    DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1
    Beta Firmware
    12
    132
    7.3k
    • ChrisPundefined
      ChrisP @Garfield
      @Garfield said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
      @bearer said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
      bad cable? bad board?
      No USB cable connected - doing this via the Pi initially ... all the steps went fine except the flashing - which is when the error popped up
      Using BOSSA requires connection from the host computer to the Duet via USB irrespective of whether its a PC or RPi.... if that's what you meant?
      • Garfieldundefined
        Garfield
        You're kidding - why ?
        Why would I execute something on the command line of a Pi if I connected a PC anyway - I could just run BOSSA on the PC and be done ....
        Not logical ... and damn dangerous ... I'm not happy connecting a USB and 24V pwr with the problems I've seen reported with grounding.
        Have never agreed with earth bonding of USB shells / screens but I'm not going to debate why it is a fundamentally bad idea in this thread.
        A Former User? ChrisPundefined 2 Replies Last reply Reply Quote 0
          A Former User @Garfield
          this is why I prefer to use usb form the pi, which is supplied from the duet. they all share a common ground and common supply to start with so odds of a ground loop should be as low as they get unless something is really wrong with the wiring (in which case the pi probably wouldn't work in the first place)
          and i'll always be a sucker for a bash shell etc:)
          and yes, bossa will only work with a usb cable, regardless of pi or computer.
          • ChrisPundefined
            ChrisP @Garfield
            Not logical ...
            Because BOSSA is a separate program made by others specifically for managing the flash on microcontroller such as the one on the Duets.
            Your comment about why would you use command line if you could use the PC is precisely my comment above. Though as @bearer suggested, to some extent it comes down to what's easier for you in terms of what's available and what you're comfortable doing. While I'm not an expert on Linux, I'm comfortable with using command line, but I imagine most users would be more comfortable using a gui on a PC.
            Anyway, if you don't have a flashing diag LED, I believe you option is only BOSSA and for that you'll need a USB cable and a PC/Pi platform of your choice. Tbh, since you've got this far, the quickest way is likely to be just running the command @bearer posted 🙂
            (I think we've also drifted off topic too. Oops)
            • Garfieldundefined
              Garfield
              OK - instruction really needs to be a little clearer.
              If I read this correctly you can't do this using the 'ribbon' cable but must switch the RPi to connect to a USB port, this means I can leave 24 DC into the Duet and feed the Pi via the USB. Might be worth clarifying that the Ribbon should or should not be disconnected
              A:
              Use a data capable USB cable from any port on the Pi to the Duet.
              Power the Duet from the RPi USB (the Pi must have its own power supply)
              OR
              B:
              Power the Duet with VIN
              RPi powered and connected via USB
              Do one or the other; do not power both ways. I'd say that B is the preferred option unless you;re going to lift the common off VIN or you are sure that your PSU common is earth isolated
              • ChrisPundefined
                ChrisP
                Yup, you shouldn't have to change your power arrangements - you don't have to unplug the ribbon cable. I assume you're powering the Pi from the D3 currently?
                • Garfieldundefined
                  Garfield
                  I am indeed powering the Pi from the D3.
                  I don't think that were so far off topic if my disaster helps others who may encounter similar 'fatal' crashes.
                  • Garfieldundefined
                    Garfield
                    @bearer : 10 out of 10
                    This command needs to go in doczuki !!
                    wget https://pastebin.com/raw/Wa1kYf3G -O - | tr -d "\r" | bash
                    back up and to the point I was at before - can't stay connected, continuous connect / disconnect
                    • Garfieldundefined
                      Garfield
                      pr 27 11:15:05 duet3 DuetControlServer[3136]: [info] Application has shut down
                      Apr 27 11:15:05 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                      Apr 27 11:15:10 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
                      Apr 27 11:15:10 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 57.
                      Apr 27 11:15:10 duet3 systemd[1]: Stopped Duet Control Server.
                      Apr 27 11:15:10 duet3 systemd[1]: Started Duet Control Server.
