    M400 / G4 P0 Not working?
    Beta Firmware
    579
    • chrishammundefined
      chrishamm administrators
      I tried to reproduce this problem on my test setup but failed to do so. Can you please hook up a computer to your Duet 3, open a serial monitor, run M111 P3 S1, try to provoke the problem once again, and post the output here? You can disable debugging after that again by running M111 S0.
      Duet software engineer
        One further question: if you run the tpre3.g file manually by sending M98 P"tpre3.g"), does the problem still occur?
        RobMinkundefined 1 Reply Last reply Reply Quote 0
        • RobMinkundefined
          RobMink @dc42
          Thanks for the info!
          If I run the command M98 P"tpre3.g" it works, but if I just go T0 T3 it does not. T0 will load correctly the first time, then exhibit the same behavior. I apologize if this is a bug on my end!
          EDIT: I tried plugging the duet into my laptop and running pronterface. I get "Board 1 does not have input handle 1000" when I try and home until I reboot the printer afterwards.
            dc42 administrators @RobMink
            @RobMink said in M400 / G4 P0 Not working?:
            No bug at your end, I'm just trying to identify the circumstances that cause the problem. Did you have a chance to try standalone mode? EDIT: and/or getting a debug trace from RRF as chrishamm suggested.
            That message normally means that the expansion board was reset (e.g. because of a firmware update, reset button being pressed, or firmware crash) and config.g hasn't been run since then. If you think this problem is reproducible without a deliberate reset, please let us know and post the result of M122 and M112 B1.
            • RobMinkundefined
              RobMink
              I tried a USB connection again, and this time it (USB) worked. Not sure what caused the issue the first time.
              SENDING:M111 P3 S1
              Debugging enabled for modules: GCodes(3)
              Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) LinuxInterface(16)
              >>> T0
              SENDING:T0
              USB: T0
              USB: G1 X96 Y760 F5000
              USB: G1 Y830 F2400
              USB: M400
              USB: M280 P0 S150
              USB: G4 P500
              USB: G1 Y800 F2400
              USB: G1 Y760 F3600
              USB: M116 P0
              USB: M105
              >>> T3
              SENDING:T3
              USB: T3
              USB: G1 Y800 F1200
              USB: M280 P0 S40
              USB: G1 Y830 F2400
              USB: G1 Y760 F2400
              Queue: M280 P0 S40
              USB: G1 X306 Y760 F5000
              USB: G1 Y830 F2400
              USB: M400
              USB: M280 P0 S150
              USB: G4 P400
              USB: G1 Y800 F2400
              USB: G1 Y760 F3600
              USB: M105
              All the edits! Oops!
              Ok, so a little clarification, the tool 0 docking in the last chunk after T3 ends at USB: G1 Y760 F2400 and T3 picks up at USB: G1 X306 Y760 F5000
                Thanks. You sent the T0 and T3 commands from USB this time. Did the problem occur when you selected T0, with no tool initially selected? Did it occur when you changed from T0 to T3?
                I think I've spotted a problem:
                T3
                SENDING:T3
                USB: T3
                USB: G1 Y800 F1200
                USB: M280 P0 S40
                USB: G1 Y830 F2400
                USB: G1 Y760 F2400
                Queue: M280 P0 S40
                ; T0 finished docking at this point
                USB: G1 Y830 F2400
                USB: M400
                USB: M280 P0 S150
                USB: G4 P400
                USB: G1 Y800 F2400
                USB: G1 Y760 F3600
                USB: M105
                What I think is happening is that you have a M280 P0 S40 command in tfree.g and it is that command that is still being executed when the next tpre is run. RRF can't tell when the servo has finished responding to that command.
                • RobMinkundefined
                  RobMink
                  It happend after I went from T0 to T3.
                  M280 P0 S40 is the tool release command, and the M280 P0 S150 tool grab command happens before the printer isin position to grab the tool.
                  Here is
                  ; tfree0.g
                  ; called when tool 0 is freed
                  G1 X96 Y760 F5000
                  G1 Y800 F1200
                  M280 P0 S40
                  G1 Y830 F2400
                  G1 Y760	F2400
                  Should I put a G4 P1000 or something in the end of this file and test?
                    Here is
                    ; tfree0.g
                    G1 X96 Y760 F5000
                    G1 Y800 F1200
                    M280 P0 S40
                    G1 Y830 F2400
                    G1 Y760	F2400
                    Yes please, assuming 1 sec is long enough for the servo. Or put it directly after the M280 command, if you want the servo move to complete before the G1 Y830 command.
                    • RobMinkundefined
                      RobMink
                      Ok, I gave that a go. It releases the tool correctly and pulls back, pauses, but does the 'grab' command (M280 P0 S150) for T3 en route to T3. I can post a video if that would help.
                        Thanks. I'll see if I can reproduce that. I may ask for a video later.
                        • RobMinkundefined
                          RobMink
                          Upgrading all using a sudo apt-get/apt-upgrade to RC10 and removing the M400 fixed the issue.
                            Thanks, I suspected that it might because of this bug fix:
                            • Non-movement commands that needed to be synchronised to the movement queue were sometimes executed too early
                            • RobMinkundefined
                              RobMink @dc42
                              Yep! Thanks for all the great work! I thought it would give it a shot when I saw that release note.
