    Layer count in DWC progress display
    Duet Web Control
    977
    • DaveAundefined
      DaveA
      Object Height = 10mm
      Layer Height = 0.10 mm
      Which is very odd in that all prints I've done this afternoon have an object height of 10mm and they certainly have all not been 10mm. Actually I doubt that any of them have been exactly 10mm.
      Where is the Object Height obtained? I've looked in the .gcode file with NotePad++ and I can find a string for "layerHeight' but no entry for ObjectHeight or any string of "object*"
      • DaveAundefined
        DaveA @dc42
        @dc42 I'm updating my last reply to report that every .gcode file that I upload shows up with a 10mm object height. I've tried using Prusa Slicer and S3D with the same results. Actually all files uploaded in the last 5 days are 10mm.
        Just updated to RC8 and DWC 2.1.3 with no change.
          Please make available to us a sample file that incorrectly causes RRF to report 10mm object height.
          • DaveAundefined
            DaveA
            Here it is.
            Coupler v3 large.gcode
            • Danalundefined
              Danal
              Yeah, there is no tag in an S3D generated gcode-file directly for "Object Height" (or most slicers, for that matter).
              I took another look at the code, and RRF appears to be scanning for G0 or G1 commands, highest Z value it can find, or really the last value in the file it can find, skipping those in G91 relative mode, etc. It derives object height from that last one it finds.
              The last few statements in your file are:
              ; layer end
              M106 P2 S0	; case lights off
              M104 S0 	; turn off temperature
              M140 S0	; turn off heatbed
              G1 X0 Y200 F1800	;
              G1 Z10
              M84   	 ; disable motors
              M107	 ; turn off fan
              ; Build Summary
              ;   Build time: 1 hour 24 minutes
              ;   Filament length: 1363.3 mm (1.36 m)
              ;   Plastic volume: 3279.09 mm^3 (3.28 cc)
              ;   Plastic weight: 4.10 g (0.01 lb)
              ;   Material cost: 0.10
              A few thousand lines up from that (line 116782 in the gcode file) is the actual slicer generated G1 with the largest Z:
              G1 Z31.544 F1002
              RRF is finding G1 Z10 that just before the end of the file (line 6 above, line 117118 in the actual file). I believe this is coming from end gcode in S3D. S3D GUI actually calls this the "scripts" tab in a 'process', and it is the "Ending Script" sub-tab. So check all your processes if you are using multiples.
              Either take the 'G1 Z10' out, or make it relative (G91 first) or similar.
              DaveAundefined 1 Reply Last reply Reply Quote 0
              • DaveAundefined
                DaveA @Danal
                @Danal Bingo!!
                Thanks for that. I never thought that the software would walk through the entire file looking for Z move commands. I expected that it would be something fancier than that but I guess it works unless you to want to
                move the head out of the way at the end.
                Thanks again.
                  You can make RRF ignore that G1 Z10 line when scanning for object height by adding a comment beginning ";E" or "; E" (without the quotation marks) at the end of that line:
                  G1 Z10 ; E
                  demonlibraundefined 1 Reply Last reply Reply Quote 0
                  • DeadNewbieundefined
                    DeadNewbie
                    I have a similar issue, but only in S3D,
                    I can see it is detecting the layer height correctly, and I have scanned the file for any G1 Z comands after the end of the parts G-code, but cant find any.
                    I am at a loss, can someone take a look at my file and tell me what I am doing wrong?
                    DWC 2.0.7
                    Firmware 2.05.1
                    Link to the file on my NAS
                    Thanks in Advance
                    Michael
                      Phaedrux Moderator @DeadNewbie
                      @DeadNewbie Its in your end code
                      ; layer end
                      M104 S0 ; turn off extruder
                      M140 S0 ; turn off bed
                      M107
                      G0 Y190 Z190 X10
                      G0 Y190 Z190 X10
                        DeadNewbie
                        I will have a look, but I thought RRF ignored G0 Z?
                        Thanks for looking.
                        And yes you are correct, just tried it, I will amend the end scipt.
                        Thank you
                        • demonlibraundefined
                          demonlibra @dc42
                          @dc42 It seems firmware parsing gcode and find last command "G1 Z..." to determine the height of the part.
                          Maybe it is better searching last command "G1 Z..." before last command "G1 ..... E...." to determine real printing height.
                            dc42 administrators @demonlibra
                            @demonlibra you can get RRF to ignore that line by putting a command starting with ;E or ; E at the end of it.
