    M122 gives no output since DWC 2.1.x
    Duet Web Control
    303
    • smoki3undefined
      smoki3
      since 2.1.x M122 does not give any output on my Duet 2 Wifi. I am on RC8 and 2.1.3.
      No error and no output.
      With DWC 1.x and 2.0.7 everything is working fine so far.
        That's odd, because that combination is working for me. I presume you are sending M122 from the Console of DWC? Does this problem happen immediately after startup, or only after the printer has been running for some time?
        You can run DWC 1.22.6 if you had it installed on your SD card before you upgraded, by appending /reprap.htm to the IP address in the browser address bar. If you do that, does M122 work?
        smoki3undefined 2 Replies Last reply Reply Quote 0
        • smoki3undefined
          smoki3 @dc42
          Yes through Konsole and same behavior when I press diagnostic button in the settings.
          Already tried to reset DWC but doesn't help.
          This is what I get:
          • smoki3undefined
            smoki3 @dc42
            @dc42 said in M122 gives no output since DWC 2.1.x:
            Yes on 1.22.6 I get normal M122 output
              @smoki3 said in M122 gives no output since DWC 2.1.x:
              Thanks. I've asked @chrishamm to look into this.
              smoki3undefined 1 Reply Last reply Reply Quote 0
              • smoki3undefined
                smoki3 @dc42
                @dc42 ok thanks
                • smoki3undefined
                  smoki3
                  Just a short feedback, on 2.1.4 it is still not working
                  • smoki3undefined
                    smoki3
                    It's fixed now with RC12
