Duet 2.05 memory leak?
Firmware installation
9
132
6.8k
    kazolar
    @T3P3Tony ok -- so cura sliced code seemed a bit more sane than Prusa, but it didn't look good, but I let it run -- and it just failed -- underruns and stuttering.
    I optimized it for short paths to simplify it -- still...same result. Gonna clean the bed. Reset and kick of the S3D print -- that actually looks good and works after a reset (fingers crossed)
      kazolar
      @T3P3Tony @dc42
      Here is where I am at --
      1. I am running 2.05RC -- 2.05.1 is a lot less predictable -- it seems to work ok, then stops working and gets into stuttering underrun condition. I can't trust it from print to print, so I went back to 2.05RC -- it's at repeatable, and I can get shields out now without checking on it every 5 minutes.
      2. I can tell right away from m122 after the print starts, actually starts laying down plastic -- if I run M122 two times in 30 second intervals, if the 2nd time I get
        Slowest loop: 3.99ms; fastest: 0.08ms
        Then it will work through the end of the print -- I can tell that within 5 minutes now of starting the print before waiting the full 30 minutes to get underruns ans stuttering .
        If I get
        Slowest loop: 63.64ms; fastest: 0.07ms
        Then it will underrun by 30 minute mark.
      3. This is what works. I preheated the bed, nozzles -- clean everything off - press reset -- then start the S3D print -- and this works. The print will get slowest loop in 5ms range and will run through to conclusion - 5hrs 15 min give or take.
      4. This procedure works -- and has worked for the entire month I've been printing shields until I started messing around with 2.05.1. I don't have to copy the file over, I can keep using the same file.
      5. If I do anything prior to starting the print without pressing reset -- I will get the high slowest loop numbers and inevitable underrun.
      6. The behavior is absolutely repeatable with S3D or Cura prints (in terms of underrun condition). I am sure I can tune the Cura version to look better, and probably the Prusa version, both looked like trash on layer one to varying degrees -- but both were optimized to eliminate small movements, S3D doesn't have that feature, but this print doesn't have any -- or many.
      Question is -- is this hardware or software. I have done triplicate prints before without having to do the "three finger salute" before starting it -- so either something died in the hardware, David's documentation on underrruns talks about voltage regulators, etc. I have no indication that something is wrong there, but the only alteration from then and now, is I switched to optical end stops on XYUVWA axes - the others (for the bed -- are still mechanical). I also went from 32 teeth pulleys to 20 teeth. I have done a 40 hour long multi extrusion print with the current setup with no issues.
        kazolar
        Another update -- I did not power down -- did the exact some procedure -- I removed the shields -- set bed temp, set extruder temp (keep bed hot and set extruders to 150 so I can pull of any stuck on filament) -- then after alcohol wipe down of the build area, i pressed stop on LCD, the select the print -- it's working perfectly -- THE only way I can print in triplicate reliably is to do this process. I don't need to delete and reupload the file. No other tricks involved. If I try printing it again 50/50 chance it will spin up the loop time and will fail due to underruns. If I keep doing this process, I can keep doing a lot of shields with no interruption.
        There is a leak, or some missed clean up routine in this triplicate mode -- i have offsets specified such that my bed 0 left front -- I don't use 0,0 at center -- to convoluted on non-delta machines. So my offsets correspond with 0,0 at front left, triplication works perfectly fine -- mirror works fine -- so far as I can demonstrate, triplication in 2.05RC works only after a reset, and in 2.05.1 it works kinda better, but only that i can do more prints before a failure, and I can't predict when it will happen, so kinda not very helpful -- I am doing the shields while doing my day job -- so I can't be monitoring M122 results every few seconds -- it's not practical -- do the setup -- reset the firmware -- press print -- walk away -- that works, rinse repeat.
        undefined 1 Reply Last reply 24 Apr 2020, 14:10 Reply Quote 0
          Just to confirm: if you do a software reset of the Duet, for example using the Emergency Stop button or M999, it clears the problem sufficiently to do another print?
          If that's the case, please can you do the following next time:
          • Send M122 after powering up and resetting the printer
          • After the print has finished, send M122 again
          • Then send M21 and see whether that is sufficient to allow a new print to succeed. If the M21 command reports an error, send M22 and then M21.
