    Duet3/pi DCS is unavailable after wiring 24V
    duet 3 rasberry pi
    8
    166
    11.6k
    • fractalengineerundefined
      fractalengineer @A Former User
      @bearer thanks;
      Well it's all fixed now with the new image...the wifi connection it is...Still unable to connect to DCS
      On a separate pi...
      On a new board...
      Maybe we can try that pin by pin connection to double check the issue wasn't the ribbon?
      I can go buy jumpers tomorrow; how many we need?
      Railcore II ZL
        A Former User @fractalengineer
        @fractalengineer said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
        how many we need?
        Minimum 9, but didn't you get a new cable?
        fractalengineerundefined 1 Reply Last reply Reply Quote 0
          @bearer no I think I got a refurb; there was only the board and SD card in it
          Railcore II ZL
          • chrishammundefined
            chrishamm administrators @Danal
            @Danal That error occurred because SPI wasn't enabled at that point, hence no /dev/spidev.0.0. It's always possible to define module options in /etc/modprobe.d, that doesn't require the driver(s) to be loaded.
            It must be the connection from the Pi to the Duet 3 (ribbon cable?). The SPI link uses pins 19-24 (see https://pinout.xyz/pinout/pin22_gpio25#) so I'd once more check continuity between these pins on both sides. The error you see in the log without any extra comment (more verbose in v2.1.0) means that no signal could be transferred over pin 22 (BCM25). DSF expects this pin to be high when it starts.
            Duet software engineer
            A Former User? fractalengineerundefined 2 Replies Last reply Reply Quote 1
              A Former User @chrishamm
              @chrishamm said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
              of curiosity what does DCS say if it gets a response, but the wrong due to say wrong firmware or spi clock?
                It's also worth starting DCS with -l debug to see a few more details. If the SPI clock is too high, you usually see warnings about failed transfers and/or checksum errors.
                  -l debug shows the difference, no difference without it.
                  #with 22 low
                  pi@raspberrypi:~ $ /opt/dsf/bin/DuetControlServer -l debug
                  [debug] Lost connection to Duet
                     System.OperationCanceledException: Timeout while waiting for transfer ready pin ...
                  [error] Duet is not available
                  #with 22 high
                     System.OperationCanceledException: Board is not available (no header) ...
                  Maybe change the first to Duet is not ready?
                  edit: sudo wasn't needed (at that point in starting up at least)
                  edit2: whops, wasn't testing the latest version, error changed to fatal, but same string.
                    Yes I thought it already showed more details so I'm going to improve that in v2.1.1.
                      fractalengineer @chrishamm
                      @chrishamm I just checked continuity once more; ever pin beeps from one board to the other.
                      Also checked for any short to ground; it’s all clear with the multimeter.
                      I’ll try wiring pin by pin using bridges; really can’t figure out what else to do
                      Unless the previous duet fried the pi4 too...
                      Railcore II ZL
                        if you've got a steady hand you could measure the voltage on pin 22 with the Duet running (before and after starting DCS) and then cross refrene with the output of running DSC with -l debug to at least verify if the Pi is reading pin 22 correctly.
                        see next post instead:
                          A Former User
                          Hold off on that; not sure why loopback testing didn't occur to me a week ago ... but:
                          https://github.com/rm-hull/spidev-test
                          combine with wiringpi's gpiocommand and two jumpers to do full (or 80%? as SCK isn't tested) diagnostic on the rPi.
                          place jumper over 22-24 and 19-21, then run commands as shown, compare to output below.
                          (Quick copy/paste to get the spidev-test tool and wiringpi):
                          sudo apt install -y git wiringpi
                          git clone https://github.com/rm-hull/spidev-test ~/spidev-test
                          cd ~/spidev-test
                          gcc spidev_test.c -o spidev_test
                          Commands to run:
                          RDY=22 CS=24 ; {
                          gpio -1 mode $CS out
                          gpio -1 mode $RDY in
                          gpio -1 write $CS 1 && echo "(Pin RDY/$RDY) `gpio -1 read $RDY` should equal `gpio -1 read $CS` (Pin CS/$CS)"
                          gpio -1 write $CS 0 && echo "(Pin RDY/$RDY) `gpio -1 read $RDY` should equal `gpio -1 read $CS` (Pin CS/$CS)"
                          { ~/spidev-test/spidev_test -v -s 8000000 -D /dev/spidev0.0 && echo RX should equal TX. ;} | tail -n3 | cut -b-100 ;}
                          What output should look like:
                          (Pin RDY/22) 1 should equal 1 (Pin CS/24)
                          (Pin RDY/22) 0 should equal 0 (Pin CS/24)
                          TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D
                          RX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D
                          RX should equal TX.
