pydsfapi [v3.2.0] - Official Python Client Library for DSF
@Danal said in pydsfapi - Official Python Client Library for DSF [beta]:
Fantastic! This was somewhere "on my list" and I'd much rather use an existing.
Actually your existing library was a jump-start for me.
Great community here...
So thanks to you as well!
May I request a couple of usage examples in one of the readme.md files? I'd like to convert my tool alignment scripts ASAP.
I will add some. EDIT: This might take until tomorrow.
EDIT2: Just so you don't have to starve until then
# Initialize a new CommandConnection with debug mode enabled command_connection = connections.CommandConnection(debug=True) # Connect to default socket location command_connection.connect() try: # Run a command command_connection.perform_simple_code("M117 I'm alive", CodeChannel.SPI) finally: # Close the connection command_connection.close()
If @chrishamm doesn't show up soon, I think I'm just going to rewrite the entire DSF in python (or nodejs).
@gtj0 said in pydsfapi - Official Python Client Library for DSF [beta]:
I would actually vote for NodeJS, but either would be OK.
P.S. I did fix the M999 bug. Caveat Emptor and all that, this is my very first .net on Linux... etc, etc. If anyone is willing to try the 1.2.4.0 version of DuetControlServer with this fix, download this file:
http://danalspub.com/wp-content/uploads/2020/03/DuetControlServer.zip
Unzip, and place the two files inside in /opt/dsf/bin
The 'DuetControlServer' file should have attributes of -rwxr-xr-x. If for some reason it does not, run chmod 755 DuetControlServer
After the copies:
sudo systemctl stop duetcontrolserver
sudo systemctl start duetcontrolserverIf you decide to go back, run:
sudo apt-get reinstall duetcontrolserver
or
sudo apt-get reinstall duetcontrolserver=specific version number you wish
You can find all available versions via:
apt-cache policy duetcontrolserver -
He's currently working on both DWC and DSF to get the ObjectModel up to date.
But either way please don't replace one interpreted language for another. On a RPi use something that runs natively. Use Go or Rust.
@wilriker said in pydsfapi - Official Python Client Library for DSF [beta]:
HA!. I hear COBOL is making a comeback. Actually the new "thing" is nim
@Danal (and interested others):
I have pushed a change that has added an
examples.py
that shows minimal examples of the three (four) most common usage scenarios.Also mind that I renamed the main entry point from a generic
connections.py
to a more specificpydsfapi.py
Thank you! I will take a look, and target adapting this into my tool alignment scrips.
@wilriker For beginners (of APIs) it would be very useful, so see an example in which you interact more with the duet (like move/ call M115 / read pin). I feel slighly overwhelmed with your example....
@JBisc There is an update to
pydsfapi
coming in the next couple of days. I'll update the examples then also. Thanks for pointing it out. -
@JBisc I haven't changed much with the examples but added a lot of comments (see https://github.com/Duet3D/DSF-APIs/blob/dev/pydsfapi/examples.py). Is that already enough to get you started? If not can you please provide a detailed set of things you want to achieve and I'll be happy to either add this to the
examples.py
or reply to it here in the thread. -
@wilriker Thanks. I will try it directly tomorrow and give feedback to you. Just for others who are searching: these changes are still on the dev Branch.
@wilriker Ok I tried. I took the latest commit on the dev branch (Hash: 7b7c9291aaa1e77bd570c2503f981a73410a0f32)
I changed:
cmd_conn.connect('/var/run/dsf/dcs.sock')
I ran the example file with python 3.7 and the RPI and sudo rights (dcs.sock requires it)
and I got the following error
File "/home/shares/pi/HandwritingRoboter/src/DSF-APIs/pydsfapi/pydsfapi.py", line 234, in connect server_init_message.EXPECTED_SERVER_VERSION, server_init_message.version)) AttributeError: 'ServerInitMessage' object has no attribute 'EXPECTED_SERVER_VERSION'
Probably you have an Idea what that could be?
@JBisc Yeah, the reason was me refactoring a name right before committing but after testing.
But there is another problem why it would not have happened for me anyway: the version on the
dev
branch requires DSF 2.1.0 fromunstable
repo.EDIT: I pushed another change fixing this bug right before I posted here. So once you upgraded to DSF 2.1.0 the latest commit on
dev
should work. -
Release 2.1.0
I present to you the first official release of
pydsfapi
which can be found at GitHub Releases page as usual.This is the first release of
pydsfapi
and it is target at compatibility with Duet Software Framework 2.1.0 and later (it specifically does not work with DSF 1.2.4 and earlier).With this release the package structure has been brought to a Python standard layout and a
setup.py
has been added for easier installation viadisttools
.What's missing
- There are no concrete class implementations representing the ObjectModel. For now there is a placeholder class
MachineModel
that has all the values asdict
withdict
s inside it.
Release v2.1.2
This release can be found as usual on GitHub Releases page.
Port changes from upstream
- Increase PROTOCOL_VERSION to 6
- Add G53 to string output of commands that use it
Release 3.1.0
This release syncs changes and version with latest DuetSoftwareFramework and can be found as usual on GitHub Releases page.
Ported changed from upstream
- Increase PROTOCOL_VERSION to 7
- Add new
Aux2
CodeChannel
- Comments now use
Q
asCodeType
(instead ofC
) - Letter for unprecedented parameters has been changed from empty string to
Release 3.1.1
Minor release that just updates
PROTOCOL_VERSION
to 8 to be in line with DuetSoftwareFramework 3.1.1.Can be found at GitHub Releases page.
Line 284 of pydsfapi/pydsfapi.py limits the json response to 32kB:
json_string = self.socket.recv(32 * 1024).decode('utf8')
The full machine model can easily exceed that when a print is under way, because it contains an entry for every layer, with at least 90 bytes per layer (depending on the values and number of filaments). Then the json string is just arbitrarily truncated at 32kB and you get an error such as:
Traceback (most recent call last): File "./delta_lights.py", line 99, in <module> mm = subscribe_connection.get_machine_model() File "/usr/local/lib/python3.7/dist-packages/pydsfapi/pydsfapi.py", line 455, in get_machine_model machine_model = self.receive(machinemodel.MachineModel) File "/usr/local/lib/python3.7/dist-packages/pydsfapi/pydsfapi.py", line 275, in receive return cls.from_json(json.loads(json_string)) File "/usr/lib/python3.7/json/__init__.py", line 348, in loads return _default_decoder.decode(s) File "/usr/lib/python3.7/json/decoder.py", line 337, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end()) File "/usr/lib/python3.7/json/decoder.py", line 353, in raw_decode obj, end = self.scan_once(s, idx) json.decoder.JSONDecodeError: Unterminated string starting at: line 1 column 32768 (char 32767)
If you change the (32 * 1024) to something bigger it goes away, but it doesn't take a very large print to overwhelm any sensible value - 32kB at 90 bytes per layer is only 364 layers, so another 32kB gets you less than a further 73mm of print height at 0.2mm layers.
As I understand it, there's the facility in the DSF to filter the machine model returned. However, I haven't figured out of that is in pydsfapi and if so how to use it. Can a filter be used to not return the 'layers' entries?
@achrn Thanks for reporting. I will look into that.
