M400 / G4 P0 Not working?
Beta Firmware
579
    RobMink
    Latest Release 3.01 - RC9
    My tool changer used to wait to activate the servo for tool changing. Now after updating today the servo moves right at the beginning of the moment for the tool change.
    This is my 0:/sys/tpre3.g For tool 3. This happens with all tools.
    G1 X306 Y760 F5000 - Servo Moves concurrently with this commnad.
    G1 Y830 F2400
    M400 - I know this is redundant
    G4 P400
    M280 P0 S150 - Should move here, of course, after finishing above moves.
    G4 P400
    G1 Y800 F2400
    G1 Y760 F3600
    G10 P3 Z0.9
    Thanks for taking the time to read this!
      • Which Duet are you using?
      • If it is a Duet 3, is it with/without RPi?
      • If it is Duet 3 with RPi, what versions of DSF are you using?
        RobMink
        Sorry, yes, Duet3 with 3 exp boards, RPI4 with DSF 2.1.4
        The Servo is on the main board and the core xy moment system is on the EXP1 board. Could that be causing the issue?
        undefined 1 Reply Last reply 22 Apr 2020, 07:23 Reply Quote 0
          dc42 administrators @RobMink
          @RobMink said in M400 / G4 P0 Not working?:
          2.1.4 sounds like the DWC version. Please check the DSF version.
            RobMink
            Sorry, I forgot what the abbreviation was and had to look it up. I gleaned this from the apt-get upgrade
            Setting up duetsoftwareframework (2.1.0) ...
            Thanks again!
              Are you able to run in standalone mode temporarily and see if the problem still occurs? You don't need to disconnect the Pi to run in standalone mode.
              PS - you can verify the DSF version in DWC, it's shown in Settings->Machine Specific along with the firmware version.
                chrishamm administrators
                I tried to reproduce this problem on my test setup but failed to do so. Can you please hook up a computer to your Duet 3, open a serial monitor, run M111 P3 S1, try to provoke the problem once again, and post the output here? You can disable debugging after that again by running M111 S0.
                Duet software engineer
                  One further question: if you run the tpre3.g file manually by sending M98 P"tpre3.g"), does the problem still occur?
                  undefined 1 Reply Last reply 22 Apr 2020, 13:17 Reply Quote 0
                    RobMink @dc42
                    Thanks for the info!
                    If I run the command M98 P"tpre3.g" it works, but if I just go T0 T3 it does not. T0 will load correctly the first time, then exhibit the same behavior. I apologize if this is a bug on my end!
                    EDIT: I tried plugging the duet into my laptop and running pronterface. I get "Board 1 does not have input handle 1000" when I try and home until I reboot the printer afterwards.
                    undefined 1 Reply Last reply 22 Apr 2020, 13:32 Reply Quote 0
                      No bug at your end, I'm just trying to identify the circumstances that cause the problem. Did you have a chance to try standalone mode? EDIT: and/or getting a debug trace from RRF as chrishamm suggested.
                      That message normally means that the expansion board was reset (e.g. because of a firmware update, reset button being pressed, or firmware crash) and config.g hasn't been run since then. If you think this problem is reproducible without a deliberate reset, please let us know and post the result of M122 and M112 B1.
                        RobMink
                        I tried a USB connection again, and this time it (USB) worked. Not sure what caused the issue the first time.
                        SENDING:M111 P3 S1
                        Debugging enabled for modules: GCodes(3)
                        Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) LinuxInterface(16)
                        >>> T0
                        SENDING:T0
                        USB: T0
                        USB: G1 X96 Y760 F5000
                        USB: G1 Y830 F2400
                        USB: M400
                        USB: M280 P0 S150
                        USB: G4 P500
                        USB: G1 Y800 F2400
                        USB: G1 Y760 F3600
                        USB: M116 P0
                        USB: M105
                        >>> T3
                        SENDING:T3
                        USB: T3
                        USB: G1 Y800 F1200
                        USB: M280 P0 S40
                        USB: G1 Y830 F2400
                        USB: G1 Y760 F2400
                        Queue: M280 P0 S40
                        USB: G1 X306 Y760 F5000
                        USB: G1 Y830 F2400
                        USB: M400
                        USB: M280 P0 S150
                        USB: G4 P400
                        USB: G1 Y800 F2400
                        USB: G1 Y760 F3600
                        USB: M105
                        All the edits! Oops!
                        Ok, so a little clarification, the tool 0 docking in the last chunk after T3 ends at USB: G1 Y760 F2400 and T3 picks up at USB: G1 X306 Y760 F5000
                          Thanks. You sent the T0 and T3 commands from USB this time. Did the problem occur when you selected T0, with no tool initially selected? Did it occur when you changed from T0 to T3?
                          I think I've spotted a problem:
                          T3
                          SENDING:T3
                          USB: T3
                          USB: G1 Y800 F1200
                          USB: M280 P0 S40
                          USB: G1 Y830 F2400
                          USB: G1 Y760 F2400
                          Queue: M280 P0 S40
                          ; T0 finished docking at this point
                          USB: G1 Y830 F2400
                          USB: M400
                          USB: M280 P0 S150
                          USB: G4 P400
                          USB: G1 Y800 F2400
                          USB: G1 Y760 F3600
                          USB: M105
                          What I think is happening is that you have a M280 P0 S40 command in tfree.g and it is that command that is still being executed when the next tpre is run. RRF can't tell when the servo has finished responding to that command.
                            RobMink
                            It happend after I went from T0 to T3.
                            M280 P0 S40 is the tool release command, and the M280 P0 S150 tool grab command happens before the printer isin position to grab the tool.
                            Here is
                            ; tfree0.g
                            ; called when tool 0 is freed
                            G1 X96 Y760 F5000
                            G1 Y800 F1200
                            M280 P0 S40
                            G1 Y830 F2400
                            G1 Y760 F2400
                            Should I put a G4 P1000 or something in the end of this file and test?
                            undefined 1 Reply Last reply 22 Apr 2020, 14:08 Reply Quote 0
                              Here is
                              ; tfree0.g
                              G1 X96 Y760 F5000
                              G1 Y800 F1200
                              M280 P0 S40
                              G1 Y830 F2400
                              G1 Y760 F2400
                              Yes please, assuming 1 sec is long enough for the servo. Or put it directly after the M280 command, if you want the servo move to complete before the G1 Y830 command.
                                RobMink
                                Ok, I gave that a go. It releases the tool correctly and pulls back, pauses, but does the 'grab' command (M280 P0 S150) for T3 en route to T3. I can post a video if that would help.
                                  Thanks. I'll see if I can reproduce that. I may ask for a video later.
                                    RobMink
                                    Upgrading all using a sudo apt-get/apt-upgrade to RC10 and removing the M400 fixed the issue.
                                    undefined 1 Reply Last reply 25 Apr 2020, 16:29 Reply Quote 0
                                      Thanks, I suspected that it might because of this bug fix:
                                      • Non-movement commands that needed to be synchronised to the movement queue were sometimes executed too early
                                      undefined 1 Reply Last reply 25 Apr 2020, 16:30 Reply Quote 0
                                        RobMink @dc42
                                        Yep! Thanks for all the great work! I thought it would give it a shot when I saw that release note.
                                        10 out of 19
