    DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1
    Beta Firmware
    12
    132
    7.3k
      A Former User @Garfield
      @Garfield said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
      @bearer - sorry I had already erased
      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Trying to do this via the Pi first off - the Duet is too far from the PC (or my USB cables are too short 😉 - depends how you look at it)
      you should see something like
      Bus 001 Device 008: ID 03eb:6124 Atmel Corp. at91sam SAMBA bootloader when the usb connection is okay - bad cable? bad board?
      Garfieldundefined 1 Reply Last reply Reply Quote 0
      • ChrisPundefined
        ChrisP @A Former User
        @bearer said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
        @ChrisP said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
        Perhaps in the first instance it'd be good to have some sort of command line UI for the Pi to automate switching versions quickly and easily - something along the lines of the rasp-config interface? I
        I think the solution is to get to the point where people who just need it to work can stay with the 3.1 stable version and for the learning curve on the unstable version to just be par for the course.
        Sadly people who would have liked to stay on the 3.0 stable relase have been pushed onto the rollercoaster leading up to 3.1 due to issues with 3.0.
        Yeh, to be fair, that's very true. When I decided to go down the unstable release route, I knew what I was possibly getting myself if for and I have no problem with re-imaging fresh raspbian images to start fresh if it comes to it. There's often more to it that simply "trying the latest RC", and I wonder whether it's obvious enough that most people should really stick to stable releases. That said, it needs enough people to test the RCs in different setups to find the bugs.
        • Garfieldundefined
          Garfield @A Former User
          No USB cable connected - doing this via the Pi initially ... all the steps went fine except the flashing - which is when the error popped up
          • bad board - I sure hope not, if firmware changes or code behaviour can bork a board that's bad - code should not be able to kill hardware (yes I know there are codes used by the nefarious types - but even those are bug exploits really).
          For what it is worth my diagnostic LED has been flashing continuously from the day I got the board - it no longer does. All power reports normal, LED power indications normal.
          ChrisPundefined 1 Reply Last reply Reply Quote 0
          • ChrisPundefined
            ChrisP @Garfield
            Using BOSSA requires connection from the host computer to the Duet via USB irrespective of whether its a PC or RPi.... if that's what you meant?
            • Garfieldundefined
              Garfield
              You're kidding - why ?
              Why would I execute something on the command line of a Pi if I connected a PC anyway - I could just run BOSSA on the PC and be done ....
              Not logical ... and damn dangerous ... I'm not happy connecting a USB and 24V pwr with the problems I've seen reported with grounding.
              Have never agreed with earth bonding of USB shells / screens but I'm not going to debate why it is a fundamentally bad idea in this thread.
              A Former User? ChrisPundefined 2 Replies Last reply Reply Quote 0
                this is why I prefer to use usb form the pi, which is supplied from the duet. they all share a common ground and common supply to start with so odds of a ground loop should be as low as they get unless something is really wrong with the wiring (in which case the pi probably wouldn't work in the first place)
                and i'll always be a sucker for a bash shell etc:)
                and yes, bossa will only work with a usb cable, regardless of pi or computer.
                • ChrisPundefined
                  ChrisP @Garfield
                  Not logical ...
                  Because BOSSA is a separate program made by others specifically for managing the flash on microcontroller such as the one on the Duets.
                  Your comment about why would you use command line if you could use the PC is precisely my comment above. Though as @bearer suggested, to some extent it comes down to what's easier for you in terms of what's available and what you're comfortable doing. While I'm not an expert on Linux, I'm comfortable with using command line, but I imagine most users would be more comfortable using a gui on a PC.
                  Anyway, if you don't have a flashing diag LED, I believe you option is only BOSSA and for that you'll need a USB cable and a PC/Pi platform of your choice. Tbh, since you've got this far, the quickest way is likely to be just running the command @bearer posted 🙂
                  (I think we've also drifted off topic too. Oops)
                  • Garfieldundefined
                    Garfield
                    OK - instruction really needs to be a little clearer.
                    If I read this correctly you can't do this using the 'ribbon' cable but must switch the RPi to connect to a USB port, this means I can leave 24 DC into the Duet and feed the Pi via the USB. Might be worth clarifying that the Ribbon should or should not be disconnected
                    A:
                    Use a data capable USB cable from any port on the Pi to the Duet.
                    Power the Duet from the RPi USB (the Pi must have its own power supply)
                    OR
                    B:
                    Power the Duet with VIN
                    RPi powered and connected via USB
                    Do one or the other; do not power both ways. I'd say that B is the preferred option unless you;re going to lift the common off VIN or you are sure that your PSU common is earth isolated
                    • ChrisPundefined
                      ChrisP
                      Yup, you shouldn't have to change your power arrangements - you don't have to unplug the ribbon cable. I assume you're powering the Pi from the D3 currently?
