    Endstop do I need a resistor?
    2.2k
    • Synapsisundefined
      Synapsis
      Ok one last question, I hope, end stops now working ok took out the R1 and R2 and it works, question now if I use M581 Z2 S1 T0 C0 this will send a M112 and reset the board if I use T1 I would get a pause (which I want ) but this only works while printing?
      I didn't want to use a trigger because there maybe a little delay before executing the command.
      Am i forced to use T0?
      • Danalundefined
        Danal @Synapsis
        @Synapsis said in Endstop do I need a resistor?:
        What is your goal? When homing, the printer will stop itself if it hits either of those endstops.
        Do you want it to pause if it hits one while printing? Or something else?
        Synapsisundefined 1 Reply Last reply Reply Quote 0
          A Former User @Danal
          @Danal said in Endstop do I need a resistor?:
          Think of two of these in parallel, with one of them triggered
          ouch; is that a common schematic for all those endstops with leds?
          • Danalundefined
            Danal @A Former User
            @bearer said in Endstop do I need a resistor?:
            Yeah, ouch indeed. I'm glad you see it as well.
            AFAIK it is common to anything that has that "Design by MakerBot" in one corner. Including BigTreeTech and several other retail/channel brands. Meaning, VERY common.
            • Synapsisundefined
              Synapsis @Danal
              They are a backup in case during homing the Z-probe for some reason does not work, so I want it to stop the movement of the bed but without having to reset the printer by recycling it off/on for example. There will be one near the two lead screws.
              • Danalundefined
                Danal @Synapsis
                Got it.
                During HOMING, it Duet allows both a Probe and Endstop defined on the same axis. I believe (double check) that either one stops the axis. This would mean no triggers or macros needed.
                During PRINTING, it would need to be a trigger. They do, by the way, trigger in milliseconds, plenty quick enough to prevent a crash (depending on what the triggered macro does).
                There is a bit of a dilemma on "kill it instantly" vs "pause it so it does not require a reset, and can be restarted". Consider the case of a long move. Any form of pause must occur at move boundaries. If this is a long move that hits the switch , there is no correct answer to pause/restart. This has nothing to do with the switches or the triggers or etc. It is literally the nature of G-Code.
                • Synapsisundefined
                  Synapsis @Danal
                  Ok still looking for the correct info but from what info i have It should work maybe.
                  Doing a M119 I get
                  Endstops - X: not stopped, Y: at max stop, Z: not stopped, Z probe: not stopped
                  So I would think there are two on the Z axis also because i have a M574 Z2 S1 to define it. When I tried homing i triggered the switch but it did not stop the homing the Z probe did as usual.
                  • Danalundefined
                    Danal
                    Wired the way the two switches are wired, they are showing as "Z: not stopped". That should change to "Z: Stopped" whenever you click either one.
                    • Danalundefined
                      Danal @Synapsis
                      M574 Z2 S1
                      Z2 is incorrect. Z2 means "max numeric value of z". Z1 means "minimum value". That is what you should be running.
                      Note: This has nothing to do with whether the bed is "up" or "down" in relation to the floor... just whether the numbers get smaller or larger.
                      • Synapsisundefined
                        Synapsis @Danal
                        Read above.
                        Yes when I do trigger the switch and do a M119
                        Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped,
                        Z: at max stop isn't Z: Stopped as you said.
                        • Synapsisundefined
                          Synapsis @Danal
                          M574 Z2 S1
                          Tried that but still does not stop.
                          M119
                          Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stopped
                          If I use M581 Z2/1 S1 T2 it will do the emergency stop.
                          • Danalundefined
                            Danal
                            Yeah, I wasn't absolutely sure that "both" endstop and probe worked.
                            It will have to be triggers, then.