                          Repeat with wires jumpering the far side of the ribbon cable if test with jumpers on the rPi is passed.
                          (Print quality comments can be addressed to Tiertime pending full Duet conversion of the Up Mini 2)
                          • Danalundefined
                            Danal
                            I don't know about the "W" part... but I'll take a look.
                            I can also spiff it up so that its output is very clear for an "end user", in the Duet environment.
                              A Former User @Danal
                              @Danal wrong topic?
                              • Danalundefined
                                Danal
                                I thought a post said: "If a C Wizard happens along"... and then got edited... the request being to make spidev_test more duet specific, easier to interpret. ?
                                Hopefully, because I did take a look.
                                I am not a Wizard, but:
                                ./DuetTestSPI
                                spi mode: 0x0
                                bits per word: 8
                                max speed: 8000000 Hz (8000 KHz)
                                TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D  | ......@....�..................�.
                                RX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D  | ......@....�..................�.
                                Loopback on pins 19-21, SPI MOSI MISO tested successfully.
                                All tests passed, SPI should work for Duet 3 <> Raspberry Pi.
                                (removed jumper)
                                ./DuetTestSPI
                                spi mode: 0x0
                                bits per word: 8
                                RX | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  | ................................
                                Send and receive buffers do not match!
                                Check jumpers on pins 19-21; if they are correct this machine has an SPI problem.
                                Aborted
                                Much clearer messages, etc. This is 1/2 of your suggestion above, I'll do the 22-24 part in a few min, and then post a link.
                                  @Danal said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
                                  it did, but "W" didn't make much sense; anyways, as DSF depends on wiringpi anyways figured less effort than forking the spi tools. (and easier to change if other boards have different gpio mapping)
                                  • Danalundefined
                                    Danal
                                    Understood... it was obscure. Perhaps should have said "not a Wiz, but"
                                    • Danalundefined
                                      Danal
                                      OK, here you go, a 'tester' for SPI on a Pi, to see if it is hardware OK to run with a Duet.
                                      Installation:  Either:
                                        git clone https://github.com/DanalEstes/DuetTestSPI
                                      or, if you want just the binary:
                                        wget https://github.com/DanalEstes/DuetTestSPI/raw/master/DuetTestSPI
                                        chmod 744 DuetTestSPI
                                      Run
                                      Place a jumper on Pi GPIO pins 22-24 and 19-2, then:
                                      ./DuetTestSPI
                                      All messages should be self explanatory.
                                      • Danalundefined
                                        Danal
                                        @bearer
                                        I invoked the great architectural pattern of "reuse" and put your jumper pic on the github for this. I will pull it if you'd rather I not use it.
                                          A Former User
                                          Everything on the forum is CC-BY-SA AFAIK.
                                          I think I'll more or less just add some curly bracets to clean up the output and stick with it as is; simple to understand, simple to change if someone uses a different user configurable ready pin or spi device, stays up to date with past, present and future (physical) pin mappings. It also provides the techies with all the jucy details without dumming it down.
                                          If the gloas was to make it shorter, it'll all fit on one line, but defeats the simple to undertand and simple to change part. Could even tee and grep it for humanreadable output, but as the SCK signal isn't covered saying "all good" feels wrong, miss matched data will suffice as a failed test.
                                          pi@raspberrypi:~ $ RDY=22 CS=24 ; { gpio -1 mode $CS out ; gpio -1 mode $RDY in ; echo "Pin RDY/$RDY Pin CS/$CS" ; gpio -1 write $CS 1 && echo "         `gpio -1 read $RDY`         `gpio -1 read $CS` <-should be equal" ; gpio -1 write $CS 0 && echo "         `gpio -1 read $RDY`         `gpio -1 read $CS` <-should be equal" ; echo TX should equal RX: ; ~/spidev-test/spidev_test -v -s 8000000 -D /dev/spidev0.0 | tail -n2 | cut -b-100;}
                                          Pin RDY/22 Pin CS/24
                                                   1         1 <-should be equal
                                                   0         0 <-should be equal
                                          TX should equal RX:
                                            A Former User
                                            @fractalengineer the lovely Duet people released new updates RFF3.01-RC10 and DSF2.1.1.
                                            While neither will solve your problem, it'll help diagnose the SPI issues with clearer error messages printed without needing the -l debug parameter.
                                            Between that and the loopback test we should have done ages ago I think we should pinpoint the problem at last.
                                            Fingers crossed!
