    Duet3 MB6HC Rev1.0 firmware 3.0beta12 can’t control PWM fan
    340
    • Jimmykcundefined
      Jimmykc
      My fans configuration is showed below.
      I jump wire to check the PWM signal by the oscilloscope.
      I try to key the different fan command to control PWM.
      M106 P0 S0
      M106 P0 S1
      M106 P0 S100
      And I also slide the icon on DWC menu.
      The PWM signal on the oscilloscope is no different.
        Please upgrade first to RRF 3.0 and then to RRF 3.01-RC9, and see if the problem still exists.
        • Jimmykcundefined
          Jimmykc
          @dc42 Thanks for your help.
          After I update to RRF 3.01-RC9, I can control PWM fan. But I have new question.
          After I measure the out4 pin to check PWM signal, it is different from the PWM which I configure the io4.out as PWM.
          The figure of PWM comparison is showed below
          The Ch2’s PWM is configured from the io4.out.
          The Ch3’s PWM is configured from the OUT4.
          May I use fan PWM to control the servo ? or
          Could you give me the suggestion how to use fan PWM to control the servo ?
            The fan output are open-drain, so the signals on them won't make much sense unless you connect a fan or other load (e.g. a resistor) between the two pins.
            It's possible to use a Fan- output to control a servo by adding a pullup resistor between that output and +5V, but why would you want to do that if you have a free IO_x_OUT pin?
            • Jimmykcundefined
              Jimmykc
              @dc42 I have servos more than IO_x_OUT pin so I want to use fan PWM to control them. OK, I will add a pullup resistor to try it. Thanks for your help.
                dc42 administrators @Jimmykc
                @Jimmykc said in Duet3 MB6HC Rev1.0 firmware 3.0beta12 can’t control PWM fan:
                You will also need to invert the pin in the M950 command that creates a servo output using a fan pin.
                • Jimmykcundefined
                  Jimmykc
                  I add a pullup 3.3k resistor to 3.3V to try it.
                  It can work, but I have a new question.
                  What is the limitation of voltage for the fan pin if I want to pullup voltage more than 3.3V?
                    The limit is the VIN voltage.
                    Jimmykcundefined 1 Reply Last reply Reply Quote 0
                    • Jimmykcundefined
                      Jimmykc @dc42
                      @dc42 I see, thanks.
