    New Tool: Duet V3.xx RCx to apt DSF 2.x.x version mapping
    Third-party add-ons
    • Danalundefined
      Danal
      Two tools here: https://github.com/DanalEstes/DuetVersions
      Installation instructions on the readme at that link.
      Written in 'shell' and they are probably quite sensitive to EXACT formatting of command results and will therefore break at some point. For now, they provide what I want in mapping releases.
      MAY add a utility that will show the exact command require to regress. Maybe.
      Until then, these two may be handy:
      ./DuetVersion.sh
        Highest Available DuetSoftwareFramework = 2.1.1
      Currently Installed DuetSoftwareFramework = 2.1.1
      Dependencies for DSF version 2.1.1 are:
       duetcontrolserver (= 2.1.1)
       duetsd (= 1.0.6)
       duettools (= 2.1.1)
       duetwebserver (= 2.1.0)
       duetwebcontrol (= 2.1.5)
       reprapfirmware (>= 2.1.1-1)
       reprapfirmware (<= 2.1.1-999) )
      reprapfirmware apt version 2.1.1-1 is internal version 3.01-RC10
      If you specify a number as command line argument, you are asking for that same information on the release that many 'backwards' from the most current.
      ./DuetVersion.sh 15
      Command line arg specified to request Release -15 from highest available.
            Highest-15 is DuetSoftwareFramework = 1.2.0.0
      Dependencies for DSF version 1.2.0.0 are:
       duetcontrolserver (= 1.2.0.0)
       duetsd (= 1.0.5)
       duettools (= 1.2.0.0)
       duetwebserver (= 1.2.0.0)
       duetwebcontrol (= 2.0.4-1)
       reprapfirmware (>= 1.2.0.0-1)
       reprapfirmware (<= 1.2.0.0-999) )
      reprapfirmware apt version 1.2.0.0-1 is internal version 3.0RC1
      And... so we don't have to poke through -1, -2, -3, etc, a consolidated list of the DSF to RRF releases:
       ./DuetVersionsAll.sh
      Expect this to take several seconds per line of output.
      duetsoftwareframework 2.1.1 contains reprapfirmware version 2.1.1-1 which is internal version 3.01-RC10
      duetsoftwareframework 2.1.0 contains reprapfirmware version 2.1.0-1 which is internal version 3.01-RC9
      duetsoftwareframework 2.0.0 contains reprapfirmware version 2.0.0-1 which is internal version 3.01-RC8
      duetsoftwareframework 1.3.2 contains reprapfirmware version 1.3.2-1 which is internal version 3.01-RC7
      duetsoftwareframework 1.3.1 contains reprapfirmware version 1.3.1-1 which is internal version 3.01-RC6
      duetsoftwareframework 1.3.0 contains reprapfirmware version 1.3.0-1 which is internal version 3.01-RC6
      duetsoftwareframework 1.2.5.0 contains reprapfirmware version 1.2.5.0-1 which is internal version 3.01-RC4
      ...snip...
      1 Reply Last reply Reply Quote 5
      • Luke'sLaboratoryundefined
        Luke'sLaboratory
        THANK - YOU.
        Luke
        http://lukeslab.online
        • Danalundefined
          Danal
          Found out an interesting thing about my own tool. 'apt update' is necessary for it to 'see' anything added to the package server since the prior 'apt update'. Note line 26 below.
          Makes perfect sense!
          ^C
          pi@duet3:~/DuetVersions $ sudo apt update
          Get:1 http://archive.raspberrypi.org/debian buster InRelease [25.1 kB]
          Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
          Get:3 https://pkg.duet3d.com unstable InRelease [2,565 B]
          Hit:4 https://pkg.duet3d.com stable InRelease
          Get:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
          Get:6 http://archive.raspberrypi.org/debian buster/main armhf Packages [327 kB]
          Get:7 https://pkg.duet3d.com unstable/armv7 armhf Packages [31.9 kB]
          Ign:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
          Get:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [18.3 MB]
          Fetched 18.7 MB in 1min 32s (204 kB/s)
          Reading package lists... Done
          Building dependency tree
          Reading state information... Done
          8 packages can be upgraded. Run 'apt list --upgradable' to see them.
          pi@duet3:~/DuetVersions $ ./DuetVersionsAll.sh
          duetsoftwareframework 2.1.2 contains reprapfirmware version 2.1.2-1 which is internal version 3.01-RC10
          • Danalundefined
            Danal
            Also found out that my "look backward" index is off. See lower block. Argument of 2 gets latest and 0 or 1 blows up.
            Will fix later today.
            ./DuetVersion.sh
              Highest Available DuetSoftwareFramework = 2.1.2
             duetsd (= 1.0.6)
             duettools (= 2.1.1)
            ./DuetVersion.sh 2
            Command line arg specified to request Release -2 from highest available.
                   Highest-2 is DuetSoftwareFramework = 2.1.2
            Dependencies for DSF version 2.1.2 are:
             duetcontrolserver (= 2.1.2)
             duetsd (= 1.0.6)
             duettools (= 2.1.2)
             reprapfirmware (>= 2.1.2-1)
             reprapfirmware (<= 2.1.2-999) )
            reprapfirmware apt version 2.1.2-1 is internal version 3.01-RC10
