    Duet3/pi DCS is unavailable after wiring 24V
    duet 3 rasberry pi
    8
    166
    12.1k
      A Former User @Danal
      @Danal said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
      I thought a post said: "If a C Wizard happens along"... and then got edited...
      it did, but "W" didn't make much sense; anyways, as DSF depends on wiringpi anyways figured less effort than forking the spi tools. (and easier to change if other boards have different gpio mapping)
      • Danalundefined
        Danal
        Understood... it was obscure. Perhaps should have said "not a Wiz, but"
        • Danalundefined
          Danal
          OK, here you go, a 'tester' for SPI on a Pi, to see if it is hardware OK to run with a Duet.
          Installation:  Either:
            git clone https://github.com/DanalEstes/DuetTestSPI
          or, if you want just the binary:
            wget https://github.com/DanalEstes/DuetTestSPI/raw/master/DuetTestSPI
            chmod 744 DuetTestSPI
          Run
          Place a jumper on Pi GPIO pins 22-24 and 19-2, then:
          ./DuetTestSPI
          All messages should be self explanatory.
          • Danalundefined
            Danal
            @bearer
            I invoked the great architectural pattern of "reuse" and put your jumper pic on the github for this. I will pull it if you'd rather I not use it.
              A Former User
              Everything on the forum is CC-BY-SA AFAIK.
              I think I'll more or less just add some curly bracets to clean up the output and stick with it as is; simple to understand, simple to change if someone uses a different user configurable ready pin or spi device, stays up to date with past, present and future (physical) pin mappings. It also provides the techies with all the jucy details without dumming it down.
              If the gloas was to make it shorter, it'll all fit on one line, but defeats the simple to undertand and simple to change part. Could even tee and grep it for humanreadable output, but as the SCK signal isn't covered saying "all good" feels wrong, miss matched data will suffice as a failed test.
              pi@raspberrypi:~ $ RDY=22 CS=24 ; { gpio -1 mode $CS out ; gpio -1 mode $RDY in ; echo "Pin RDY/$RDY Pin CS/$CS" ; gpio -1 write $CS 1 && echo "         `gpio -1 read $RDY`         `gpio -1 read $CS` <-should be equal" ; gpio -1 write $CS 0 && echo "         `gpio -1 read $RDY`         `gpio -1 read $CS` <-should be equal" ; echo TX should equal RX: ; ~/spidev-test/spidev_test -v -s 8000000 -D /dev/spidev0.0 | tail -n2 | cut -b-100;}
              Pin RDY/22 Pin CS/24
                       1         1 <-should be equal
                       0         0 <-should be equal
              TX should equal RX:
              TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D
              RX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D
                A Former User
                @fractalengineer the lovely Duet people released new updates RFF3.01-RC10 and DSF2.1.1.
                While neither will solve your problem, it'll help diagnose the SPI issues with clearer error messages printed without needing the -l debug parameter.
                Between that and the loopback test we should have done ages ago I think we should pinpoint the problem at last.
                Fingers crossed!
                • fractalengineerundefined
                  fractalengineer
                  @bearer @Danal wow thanks for the overwhelming help guys; really grateful for the support 🙂
                  Even though most of it goes above my head as I'm not a codehead at all, I managed to install and run the SPI test on my own pi3
                  @bearer I bought the dupont cables and bridged the pin as per your picture; here's the results of the SPI test:
                  pi@duet3:~/spidev-test $ RDY=22 CS=24 ; {
                  > gpio -1 write $CS 1 && echo "(Pin RDY/$RDY) `gpio -1 read $RDY` should equal `gpio -1 read $CS` (Pin CS/$CS)"
                  > gpio -1 write $CS 0 && echo "(Pin RDY/$RDY) `gpio -1 read $RDY` should equal `gpio -1 read $CS` (Pin CS/$CS)"
                  > { ~/spidev-test/spidev_test -v -s 8000000 -D /dev/spidev0.0 && echo RX should equal TX. ;} | tail -n3 | cut -b-100 ;}
                  -bash: gpio: command not found
                  RX should equal TX.
