Rotating magent sensor housing for 2.85mm?
Hello everyone,
I bought an Rotating magnet sensor, but i did not know that it is only for 1,75mm Filament diameter.
I have a Ultimaker 2+ with 2,85mm Filament, so i can't use the sensor.
Has someone a design for the downpart of the housing for 2,85mm Filament? -
@Novastorm I don't have an official housing for 2.85mm but I am aware of at least one implementation so I have asked if they are able to share. In the mean time I am not sure how proficient at CAD you are but it may be worth trying a version just enlarging the input and outlet hole to 2.9mm and the associated collet locking areas.
I have added the step files to the github repository here:
https://github.com/T3P3/FilamentMonitors/tree/master/Filament_Monitor_Magnetic_v1.7/enclosure -
Thank you for uploding the CAD, that helps a lot.
The redesign won't be a problem for me. -
@Novastorm I3CD printers have kindly shared their design:
Great!
I will take a look on their design an choose wich I will print.
My own or the design from I3CD printers.
But i think that the I3CD printers made a better work on the Bowdentube connector.