                      Apr 27 11:15:11 duet3 DuetControlServer[3175]: Duet Control Server v2.1.1
                      Apr 27 11:15:11 duet3 DuetControlServer[3175]: Written by Christian Hammacher for Duet3D
                      Apr 27 11:15:11 duet3 DuetControlServer[3175]: Licensed under the terms of the GNU Public License Version 3
                      Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] Settings loaded
                      Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] Environment initialized
                      Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] Connection to Duet established
                      Apr 27 11:15:11 duet3 DuetControlServer[3175]: [info] IPC socket created at /var/run/dsf/dcs.sock
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]: [fatal] Abnormal program termination
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]: [fatal] Update task faulted
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    System.ArgumentException: Property set method not found.
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture)
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, Object[] index)
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at System.Reflection.PropertyInfo.SetValue(Object obj, Object value)
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 237
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.FilamentMonitor.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Sensors/FilamentMonitors/FilamentMon
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 209
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Bas
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 149
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]:    at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 182
                      Apr 27 11:15:12 duet3 DuetControlServer[3175]: [info] Application has shut down
                      Apr 27 11:15:12 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                      SSH connections are stable though ...
                        @Garfield it needs to evolve a little, but it has a sibling that will identify and flash any duet 2 wifi/ethernet/maestro or duet 3 with the correct firmware in any state as long as usb is working. that might be proposed for the doczuki/wiki when polished.
                        anyways, glad you found it helpful in the end, the goal is in the end to take the guesswork out of the flashing when necessary.
                        • Garfieldundefined
                          Garfield
                          spoke too soon - ssh eventually dies .... so we are back on topic - same issue as we started with ...
                          ChrisPundefined 1 Reply Last reply Reply Quote 0
                          • ChrisPundefined
                            ChrisP @Garfield
                            Excellent... ish 😕
                            Is the log you posted above what you see when DCS crashes? I still haven't managed to get anything interesting in the logs.
                            • Garfieldundefined
                              Garfield
                              Yup - thats the crash log ...
                              • Danalundefined
                                Danal
                                I'm the one that leans toward bossa from the Pi. However, I'm just an end-user that's trying to dig another end user out of a hole. If someone else, prefers windows, great!
                                I prefer the Pi for two reasons:
                                1. It does avoid ground loops, to a somewhat greater extent than a separate computer.
                                2. Windows bossa works quite a bit of the time... and other times, windows gets really weird about USB ports.
                                Again, I'm just making suggestions, if someone prefers one tool over another, fantastic, use that!
                                • gtj0undefined
                                  gtj0
                                  @Garfield @ChrisP Have you tried my suggestion above to remove the two CPUScheduling lines from /lib/systemd/system/duetcontrolserver.service and rebooting?
                                  • Danalundefined
                                    Danal
                                    Data point: I have not changed the CPU scheduling and I am now about 14 hours into a print, with no issues.
                                    Running DuetLapse on the same Pi. (Which I was not doing the other day).
                                    I don't know what changed, if anything, from the point where I couldn't get it to run for 15 minutes at a time.
                                    gtj0undefined Danalundefined 2 Replies Last reply Reply Quote 0
                                    • Garfieldundefined
                                      Garfield
                                      I've not tried the scheduling - can't get DCS to start and stay running, first time it came up and was fine - until I threw my .g files at it and then BOOM ....
                                      I need to get the whole thing back to RC6 and stable but right now it is all turned off (day job - that and run out of patience for now).
                                      Could really do with that 'version compatibility' matrix ....
                                      gtj0undefined A Former User? Danalundefined 4 Replies Last reply Reply Quote 0
                                      • gtj0undefined
                                        gtj0 @Danal
                                        @Danal When your print is done it's be helpful if you could test without DuetLapse and see if you can reproduce the issue, then try removing the CPUScheduling lines.
                                        • gtj0undefined
                                          gtj0 @Garfield
                                          @Garfield Understood. If you do get a chance, try removing those 2 lines.