                  IF I REMOVE THE JUMPERS:
                  RX | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                  RX should equal TX.
                  Looks like the Pi is fine?
                  Onto updating everything then.
                  If the ribbon still gives us trouble I'll be able to wire using the duponts
                  Railcore II ZL
                    A Former User @fractalengineer
                    @fractalengineer said in Duet3/pi flashing Diag LED after wiring 24V DCS is unavailable:
                    40% fine, seems duet have changed a dependency so you're missing the GPIO utility. but the data part of the SPI bus is fine.
                    run sudo apt install -y wiringpi and do it again.
                    and you can also test the ribbon by making some male jumpers (or use male to male duponts for that matter).
                    It'd be interesting to see what DuetControlServer says after the update, because its looking less likely to be a rPi fault.
                      fractalengineer
                      @bearer nice; I'm getting a new error message indeed;
                      pi@duet3:~ $ apt list 2>/dev/null | grep duet
                      duetcontrolserver/unstable,now 2.1.1 armhf [installed,automatic]
                      duetruntime/unstable,now 2.1.1 armhf [installed,automatic]
                      duetsd/unstable,now 1.0.6 all [installed,automatic]
                      duetsoftwareframework/unstable,now 2.1.1 armhf [installed]
                      duettools/unstable,now 2.1.1 armhf [installed,automatic]
                      duetwebcontrol/unstable,now 2.1.5 all [installed,automatic]
                      duetwebserver/unstable,now 2.1.0 armhf [installed,automatic]
                      pi@duet3:~ $ sudo journalctl -u duetcontrolserver -e
                      Apr 25 15:46:18 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                      Apr 25 15:46:23 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
                      Apr 25 15:46:23 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 61.
                      Apr 25 15:46:23 duet3 systemd[1]: Stopped Duet Control Server.
                      Apr 25 15:46:23 duet3 systemd[1]: Started Duet Control Server.
                      Apr 25 15:46:24 duet3 DuetControlServer[3286]: Duet Control Server v2.1.1
                      Apr 25 15:46:24 duet3 DuetControlServer[3286]: Written by Christian Hammacher for Duet3D
                      Apr 25 15:46:24 duet3 DuetControlServer[3286]: Licensed under the terms of the GNU Public License Version 3
                      Apr 25 15:46:26 duet3 DuetControlServer[3286]: [info] Settings loaded
                      Apr 25 15:46:26 duet3 DuetControlServer[3286]: [info] Environment initialized
                      Apr 25 15:46:27 duet3 DuetControlServer[3286]: [fatal] Could not connect to Duet (Timeout while waiting for transfer ready pin)
                      I'll try the gpio test
                      Railcore II ZL
                        That is suggesting no connection to the Duet, the gpio test could rule out the Pi, new cable could rule out the ribbon.
                        fractalengineerundefined 1 Reply Last reply Reply Quote 0
                          fractalengineer @A Former User
                          @bearer ok here's the test again with the gpio util:
                          pi@duet3:~ $ DY=22 CS=24 ; {
                          Usage: gpio mode pin mode
                          Usage: gpio read pin
                          (Pin RDY/)  should equal 1 (Pin CS/24)
                          (Pin RDY/)  should equal 0 (Pin CS/24)
                          RX should equal TX.
                          ...And wow, here's with a jump on the ribbon...
                          pi@duet3:~ $ RDY=22 CS=24 ; {
                          (Pin RDY/22) 0 should equal 1 (Pin CS/24)
                          (Pin RDY/22) 0 should equal 0 (Pin CS/24)
                          RX should equal TX.
                          Guess we found the culprit
                          So can we try wiring using the duponts? what are the minimum wires required?
                          Railcore II ZL
                          A Former User? 2 Replies Last reply Reply Quote 0
                            Now thats interesting.
