RepRapFirmware 3.01-RC7 available
@ChrisP said in RepRapFirmware 3.01-RC7 available:
I guess this is more of a feature request than a bug, but I've noticed that if using a Duet3 with SBC,it is possible that the system can sit in a potentially unsafe state while the SBC boots. I first noticed the issue when power cycling before the nozzle had fully cooled and therefore before the thermostatic fan on the heatsink had stopped. During this period between power up and DCS being fully started, the Duet sits there being dumb and not knowing that the fan should be on.
I realise that there's an argument for not resetting while thermostatic fans are on etc., but it's a thing I do relatively regularly on many of my Duet based systems running Duet2s etc and it's not an issues. Sometimes it's not by choice either if DCS crashes and the only way I have to hand to restart is a power cycle.
Therefore, would it be possible to implement a means of having an SD in the Duet3 too with just some very basic config so that this can be run immediately to initialise heaters/fans/guards etc., but then still wait to connect to the SBC?For me, running a D3+Pi, this takes <25 seconds. For example, if I power cycle while everything is up and running, from the moment I hit power on to the moment the thermostatic fans kick in is less than 25. In fact, it is closer to 20.
How long does this take on your system?
I made 2 print with 5 hours print time each, with the SBC connected.
the system is updated to the RC7 and the new DSF Framework, DWC
the system runs stable, no reconnects anymore.
looks good so far for me.
have to test some macros and other topics were i had issues...
thanks to @dc42 , @chrishamm
@dc42 I'm pretty sure this is an RRF issue and not DSF... I'm not getting the "Probe triggered at start of move" error message when running
G29 S0
and the probe is in fact triggered at the start of a probe. The mesh probe just stops and the console returns "ok". I ran theG29 S0
from the Duet3 USB console to make sure. I forgot to capture the M122 but it showed no errors or abnormalities. -
Sometimes I watch my printer running and I just need to post a quick message to those involved in the development of RRF3 to say 'thank you.'
I don't think people can possibly realize everything that RRF3 does. The end result of a properly configured printer is just "magic."
(RC7 is working well for me on my delta with a standalone duet3.)
@gtj0 said in RepRapFirmware 3.01-RC7 available:
G29 S0
from the Duet3 USB console to make sure. I forgot to capture the M122 but it showed no errors or abnormalities.I'm sorry, I can't reproduce that. I inverted the Z probe input pin so that it was triggered at the very start, and ran G29 from DWC:
16/04/2020, 10:24:45 g29 Error: Z probe already triggered before probing move started I then tried from YAT/USB:
g28 ok g29 s0 Error: Z probe already triggered before probing move started ok However, the code for handling this error changed in RC7, so there could well be a new issue. Are you doing anything differently? Does your probe use deploy/retract files?
EDIT: I just retested with deployprobe.g and retractprobe.g files present, and I have reproduced the problem.
@Danal said in RepRapFirmware 3.01-RC7 available:
So for me with a D3 and Pi4 it takes just over 24 seconds each time, which I appreciate isn't an age, but it's still not ideal.
Yeah, this is very much a judgement call on where to spend resources. A stand-alone board gets from power on to fans on in about 8 seconds, (not counting the little blip right at boot). So, collapsing out somewhere under 20 seconds, as vs some number of development hours (that I think are larger, not smaller, when I think about all the edge cases)... very much a judgement call.
Oh yeh, I 100% agree that there are bigger/more important issues and features to implement and fix first. However, I run a system where this delay is borderline unacceptable and in standalone on a D2, D3 or even the older boards, the fans start pretty much instantaneously. I'll admit I haven't time it (though I'm very tempted now.haha) but my gut feeling is that it 2 seconds or less.
Anyway, as I said initially, I'd like it to be added as a feature request if possible, because I can't imagine that one should be that hard to implement, but yeh the focus should be on other more important features first.
G29 S0
from the Duet3 USB console to make sure. I forgot to capture the M122 but it showed no errors or abnormalities.This is now fixed in the 3.01 source code and in the firmware binaries at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
@dc42 said in RepRapFirmware 3.01-RC7 available:
G29 S0
Fixed in RRF but not properly propagating through DCS. Will open new issue for that.
I am quite happy with this DWC 2.1.2 + RRF 3.01-RC7 combo.
DWC somehow feels more responsive, and my phone loads DWC without issues now. It often happened that the loading of DWC froze with the 'blue bar' halfway, and I had to reload a few times.
