    Should M999 terminate the DSF core application?
    DSF Development
    9
    49
    2.1k
    • Danalundefined
      Danal @garyd9
      @garyd9 said in Should M999 terminate the DSF core application?:
      @Danal said in Should M999 terminate the DSF core application?:
      Personally, I'd be in favor of a full SBC restart as a result of an M999. In my opinion, this should also be the default.
      And again, what should the default behavior, no options, of M999 be?
      I think I disagree with the default rebooting the entire SBC operating system. First, that would require su permissions (while terminating processes running as 'duet' would only require the duet user.) Second, it creates possible unintended side effects.
      In other words, rebooting the entire SBC takes "duet" functionality outside of the "duet" sandbox.
      Yeah, I don't have much hope of actually getting broad consensus to make that the default.
      People still see the SBC as somehow separate from the Duet system. Example: "Sandbox". Example: "SU permissions". That entire way of thinking is very Pi centric. It stopped being a Pi the moment it got bolted into the printer.
      Again, I don't really expect to convince people of this. So let's ask the broader community:
      Assume M999 can reset:
      • just the board
      • board + DSF
      • board + DSF (somewhat implicit in the reboot) + Pi (reboot)
      What should the default, M999 with no arguments, be?
      • chrishammundefined
        chrishamm administrators
        Just throwing in a few thoughts: There could be a parameter for M999 that tells DCS to restart provided M999 only resets the Duet 3 + expansion boards. In addition, we will need a new M-code to either shut down or restart the Pi on demand. All of these actions could be made easily accessible on the Machine Settings page of DWC for users of DSF.
        PS: I agree more G-codes should effect the machine configuration if users are on DuetPi. We will come up with a new DSF plugin to achieve that. I don't want to distract too much from the actual question though: What should M999 do by default?
        Duet software engineer
        • ChrisPundefined
          ChrisP
          @chrishamm said in Should M999 terminate the DSF core application?:
          Personally, my vote would be for:
          • M999 resets the board, expansion boards and DSF by default
          • M999 with some parameter can reset the board, expansion boards and the whole SBC
          • M999 with some other parameter runs some *.g file to "park" the physical system and then safely shuts down the SBC
          Danalundefined 1 Reply Last reply Reply Quote 1
          • Danalundefined
            Danal @ChrisP
            @ChrisP said in Should M999 terminate the DSF core application?:
            Sounds great. Q: Is that third one really the existing "pause" or "stop" g-code followed by an M999 with the shutdown param?
            ChrisPundefined 1 Reply Last reply Reply Quote 0
              A Former User @Danal
              i wonder why; where did you buy your SBC?
              • ChrisPundefined
                ChrisP @Danal
                Hmm, yeh, very possibly somethings similar, but I'm not sure the same. Take for example the case where you want to shutdown the system and walk away - pause.g or stop.g won't necessarily wait for heaters to be cool etc. The thing I had in mind I guess is similar to setting all setpoints to 0 and then doing M116... but you'd need an M code or some means of defining the "safe" temperature when it's okay to shutdown the SBC etc. Just an idea.
                • Danalundefined
                  Danal @A Former User
                  @bearer said in Should M999 terminate the DSF core application?:
                  Duet specifies a range of hardware/software choices to go in that spot as a component of the Duet system.
                  garyd9undefined 1 Reply Last reply Reply Quote 0
                  • gtj0undefined
                    gtj0
                    Holy Moly. You sleep in and look what you miss. 🙂
                    I don't actually care what M999 can do as long as I can configure it either with gcode parameters or entries in config.json. I'm kinda hesitant to recommend the default be "restart everything" but after thinking about it, maybe it should. @Danal and @gloomyandy I -1's your posts but after I wiped the sleep from my eyes I'm OK with it. I can't remove the -1's though. 🙂
                    My big concern is that there's no one-size-fits-all solution for this except to make it configurable.
                    For instance, I'd never want my Jetson Nano SBC to be restarted. I also think that even a 5 second restart delay is too much for the DCS. In this case, it should start immediately. That, however, I can override in a duetcontrolserver.service.d conf file.
                    • garyd9undefined
                      garyd9 @Danal
                      I don't look at it like that, and I don't think many other people do/will. If it's nothing but a simple component of the duet, it's an incredibly .. clunky.. component. It would be like spooling up a Windows 10 Pro machine with the sole purpose of driving a USB webcam.
                      I'd suggest that if the SBC is actually a "part of" the duet system, it's a downgrade of the system due to making the duet harder to use. With the SBC connected, I can't just flip the power switch to turn everything off. I have to gracefully shutdown. With the SBC connected, I have more parts I have to maintain (in terms of both hardware and software.)
                      Typing this makes me realize that the SBC can be seen as being a reversion to the older printer controller boards that require a PC to be attached when printing - and the PC sends single gcode commands over the USB link. (Of course, the DSF/Duet combo is much faster than that.) Is that a good thing?
                      • Danalundefined
                        Danal
                        This is an open question among many people. I have a Pi on a CNC, a Duet printer, and a couple of monitors. I haven't done a shutdown on any of them, I've just yanked power, in years. One of the monitors in particular is under heavy development, and I must have power cycled that thing eight or ten or a dozen times a day since I started the github, which shows to be about 9 days ago.
                        Let me be clear, I am not trying to re-open the "pi shutdown" debate, nor convince anybody to do anything different. Everybody do what they believe to be right.
                        However, don't take the need to shutdown as "carved in stone" either.
                        Who knows, maybe I'll get burned tomorrow.
