    Double abnormal config.g file
    • Fedekossel1undefined
      Fedekossel1
      Hello, strangely something strange happens to me, after editing the config.g file the changes made are not made by the duet, I realized that I have to edit the config.g.bak file as well,Just so the duet makes the changes I changed on the config.g, I tried to delete the config.g.bak file as soon as I turn off no longer starts And it doesn't connect to the wifi network, I put the config.g.bak file back into the memory and the Card works normally. What happened?
        That sounds very strange. Config.g.bak is created automatically when you edit the config.g and save it as a backup of your previous file. It is not executed by the firmware at all.
        What firmware and DWC version are you using?
          Fedekossel1
          Version 2.05, With old versions I didn't have this problem.
