3:
          @chrishamm
          Good.
          If I understand your statement correctly... no... "the GPIO method" is available at every release, if DSF and the firmware match. Longer answer: Tthe firmware (on the Duet board itself) and the DSF (DuetSoftwareFramework) on the Pi must be at release levels that are compatible with each other. We know that you have RC7 on the firmware. We don't know, at this moment, what DSF you have.
          Further complicating this answer: There is a "stable" release path on the install servers, and an "unstable". I don't know which one you chose back at the time you built the SD card. If you used the "out of the box" card, you are on "stable".
          To finish this thought: We MAY need to bossa one more time. After that, everything will keep itself in sync.
          This may be a unique requirement of your production environment, but... generally everybody in Duet land recommends against this. It un-does most of the advanced function of the Duet (web, onboard files, onboard monitoring), and leaves you with an expensive board that is forced to be dumb.
          Anyway, not all that relevant to the learning curve here...
          Correct. ssh into Pi, then sequence is always:
          sudo apt update
          sudo apt upgrade
          (or, if for some reason you don't want the Pi to upgrade itself 'sudo apt upgrade duetsoftwareframework')
          We will get you going. 🙂
            A Former User @Demi
            It does depend on the DuetSoftwareFramework (or probably specifically duetcontrollserver) already working; if you have an incompatible firmware on the Duet apt update will not update the firmware.
            Specifically apt update will also update the package RepRapFirmware, and as part of its script it will ask the Duet board to run the update just like you would run M997 S1 from a console - but if the board isn't connected or otherwise unable to communicate with the running version of DSF the update will not succeed, and as far as I know it will not retry - but once communication is sorted you can run M997 S1 as it will read the firmware file that was part of the RepRapFirmware update.
            • Demiundefined
              Demi
              @Danal said in Firmware update woes. Duet3:
              Ohhhh. Headslap. Alright standby, working on it now. Yeah I know the front panel deal is weird. Its a long and strange story, but we have some printers that were purchased that already have front panels that underperformed in their shipped state, and a safety requirement that they can be controlled physically. Ill update the pi and report back in 5.
              • Demiundefined
                Demi
                Before:
                pi@duet3:~ $ sudo apt list duetcontrolserver -a
                Listing... Done
                duetcontrolserver/stable,now 1.2.4.0 armhf [installed,automatic]
                duetcontrolserver/stable 1.2.3.0 armhf
                duetcontrolserver/stable 1.2.2.1 armhf
                duetcontrolserver/stable 1.1.0.5 armhf
                duetcontrolserver/stable 1.0.4.1 armhf
                duetcontrolserver/stable 1.0.3.1 armhf
                After
                sudo apt-get update
                sudo apt-get upgrade:
                Listing... Done
                Its...the same? DCS error persists. Restarting.
                • Danalundefined
                  Danal
                  Thanks @bearer, very good clarification!
                    A Former User @Demi
                    Its...the same?
                    need to switch to the unstable packge list.
                    edit:
                    #comment out stable list
                    sudo sed -i '/ stable/s/^/#/g' /etc/apt/sources.list.d/duet3d.list
                    #add unstable list
                    echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.list
                    • Danalundefined
                      Danal
                      Yep, or regress the firmware on bossa. I believe forward is better, I'm going to give him instructions for that.
                      • Demiundefined
                        Demi
                        You guys are awesome. Im a babe in the woods over here, and thank you Danal for anticipating that I didnt know how to switch to the unstable package list. Lol. I sure didnt.
                        Trying it now.
                        • Danalundefined
                          Danal
                          Yeah, you probably found it on the Wiki, here is a cut paste, you can just run these exactly as shown:
                          wget -q https://pkg.duet3d.com/duet3d.gpg
                          wget -q https://pkg.duet3d.com/duet3d-unstable.list
                          sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
                          sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
                          sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
                          sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
                          AFTER those run, one more time:
                          sudo apt update
                          • Danalundefined
                            Danal
                            Once all that finishes, Duet Web should suddenly work.
                            A reset should not be required... but... if things still won't connect, first action is power cycle. That sequence above is pretty solid.
                            • Demiundefined
                              Demi
                              Oh, whoops. I may have jumped the gun. I ran with Bearers instructions, followed with an update/upgrade. Now returning:
                              Listing... Done
                              duetcontrolserver/unstable,now 1.3.2 armhf [installed,automatic]
                              duetcontrolserver/unstable 1.3.1 armhf
                              duetcontrolserver/unstable 1.3.0 armhf
                              duetcontrolserver/unstable 1.2.5.0 armhf
                              duetcontrolserver/unstable 1.2.4.0 armhf
                              duetcontrolserver/unstable 1.2.3.1 armhf
                              duetcontrolserver/unstable 1.2.3.0 armhf
                              duetcontrolserver/unstable 1.2.2.1 armhf
                              duetcontrolserver/unstable 1.2.2.0 armhf
                              duetcontrolserver/unstable 1.2.1.0 armhf
                              duetcontrolserver/unstable 1.2.0.0 armhf
                              duetcontrolserver/unstable 1.1.0.5 armhf
                              duetcontrolserver/unstable 1.1.0.4 armhf
                              duetcontrolserver/unstable 1.1.0.3 armhf
                              duetcontrolserver/unstable 1.1.0.2 armhf
                              duetcontrolserver/unstable 1.1.0.1 armhf
                              duetcontrolserver/unstable 1.1.0.0 armhf
                              duetcontrolserver/unstable 1.0.4.1 armhf
                              duetcontrolserver/unstable 1.0.4.0 armhf
                              duetcontrolserver/unstable 1.0.3.5 armhf
                              duetcontrolserver/unstable 1.0.3.3 armhf
                              duetcontrolserver/unstable 1.0.3.2 armhf
                              Restarting.