          Post the M122 results here.
            droftarts administrators @kazolar
            @kazolar I had a thought. This only happens when you run the 3rd hot end, in triplication, and not in mirror/duplication. Is the 3rd hot end heater connected to the Duex? I wonder if something about the PWM on the 3rd heater is interfering with the SD card. One obvious candidate is that you have not tied the grounds from the Duet and Duex together; see https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
            Alternatively, there may be subtle differences between the firmwares that cause the PWM frequency to be different, or the signalling between the boards to shift, enough to cause a stutter in the command queue (as you have had the same problem streaming from Octoprint/USB). This is just a guess; I think the PWM code has been unchanged for a long time.
              kazolar
              @dc42 I'll run the test this weekend, Sunday most likely. I need to get as many shields made as possible today and tomorrow -- I have a pickup of 200 shields for a local hospital on Sunday morning.
              @droftarts I actually had some issues with i2c a while back, and David suggested to thicken up the grounding wire between duet and duex5 -- I got the thickest wire that could be possibly inserted into a ferrule and did that -- also David had added some code to reset i2c if it gets an issue -- but my m122 has not shown any i2c errors since I improved the grounding -- but trust me there is a very short 14awg silicone shielded wire crimped in ferrules that is connecting my 2 boards -- so my grounding between them is no longer an issue.
                kazolar
                @dc42 M21 and combined with M22 do not help, I just tried it after I replaced the 4 Z stepper connectors, recall a while back I had an issue with the included stepper connectors getting singed, you suggest molex, and I had those in place for well over a year with no singing until today -- this time the singing was very bad melting the housing. I ended up taking duex5 out and I soldered wires with heavy duty JS style connectors in the place of the Z stepper connectors (I have 4 lead screws -- upon further inspection 2 had developed some singe marks.
                I didn't save M122 -- I will make sure to save it on Sunday, I hope not to be dealing with unrelated electrical issues. What was telling that even with M21 being run, the loop times were high -- max loop times until stuttering started were 50-70ms. None were lower than 12ms -- I check M122 every minute or so. When stuttering started I canceled the print -- kept the bed at temperature, cleared everything, then I reset the board -- just M999 (or stop button in this case) -- then I started the same print -- it's running now -- all loop times are 5ms and lower.
                  kazolar
                  here is the M122 right before it starts failing
                  M122
                  What's interesting -- which makes this look more like a hardware issue is that the first print after the machine has been off for a couple of hours fails. High loop times -- then underruns. Then prints done afterwards work. I did not do anything different than preheat -- reset, hit print -- first print fails the same fashion
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet Ethernet 1.02 or later + DueX5
                  Board ID: 08DGM-9T6BU-FG3S0-7JTD4-3S06K-1A4ZD
                  Used output buffers: 1 of 24 (21 max)
                  Static ram: 25708
                  Dynamic ram: 96332 of which 0 recycled
                  Exception stack ram used: 472
                  Never used ram: 8560
                  Tasks: NETWORK(ready,616) HEAT(blocked,1144) DUEX(blocked,164) MAIN(running,1668) IDLE(ready,156)
                  Owned mutexes: I2C(DUEX)
                  Last reset 00:20:52 ago, cause: software
                  Last software reset at 2020-04-25 11:06, reason: User, spinning module GCodes, available RAM 8504 bytes (slot 1)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                  Error status: 0
                  Free file entries: 9
                  MCU temperature: min 25.6, current 26.0, max 26.2
                  Supply voltage: min 24.1, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: ok, SG min/max 0/313
                  Driver 2: standstill, SG min/max 0/252
                  Driver 3: ok, SG min/max 0/305
                  Driver 4: ok, SG min/max 0/332
                  Driver 5: standstill, SG min/max not available
                  Driver 6: standstill, SG min/max 64/229
                  Driver 7: standstill, SG min/max 144/295
                  Driver 8: standstill, SG min/max 88/251
                  Driver 9: standstill, SG min/max 41/218
                  Date/time: 2020-04-25 11:27:19
                  Cache data hit count 2554842663
                  Slowest loop: 47.93ms; fastest: 0.08ms
                  Hiccups: 0, FreeDm: 154, MinFreeDm: 8, MaxWait: 0ms
                  === DDARing ===
                  Scheduled moves: 8715, completed moves: 8675, StepErrors: 0, LaErrors: 0, Underruns: 6, 0
                  Heater 0 is on, I-accum = 1.0
                  Heater 1 is on, I-accum = 0.6
                  Heater 2 is on, I-accum = 0.7
                  Heater 4 is on, I-accum = 0.5
                  Segments left: 1
                  Movement lock held by null
                  http is idle in state(s) 0
                  telnet is idle in state(s) 0
                  file is doing "G1 X228.135 Y232.279 E1.2574" in state(s) 0
                  serial is idle in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 7.26ms; fastest: 0.06ms
                  HTTP sessions: 2 of 8
                  Interface state 5, link 100Mbps full duplex
                    Is there any metalwork (e.g. printer enclosure) close to the SD card socket? If so, is that metalwork connected to Duet ground, either directly or through a resistor? I'm wondering whether static buildup might be a factor.
