    RRF Version numbers and tagging
    Firmware developers
    409
    • gtj0undefined
      gtj0
      @dc42 Would it be possible to change RRF to use a more standard major.minor.patch version scheme. It might make it easier for folks to understand what they might want to skip if they're otherwise running OK. For instance, a 3.1.0 to 3.2.0 change (with 3.2.0-RCs in between) would imply new features plus fixes suitable for production but a 3.1.0 to 3.1.1 change would imply fixes only.
      Also would it be possible for you to tag CANlib, CoreNG, FreeRTOS and RRFLibraries with the RRF version that they support. This would make it easier for us folks who test and tinker to go back to known versions of RRF and get the matching library versions.
        A Former User
        Was a topic about a year ago or so, conclusion "possibly, not feasible" iirc but couldn't find the refrence with a quick search
          A Former User @A Former User
          @bearer said in RRF Version numbers and tagging:
          (not what i was looking for, but there is some discussion of the same here https://forum.duet3d.com/topic/13381/reprapfirmware-3-0rc1-released/10?_=1588434489302)
          • gtj0undefined
            gtj0 @A Former User
            @bearer I have a hard enough time remembering conversations from yesterday. 🙂
              dc42 administrators @gtj0
              @gtj0 said in RRF Version numbers and tagging:
              That's almost what we do already. We use 2 digits for the second number so that version number strings can be compared, for example it's important that 3.10 > 3.2 > 3.1. We don't currently include the .0 at the end of the version number of a new minor release, but we could do.
              Yes I could do that.
              • gtj0undefined
                gtj0 @dc42
                @dc42 said in RRF Version numbers and tagging:
                There are plenty of utilities that can do semantic version comparisons. 🙂 Anyway, if you think that there'll be a 3.01.1 for instance instead of a 3.02 then adding the patch level to all releases will make things easier I think. I.E. 3.01.0, 3.01.1, 3.02.0-RC1, 3.02.0, etc. Easy to parse with a regex for example.
                That would be excellent, thanks! RCs as well I hope.
                • Danalundefined
                  Danal
                  To me, the bigger problem is lack of mapping from 'apt' releases to "V3.01 RC11" nomenclature.
                  I've been trying to decide if this is worth releasing. Looking at it tonight, I realize it should also show DWC
                   ./DuetVersionsAll.sh
                  Expect this to take several seconds per line of output.
                  Note: For highest accuracy, run 'sudo apt get update' first.
                  duetsoftwareframework 2.1.3 contains reprapfirmware version 2.1.3-1 which is internal version 3.01-RC11
                  duetsoftwareframework 2.1.2 contains reprapfirmware version 2.1.2-1 which is internal version 3.01-RC10
                  duetsoftwareframework 2.1.1 contains reprapfirmware version 2.1.1-1 which is internal version 3.01-RC10
                  duetsoftwareframework 2.1.0 contains reprapfirmware version 2.1.0-1 which is internal version 3.01-RC9
                  duetsoftwareframework 2.0.0 contains reprapfirmware version 2.0.0-1 which is internal version 3.01-RC8
                    Maybe; but I am not going to waste time and precious flash memory space by adding a separate data type in the object model so that conditional GCode can compare version numbers. Much simpler to include the leading zero.
                    • gtj0undefined
                      gtj0 @Danal
                      @Danal said in RRF Version numbers and tagging:
                      Yeah, I don't use the packages because I compile and test a lot but it would make sense that the reprapfirmware package have the same version as the firmware it contained.