                              • Danalundefined
                                Danal
                                Our instructions looked different but did the same things. Your status looks GOOD
                                  A Former User @Danal
                                  almost; but chrishammn never confirmed or denied if stable and unstable list should co-exist after not too long ago asking someone to remove the stable list.
                                  • Danalundefined
                                    Danal
                                    Once everything is back up, just for fun, try this from the Pi ssh session
                                    echo "m115" | sudo /opt/dsf/bin/CodeConsole
                                    Mine returns:
                                    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC7 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE
                                    _DATE: 2020-04-14b3
                                    and the fact that it returns anything indicates the Pi and the Duet are connected.
                                    • Danalundefined
                                      Danal @A Former User
                                      @bearer said in Firmware update woes. Duet3:
                                      Ah, very interesting. Should we update the documentation in the "getting started"?
                                        i re-read it after his comment, and i guess it could be interpreted as either or, and the rest of us missed that. (but i suspect english is not the native language for me nor the author of the text so ymmw). however adding the key in both scenarios would indicate one or the other. if the text were to be changed replacing all the key stuff with wget -qO - https://pkg.duet3d.com/duet3d.gpg | sudo apt-key add - would probably be worth while as well.
                                        clarifying if it is an issue and making the instructions clearer would probably be a good thing in any case.
                                        • Danalundefined
                                          Danal
                                          I joke, and I repeat JOKE, that I am not a native English speaker.
                                          I was born in a small town in TX, and the grain of truth behind that joke is that I really did take some tutoring at a point long after college, in my mid-career, so that I could speak accent-less, grammatically correct, English when I need to in business situations. It did seem to unlock some advancement that was lagging a bit.
                                          But what REALLY cured my TX accent, and made me sound neutral american, was living in the Greater London Area (New Barnet) for about a year.
                                          • Demiundefined
                                            Demi
                                            It works!!! Good LORD. Im sure glad you were all here to help me, I would have never gotten there but I still have the ethernet issue.
                                            So, I pull the card out of the Pi. Put it in the Duet3, plug in the ethernet. It doesnt join the network. I plug in USB and connect via Pronterface.
                                            Connecting...
                                            Printer is now online.
                                            >>>M122
                                            SENDING:M122
                                            RepRapFirmware for Duet 3 MB6HC version 3.01-RC7 running on Duet 3 MB6HC v0.6 or 1.0
                                            Board ID: 08DJM-956L2-G43S4-6J9DD-3SJ6M-TB6AG
                                            Used output buffers: 4 of 40 (4 max)
                                            Static ram: 154580
                                            Dynamic ram: 161588 of which 24 recycled
                                            Exception stack ram used: 308
                                            Never used ram: 76716
                                            Tasks: NETWORK(ready,2084) HEAT(blocked,1196) CanReceiv(suspended,3824) CanSender(suspended,1484) CanClock(blocked,1432) TMC(blocked,216) MAIN(running,4540) IDLE(ready,80)
                                            Owned mutexes:
                                            Last reset 00:05:00 ago, cause: power up
                                            Last software reset at 2020-04-16 10:52, reason: User, spinning module GCodes, available RAM 76640 bytes (slot 0)
                                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04432000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                                            Error status: 0
                                            [ERROR] Error status: 0
                                            Free file entries: 10
                                            MCU temperature: min 33.9, current 42.7, max 42.7
                                            Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                            12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
                                            Driver 0: standstill, reads 24921, writes 14 timeouts 0, SG min/max 0/0
                                            Driver 1: standstill, reads 24922, writes 14 timeouts 0, SG min/max 0/0
                                            Driver 2: standstill, reads 24923, writes 14 timeouts 0, SG min/max 0/0
                                            Driver 3: standstill, reads 24923, writes 14 timeouts 0, SG min/max 0/0
                                            Driver 4: standstill, reads 24927, writes 11 timeouts 0, SG min/max 0/0
                                            Driver 5: standstill, reads 24927, writes 11 timeouts 0, SG min/max 0/0
                                            Slowest loop: 1.95ms; fastest: 0.15ms
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Heater 1 is on, I-accum = 0.0
                                            Segments left: 0
                                            Movement lock held by null
                                            HTTP is idle in state(s) 0
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is ready with "M122" in state(s) 0
                                            Aux is idle in state(s) 0
                                            Trigger is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            LCD is idle in state(s) 0
                                            SBC is idle in state(s) 0
                                            Daemon is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 1.95ms; fastest: 0.01ms
                                            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                            HTTP sessions: 0 of 8
                                            - Ethernet -
                                            State: disabled
                                            Error counts: 0 0 0 0 0
                                            [ERROR] Error counts: 0 0 0 0 0
                                            === CAN ===
                                            Messages sent 1201, longest wait 0ms for type 0
                                            === Linux interface ===
                                            State: 0, failed transfers: 0
                                            Last transfer: 93602ms ago
                                            RX/TX seq numbers: 0/1
                                            SPI underruns 0, overruns 0
                                            Number of disconnects: 0
                                            Buffer RX/TX: 0/0-0
                                            Ethernet disconnected seems like the key entry here.
                                            Send:
                                            M552 S1
                                            And BAM, everything works! If I restart I have to reconnected and do it all over again to get ethernet (stand alone) working. I tried putting the M552 S1 in config.g but it doesnt enable ethernet.