                        • Danalundefined
                          Danal @garyd9
                          I believe I understand your perspective, at least in some ways.
                          I would nit-pick the "more parts to maintain", given that the upgrade activities for a D3+Pi are much simpler than for any past duet. No finding files, no figuring out which combinations you need. Just choose your feed, and run the same two commands whenever you wish to advance. (assuming this technique becomes reliable, and I believe it is already there).
                          Having said that, more/less clicks to maintain is probably not all that relevant to the philosophic question of "part of the system" or not.
                          I would also challenge the metaphor to old USB. Having a PC or Mac with all of its functionality drive a printer is very different than a dedicated SBC. Various "embedded" use cases are one of the big reasons that SBCs were invented.
                          Again, fun discussion, but not all that relevant to the underlying question.
                          So let me ask it this way. A popular use for RPi is a "whole home" or "home automation" controller. Would anyone consider running this function on the physical Pi embedded in their 3D Printer? Probably technically possible... but it would seem very non-optimal to combine these things. That leads back to the philosophic question: Is the SBC bolted into a given printer part of the Duet implementation on that printer? or is it somehow separate?
                          • gtj0undefined
                            gtj0 @Danal
                            So let me ask it this way. A popular use for RPi is a "whole home" or "home automation" controller. Would anyone consider running this function on the physical Pi embedded in their 3D Printer? Probably no technical reason you can't... but it would seem very non-optimal to combine these things. That leads back to the philosophic question: Is the SBC bolted into a given printer part of the Duet implementation on that printer? or is it somehow separate?
                            I think it's "part of the printer" BUT it may be doing things nor directly involved in printing, like running your DuetLapse 🙂 or maybe later, even slicing. I'd hate to send M999 and have the SBC restart in the middle of combining all those jpegs into an mp4 or aborting a slice.
                            • Danalundefined
                              Danal @gtj0
                              @gtj0 said in Should M999 terminate the DSF core application?:
                              So if the default M999 is "board + DSF" and it takes an extra parm to reboot the SBC, would that would be a good balance?
                              gtj0undefined 1 Reply Last reply Reply Quote 2
                              • gtj0undefined
                                gtj0 @Danal
                                Works For Me!
                                • Danalundefined
                                  Danal
                                  Yeah, I think that's a pretty good balance spot.
                                  I also think it answers the question that Chris originally asked. Fun discussions... and a conclusion! Will wonders never cease!.
                                  • garyd9undefined
                                    garyd9 @Danal
                                    This is like saying "I manually spin my stepper motors really fast all the time while they are still plugged into the duet, and never once have I experienced a problem."
                                    Frequently not having a failure doesn't mean it's not a reckless thing to do, and your argument could even encourage other people to do the same reckless thing. There is simply no (reasonably feasible) way to ensure a clean shutdown of a raspbian included read/write filesystem on sudden power loss. It might even be a good idea on these SBCs to disable the filesystem write cache, and force all the logs, etc, to be written to a tempfs.
                                    On a current Raspberry Pi, no - but only because of the limitations of the board. If I had a SBC with a better processor, and much faster file I/O, I'd have no problem whatsoever doing that. I could justify it as both are functions that control physical appliances.
                                    • Danalundefined
                                      Danal
                                      Re: Shutdown.
                                      We are going to disagree on this one.
                                      And, no, those two situations are not at all parallel. There is an RPM of steppers that WILL cause damage. This is simply provable, in moments (I won't ask anyone to demonstrate). There is no way to prove or disprove that fsck on startup will or won't handle any possible power down state, simply because you can't prove a negative.
                                      Again, I really didn't want to reopen this debate. Every individual should do what they believe is right. Please, no one should change their habit based on THIS discussion.
                                      Re: Running multiple things.
                                      So you'd keep your printer powered on at all times to run your home auto? (Or maybe power up and down subsections...) And you'd accept interruptions to your home auto when you had no choice than to power cycle the printer? And so on and so forth. There is no right answer here, but this all seems contrary to the mission of "single board, embedded, computers".
                                      I sincerely hope SBCs are headed the other way... more of them (not fewer), single "function" (maybe "area of function" is a better phrase), and so forth. More specialized, not more shared.
                                      Again, we may have to agree to disagree.
                                      • garyd9undefined
                                        garyd9 @Danal
                                        Re: Shutdown.
                                        Why keep debating it immediately before stating you didn't want to reopen it? 😉
                                        If you look above, you'll see that I don't see the SBC as integrated as part of the printer. I see it as something that controls the printer. Just as a computer controls my webcam, and the computer running my home automation controls a light switch. So, I wouldn't power down my home automation if/when I power down the printer: I'd turn off the printer and leave the SBC running. (I already do this.)
                                        "Single board computer" doesn't mean "single purpose computer." As well, it's not embedded within the duet. An embedded system wouldn't be sold separately from a different company with a different physical footprint that's optional. It would be "embedded." As well, most devices that actually embed linux-based OS's (such as home internet routers) configure the OS to be more tolerant of power outages (by not caching filesystem (or NVRAM) writes, and using tempfs for logs, etc) and do other things that essentially make the underlying OS (and general purpose processor) invisible.
                                        • Danalundefined
                                          Danal
                                          Because you keep posting about it and I do wish that bystanders know there are two, widespread, operational practices. I don't want people to change in either direction without more research on their own.
                                          garyd9undefined 1 Reply Last reply Reply Quote 1
                                          • garyd9undefined
                                            garyd9 @Danal
                                            That's fair. I hope you don't take offense at my debating with you. Discussion is the best way to share different views/opinions. Once in a while, new and better ideas are the result.