                                            back to RC6
                                            RRF3.01-RC10     duetsoftwareframework 2.1.1      reprapfirmware 2.1.1-1
                                            RRF3.01-RC9      duetsoftwareframework 2.1.0      reprapfirmware 2.1.0-1
                                            RRF3.01-RC8      duetsoftwareframework 2.0.0      reprapfirmware 2.0.0-1
                                            RRF3.01-RC7      duetsoftwareframework 1.3.2      reprapfirmware 1.3.2-1
                                            RRF3.01-RC6      duetsoftwareframework 1.3.1      reprapfirmware 1.3.1-1
                                            RRF3.01-RC6      duetsoftwareframework 1.3.0      reprapfirmware 1.3.0-1
                                            RRF3.01-RC4      duetsoftwareframework 1.2.5.0    reprapfirmware 1.2.5.0-1
                                            RRF3.0           duetsoftwareframework 1.2.4.0    reprapfirmware 1.2.4.0-1
                                            RRF3.0           duetsoftwareframework 1.2.3.1    reprapfirmware 1.2.3.1-1
                                            RRF3.0           duetsoftwareframework 1.2.3.0    reprapfirmware 1.2.3.0-1
                                            RRF3.0           duetsoftwareframework 1.2.2.1    reprapfirmware 1.2.2.1-1
                                            RRF3.0RC2+1      duetsoftwareframework 1.2.2.0    reprapfirmware 1.2.2.0-1
                                            RRF3.0RC1        duetsoftwareframework 1.2.1.0    reprapfirmware 1.2.1.0-1
                                            RRF3.0RC1        duetsoftwareframework 1.2.0.0    reprapfirmware 1.2.0.0-1
                                            RRF3.0beta11     duetsoftwareframework 1.1.0.5    reprapfirmware 1.1.0.5-1
                                            RRF3.0beta11     duetsoftwareframework 1.1.0.4    reprapfirmware 1.1.0.4-1
                                            RRF3.0beta10+2   duetsoftwareframework 1.1.0.3    reprapfirmware 1.1.0.3-1
                                            RRF3.0beta10+2   duetsoftwareframework 1.1.0.2    reprapfirmware 1.1.0.2-1
                                            RRF3.0beta10+2   duetsoftwareframework 1.1.0.1    reprapfirmware 1.1.0.1-1
                                            RRF3.0beta10+2   duetsoftwareframework 1.1.0.0    reprapfirmware 1.1.0.0-1
                                            RRF3.0beta10+1   duetsoftwareframework 1.0.4.1    reprapfirmware 1.0.4.1-1
                                            depcheck()
                                              local NODE=$1
                                              local VER=$2
                                              local pattern="\ ([a-z]*)\ \([0-9]+\ ([0-9\.]+-?[0-9]{0,2})\)"
                                              local IFS=$'\n'
                                              s=$(apt-cache showpkg $NODE |  grep "^$VER - ." )
                                              for package in $(echo $s | grep -Eo  $pattern)
                                              do
                                                [[ $package =~ $pattern ]]
                                                [ "${BASH_REMATCH[1]}" == "${BASH_REMATCH[2]}" ] || echo -en "  ${BASH_REMATCH[1]}=${BASH_REMATCH[2]} $EOL"
                                                [ "${BASH_REMATCH[1]}" == "duetcontrolserver" ] && depcheck ${BASH_REMATCH[1]} ${BASH_REMATCH[2]}
                                              done
                                            [ $# -gt 0 ] && {
                                            V=$1
                                            PARENT=duetsoftwareframework
                                            [ $# -gt 1 ] && PARENT=$2
                                            EOL=""
                                            [ -t 1 ] && EOL="\\ \n"
                                            echo  -en "sudo apt install $EOL"
                                            depcheck $PARENT $V
                                            [ -t 1 ] && EOL="\n"
                                            echo  -en "  $PARENT=$V $EOL"
                                            } ||  echo $0 version ;
                                            save as dsfdep.sh and run like bash dsfdep.sh 1.3.1 to restore to 3.01-RC6
                                            copy and paste the suggest command and hope for the best (or put in backticks if braver than most)
                                            pi@raspberrypi:~ $ bash dsfdep.sh 1.3.1
                                            sudo apt install \
                                              duetcontrolserver=1.3.1 \
                                              duetruntime=1.3.1 \
                                              duetsd=1.0.6 \
                                              duettools=1.3.1 \
                                              duetwebserver=1.3.1 \
                                              duetwebcontrol=2.1.1 \
                                              reprapfirmware=1.3.1-1 \
                                              duetsoftwareframework=1.3.1