                      • Garfieldundefined
                        Garfield
                        I am indeed powering the Pi from the D3.
                        I don't think that were so far off topic if my disaster helps others who may encounter similar 'fatal' crashes.
                        • Garfieldundefined
                          Garfield
                          @bearer : 10 out of 10
                          This command needs to go in doczuki !!
                          wget https://pastebin.com/raw/Wa1kYf3G -O - | tr -d "\r" | bash
                          back up and to the point I was at before - can't stay connected, continuous connect / disconnect
                          • Garfieldundefined
                            Garfield
                            pr 27 11:15:05 duet3 DuetControlServer[3136]: [info] Application has shut down
                            Apr 27 11:15:05 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                            Apr 27 11:15:10 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
                            Apr 27 11:15:10 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 57.
                            Apr 27 11:15:10 duet3 systemd[1]: Stopped Duet Control Server.
                            Apr 27 11:15:10 duet3 systemd[1]: Started Duet Control Server.
                            Apr 27 11:15:11 duet3 DuetControlServer[3175]: Duet Control Server v2.1.1
                            Apr 27 11:15:11 duet3 DuetControlServer[3175]: Written by Christian Hammacher for Duet3D
                            Apr 27 11:15:11 duet3 DuetControlServer[3175]: Licensed under the terms of the GNU Public License Version 3
                            Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] Settings loaded
                            Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] Environment initialized
                            Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] Connection to Duet established
                            Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] IPC socket created at /var/run/dsf/dcs.sock
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]: [fatal] Abnormal program termination
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]: [fatal] Update task faulted
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    System.ArgumentException: Property set method not found.
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture)
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, Object[] index)
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at System.Reflection.PropertyInfo.SetValue(Object obj, Object value)
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 237
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.FilamentMonitor.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Sensors/FilamentMonitors/FilamentMon
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 209
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Bas
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 149
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 182
                            Apr 27 11:15:12 duet3 DuetControlServer[3175]: [info] Application has shut down
                            Apr 27 11:15:12 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                            SSH connections are stable though ...
                              @Garfield it needs to evolve a little, but it has a sibling that will identify and flash any duet 2 wifi/ethernet/maestro or duet 3 with the correct firmware in any state as long as usb is working. that might be proposed for the doczuki/wiki when polished.
                              anyways, glad you found it helpful in the end, the goal is in the end to take the guesswork out of the flashing when necessary.
                              • Garfieldundefined
                                Garfield
                                spoke too soon - ssh eventually dies .... so we are back on topic - same issue as we started with ...
                                • ChrisPundefined
                                  ChrisP @Garfield
                                  Excellent... ish 😕
                                  Is the log you posted above what you see when DCS crashes? I still haven't managed to get anything interesting in the logs.
                                  • Garfieldundefined
                                    Garfield
                                    Yup - thats the crash log ...
                                    • Danalundefined
                                      Danal
                                      I'm the one that leans toward bossa from the Pi. However, I'm just an end-user that's trying to dig another end user out of a hole. If someone else, prefers windows, great!
                                      I prefer the Pi for two reasons:
                                      1. It does avoid ground loops, to a somewhat greater extent than a separate computer.
                                      2. Windows bossa works quite a bit of the time... and other times, windows gets really weird about USB ports.
                                      Again, I'm just making suggestions, if someone prefers one tool over another, fantastic, use that!
                                      • gtj0undefined
                                        gtj0
                                        @Garfield @ChrisP Have you tried my suggestion above to remove the two CPUScheduling lines from /lib/systemd/system/duetcontrolserver.service and rebooting?
                                        • Danalundefined
                                          Danal
                                          Data point: I have not changed the CPU scheduling and I am now about 14 hours into a print, with no issues.
                                          Running DuetLapse on the same Pi. (Which I was not doing the other day).
                                          I don't know what changed, if anything, from the point where I couldn't get it to run for 15 minutes at a time.
                                          gtj0undefined Danalundefined 2 Replies Last reply Reply Quote 0
                                          • Garfieldundefined
                                            Garfield
                                            I've not tried the scheduling - can't get DCS to start and stay running, first time it came up and was fine - until I threw my .g files at it and then BOOM ....
                                            I need to get the whole thing back to RC6 and stable but right now it is all turned off (day job - that and run out of patience for now).
                                            Could really do with that 'version compatibility' matrix ....
                                            gtj0undefined A Former User? Danalundefined 4 Replies Last reply Reply Quote 0