                      kazolar
                      @dc42 nope, printer is in a plastic enclosure -- no metal parts touch the network jack
                      Here is the actual failure:
                      12:22:43 PMM122
                      Used output buffers: 1 of 24 (22 max)
                      Static ram: 25708
                      Exception stack ram used: 448
                      Never used ram: 8584
                      Tasks: NETWORK(ready,616) HEAT(blocked,1144) DUEX(suspended,164) MAIN(running,1668) IDLE(ready,156)
                      Owned mutexes:
                      Last reset 00:37:46 ago, cause: software
                      Last software reset at 2020-04-25 11:44, reason: User, spinning module GCodes, available RAM 8748 bytes (slot 0)
                      Error status: 0
                      MCU temperature: min 25.9, current 26.2, max 26.6
                      Supply voltage: min 24.1, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: ok, SG min/max 0/333
                      Driver 2: ok, SG min/max 0/1023
                      Driver 3: ok, SG min/max 0/721
                      Driver 6: standstill, SG min/max 26/241
                      Driver 7: standstill, SG min/max 135/297
                      Driver 8: standstill, SG min/max 71/249
                      Driver 9: standstill, SG min/max 29/222
                      Date/time: 2020-04-25 12:22:39
                      Slowest loop: 151.20ms; fastest: 0.08ms
                      Hiccups: 0, FreeDm: 120, MinFreeDm: 6, MaxWait: 0ms
                      === DDARing ===
                      Scheduled moves: 26743, completed moves: 26706, StepErrors: 0, LaErrors: 0, Underruns: 69, 78
                      Heater 2 is on, I-accum = 0.6
                      Segments left: 0
                      file is idle in state(s) 0
                      === Network ===
                      Slowest loop: 77.03ms; fastest: 0.06ms
                      HTTP sessions: 1 of 8
                      undefined undefined 2 Replies Last reply 25 Apr 2020, 16:43 Reply Quote 0
                        dc42 administrators @kazolar
                        @kazolar said in Duet 2.05 memory leak?:
                        Do you mean after you have just had the SD card read error?
                          kazolar
                          @dc42 here is the observable behavior -- happened 3 times in a row.
                          First print -- high loop times, inevitable failure due to underrun -- I tried to cancel it, looked like it would fail about 15 minutes in, but the next print failed. So basically 30-40 is required.
                          Next print running now
                          Is going to be fine -- loop times are great:
                          M122
                          Used output buffers: 3 of 24 (21 max)
                          Static ram: 25708
                          Exception stack ram used: 464
                          Never used ram: 8568
                          Tasks: NETWORK(ready,748) HEAT(blocked,1236) DUEX(suspended,168) MAIN(running,1668) IDLE(ready,156)
                          Owned mutexes:
                          Last reset 00:14:25 ago, cause: software
                          Last software reset at 2020-04-25 12:28, reason: User, spinning module GCodes, available RAM 8584 bytes (slot 1)
                          Error status: 0
                          MCU temperature: min 25.9, current 26.3, max 26.5
                          Driver 0: ok, SG min/max 0/319
                          Driver 2: ok, SG min/max 0/242
                          Driver 3: ok, SG min/max 0/290
                          Driver 4: ok, SG min/max 0/301
                          Driver 6: standstill, SG min/max 59/235
                          Driver 7: standstill, SG min/max 151/286
                          Driver 8: standstill, SG min/max 82/248
                          Driver 9: standstill, SG min/max 47/214
                          Date/time: 2020-04-25 12:43:13
                          Cache data hit count 1720212453
                          Slowest loop: 4.75ms; fastest: 0.08ms
                          Hiccups: 0, FreeDm: 152, MinFreeDm: 56, MaxWait: 0ms
                          === DDARing ===
                          Scheduled moves: 4720, completed moves: 4708, StepErrors: 0, LaErrors: 0, Underruns: 3, 0
                          Heater 1 is on, I-accum = 0.4
                          Heater 2 is on, I-accum = 0.5
                          Heater 4 is on, I-accum = 0.4
                          Segments left: 1
                          file is doing "G1 X110.719 Y48.457 E36.9405" in state(s) 0
                          === Network ===
                          Slowest loop: 10.72ms; fastest: 0.06ms
                            kazolar @kazolar
                            @dc42 stuttering -- failure of print -- just had it, yes. I reset and started again -- working fine now
                              kazolar
                              @dc42 i think we're going around in circles -- 2.5.1 likely would fix the software issue, but there is clearly a hardware fault -- i HAVE to let it run for 30+ minutes and fail before reset and start a series of prints that will succeed. That 30 minutes time frame -- maybe the time that the cold solder joint -- somewhere heats up things start running fine. This board was purchased on Aug 3 2018 -- Filastruder order #36936
                              It's either covered by warranty or it's not. If not I'll order a new one from filastruder.