                            I wasn't able to test if that can only mean the RDY pin isn't reading correctly, or if it could be the CS pin not being asserted correctly. But it is in line with the error from DCS.
                            I'd be surprised if DCS was blocking the CS pin but not the MISO/MOSI pins, but for good measure making sure DCS isn't running might be worth while.
                            Then you could attempt to actually measure the voltage, but the fact that it isn't working is sufficient to move on to the next Pi imo. Given the RDY pin is defined as an input it should be safe to jumper it straight to 3.3v and see if the value stays at 1. That would confirm if the problem is RDY or CS.
                            As a last resort you can attempt to change the RDY pin. Its defined in /opt/dsf/conf/config.json. But you could change the definition (for the test), move the jumper and re-run the test before editing the file. Changing RDY from 22 to 26 will mean you have to use a custom cable, and connect 26 on the Pi to 22 on the Duet. And jumper 26 to 24 to test with (the only change is RDY=26)
                            RDY=26 CS=24 ; {
                            Edit: oh damn, pins in config.json are broadcom gpios, which means you need to enter 7 in config.json to use physical pin2 26. Just to rule out differences between versions of rPi run gpio readall | cut -b41-90 | grep "^| 26 " | cut -b35-38 to check that it outputs 7, or use whatever number it does output.
                              fractalengineer
                              damn I can't edit the previous post but I figured I messed up the mirroring of the pins on the ribbon; here's the actual result
                              RX should equal TX.
                              Railcore II ZL
                                ah, i got hung on the "interesting" part, which stayed the same so no worries.
                                Its the RDY or CS pin that should get focus for now.
                                  you can, but if jumpering it directly on the pi doesn't work, new wires isn't going to help.
                                  The pins are shown on the Duet3 wiring diagram, in the note. This does visualize it (I've only connected two of the 5 grounds, but it should suffice). Connect 1:1 from the Duet to the Pi taking care to correctly identifying pin 1.
                                    @bearer Ok so the next steps would be:
                                    1-Stopping DCS and rerunning the test
                                    2-Jump RDY (22) to 3.3v
                                    3-Change RDY pin
                                    4-Swap to the other Rpi
                                    5-Wire with all jumpers
                                    Am I correct?
                                    Those are pretty heavy operations I'll try to hang there but I hope I won't mess anything
                                    Here's 1-Stopping DCS and rerunning the test
                                    pi@duet3:~ $ sudo systemctl stop duetwebserver
                                    pi@duet3:~ $ sudo systemctl stop duetcontrolserver
                                    RX should equal TX.
                                    Railcore II ZL
                                      @fractalengineer
                                      Tbh, I'd start by just having jumpers on the other pi.
                                      Then I'd move the jumpers to jump RDY(26) to CS(24) and run the gpio test again, targeting the correct RDY pin. edit: actually run the gpio test before and after changing the jumper, ignoring the output the first time (to ensure the pin is in input mode before connecting it)
                                      If still no dice, then I'd wire RDY to 3.3v and run the gpio test again, targeting the correct RDY pin be it 22 or 26. (again run gpio test before making changes to ensure pin is input)
                                      If all of that fails then no point in the rest.
                                      If something succeeds then try with the duet and whatever combination of Pi and RDY pin gave the desired test result.
                                      Also note I edited the post about editing config.json to reflect which pin number to enter if you get to that point.
                                        @bearer thanks;
                                        Ok so here's my wiring;
                                        I wired both grounds and both +5v; is this about right?
                                        Railcore II ZL
                                          Yes, they're just double up to reduce voltage drop.
                                          It looks right as far as I can tell; but not easy to see if blue/purple was swapped on the way over. The rest I'm reasonable confident in.
                                          Although I'd be very surprised to see it working if the gpio test didn't indicate RDY and CS had the same readings on each line.
                                            Does the soldering of the 26-way connector look OK on the underside of the Duet?
