    Duet3 Bossa firmware flash fails
    Firmware installation
    520
    • judicarundefined
      judicar
      Duet3 MB6HC 1.0 (3.0beta12)
      I received this board and out of box everything worked until I attempted to flash it over ethernet via DWC. The board stopped responding over ethernet and USB (I read earlier that the ethernet is unreliable in 3.0 beta).
      I followed steps for flashing board using Bossa 1.9.1 but it always returns 'Flash failed' at 6%.
      1. Reboot with Erase jumper installed.
      2. Remove Erase jumper.
      3. Attempt to flash with Bossa either through UI or command line fails.
      $ sudo bossac -e -w -v -b -d -U -p cu.usbmodem144201 ./Duet3Firmware_MB6HC.bin -R
      go(addr=0x20401020)
      writeWord(addr=0x400e0c04,value=0x5a004301)
      [= ] 6% (68/1110 pages)write(addr=0x20401034,size=0x200)
      writeWord(addr=0x20401028,value=0x408800)
      writeWord(addr=0x2040102c,value=0x20401034)
      readWord(addr=0x400e0c08)=0x469c4662
      Flash command failed
      Any ideas? Verify also fails, but read succeeds.
      • Danalundefined
        Danal
        Your input file is './Duet3Firmware_MB6HC.bin' Where did that originate?
        Also you have the -U -p and -R flags specified. You don't need them. In particular, bossac will auto discover the port. Try:
        bossac -e -w -v -b /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
        judicarundefined 1 Reply Last reply Reply Quote 0
          A Former User @judicar
          @judicar the only other instance of something similar I've seen was resolved by trying another usb cable. It's it the exact same address it falls at each time?
          • judicarundefined
            judicar @A Former User
            @bearer It fails at different points with different versions of firmware. I assume 0x400e0c08 is some register that contains the result of whatever operation its trying to perform.
              Odd, the target is "dead" and shouldn't react differently afaik.
              I suspect @droftarts may know a thing (or 2000) about this. Meanwhile I'd give another cable a go.
              • judicarundefined
                judicar @Danal
                @Danal I should've mentioned this running standalone
                • Danalundefined
                  Danal
                  Standalone when running, got it. At the same time, per the "sudo" you are bossac-ing from unix/linux/pi, correct? If so, I would seriously consider changing the flags.
                  And, as mentioned above, try different USB cables.
                  • judicarundefined
                    judicar
                    Looks like it's a bug in the macOS/BSD version of Bossa. Dug up an old pc and it flashes fine with the Windows version. Thanks for the assistance.
                      A Former User
                      If you kept the complete debug output could you add it to pastebin or directly in the issue on github, maybe it helps get it fixed.
                      https://github.com/shumatech/BOSSA/issues/106
                      (or if you wanna get down and dirty try testing https://github.com/shumatech/BOSSA/pull/121 if you only make bossac it shouldn't have dependencies)
                      mbavaro created this issue in shumatech/BOSSA
                      open MacOS fails programming SAM S70, Windows succeeds #106
                      dledge opened this pull request in shumatech/BOSSA
                      open Short delay to ensure port is flushed in OS X (and prevent download h… #121
                      judicarundefined 1 Reply Last reply Reply Quote 1
                      • judicarundefined
                        @bearer Will do!
                          droftarts administrators @judicar
                          @judicar Yes, current version of Bossa 1.9.1 on Mac OS seems to be broken for Duet 3. Has been reported here https://github.com/shumatech/BOSSA/issues/106 but there doesn't seem to be much activity on the bossa github.
                          Please let us know if you recompile it with that fix, and it works.