                              I said that I was ready to go ahead and do this -- I was asked to slice this in different slicers and try different SD cards -- I have. I am printing face shields for hospital workers. I have a donation of 200 being picked to go to a local hospital tomorrow. I'd rather lose more sleep and waste time troubleshooting what at this point feels like a bad solder joint -- is it worth my time to take the board out look at under a scope and look for it -- it could be on the sd card connector -- another trace. I resolves itself after 30 minutes of printing. The question is at this point how is the replacement being handled.
                                kazolar
                                @dc42 what makes you think it's an SD card error still? I had the same underrun error reproduced with Ocotprint. I am using a branded SD card which tests out at the top of speed spectrums. The predictable behavior now is that after the machine has been either idle or off for some time, it takes 1 failed print due to an underrun --which happens around 30-40min (not same spot each time anymore) and then after a reset the next set of prints if I don't let it cool down work fine --so as some suggested a cold solder joint which ends up warming up and working fine after some heat up time is the culprit here. I'm going to wait for a response as to how to proceed -- If I don't get one -- I'll order a new duet 2 from filastruder.
                                @droftarts Considering the importance of these prints, and my past experience here, I rather disappointed and surprised with the level of support. YouTubers who do questionable videos (I can name some -- who I used to watch) get free boards sent to them, I guess I don't have that kind of a public image -- I will be releasing the build vlog of this printer, which has been long overdue as I've filmed it starting 3 years ago. The last few episodes will feature my experience with using this machine to print these shields. I am donating countless hours of my time, our group is getting daily requests from local hospitals -- and even those further away for ear relievers. I am kinda getting burn out mostly due the issues with the duet board. I was dealing with these behaviors initially -- and was willing to keep troubleshooting this. Now we're at a crossroads. I have played the -- do this, do that steps, which would be fine if we weren't in time crunch in a pandemic and every shield I produce is another doctor/nurse, EMT worker who won't get sick. I don't quite understand the lack of urgency here, or maybe you're not taking this seriously enough -- I had first hand accounts of doctors dying in New York, and young nurses succumbing to the illness in the Bronx.
                                botundefined undefined 2 Replies Last reply 25 Apr 2020, 19:36 Reply Quote 0
                                • botundefined
                                  bot @kazolar
                                  As for your first question directed at dc42: octoprint sometimes waits for an OK response from the firmware, and maybe for other reasons, the stuttering might occur on any setup. It doesn't rule out the SD card being a problem.
                                  *not actually a robot
                                  undefined 1 Reply Last reply 25 Apr 2020, 19:39 Reply Quote 0
                                    kazolar @bot
                                    @bot
                                    So yes, an SD card problem may be there, which is likely a hardware issue since after 30-40 minutes of a failed print, the next print is fine. In fact the next 3-4 prints are fine, provided I don't let the board/system cool off
                                    botundefined 1 Reply Last reply 25 Apr 2020, 19:42 Reply Quote 0
                                    • botundefined
                                      bot @kazolar
                                      I'm just watching this thread with interest, but have no idea or opinion about why it may be occurring. I was just pointing out the reasoning that octoprint didn't rule out a faulty sd card.
                                      undefined 1 Reply Last reply 25 Apr 2020, 19:43 Reply Quote 0
                                        kazolar @bot
                                        @bot I am using a brand new SanDisk 32 gb card. I have used 4 different cards. Are they all faulty?
                                        And the fault magically clears after 40 minutes. And works fine for the next 15 hours...hell I had a night when I caught it in the morning right after it finished a print and was able to run another with no issues. Start cold and the SD card has a fault in it ... I'm software engineer and this makes no sense to me.
                                          This thread is long, so it's hard to find your post in which you mentioned Octoprint (the browser search facility doesn't find it). I recall that you said you had experienced underruns with Octoprint, but AFAIR you didn't say you had experienced the same pattern of underruns i.e. the first print working and subsequent prints not. I replied that underruns when using Octoprint/USB were common on all electronics.
                                          40 minutes of what? The machine standing idle, or something else?
                                          undefined 2 Replies Last reply 25 Apr 2020, 19:50 Reply Quote 0
                                          114 out of 132
