    Macros don't show up on the PanelDue
    1.7k
    • PayTorundefined
      PayTor
      I checked the firmware and it is 1.15c. Also, this the line I use in the config file to create U and V :
      M584 X0 Y1 Z2 U3 V4 E5:6:7:8:9 ; Create U and V axes
      I can see the the U and V homing buttons on the web interface, but not on the PanelDue.
        Does the machine name show up on PanelDue?
        Please try PanelDue firmware version 1.16beta2.
        • PayTorundefined
          PayTor
          I upgraded the firmware. Still the same issue. Here are some pictures of the PanelDue and the web interface:
            Your temperature readings look odd and i am wondering whether your configuration is resulting in a status message that PanelDue is failing to parse. Please share your config.g file.
            • PayTorundefined
              PayTor
              I've disabled the heaters in the config file. Please take a look:
              M111 S0 ; Debugging off
              G21 ; Work in millimetres
              G90 ; Send absolute coordinates…
              M555 P1 ; Set firmware compatibility to look like RepRapFirmare
              M208 X0 Y0 Z-10 U-10 V-10 E0:0:0:0:0 S1 ; Set axis minima
              M208 X250 Y615 Z50 U400 V400 E1:1:1:1:1 S0 ; Set axis maxima
              M574 X1 Y1 Z1 U1 V1 E1:1:1:1:1 S0 ; Define active S0=LOW or S1=HIGH microswitches
              M569 P0 S0; Drive 0 goes forwards
              M569 P1 S0; Drive 1 goes forwards
              M569 P2 S1; Drive 2 goes forwards
              M569 P3 S0; Drive 3 goes forwards
              M569 P4 S0; Drive 4 goes forwards
              M569 P5 S1; Drive 5 goes forwards
              M569 P6 S1; Drive 6 goes forwards
              M569 P7 S1; Drive 7 goes forwards
              M569 P8 S1; Drive 8 goes forwards
              M569 P9 S1; Drive 9 goes forwards
              M350 X16 Y16 Z16 U16 V16 E16:16:16:16:16 I1 ; Configure microstepping with interpolation
              M92 X320 Y320 Z640 U1066.66 V1066.66 E100💯100💯100 ; Set steps per mm
              M566 X500 Y500 Z1000 U300 V300 E1000:1000:1000:1000:1000 ; Set maximum instantaneous speed changes (mm/min)
              M203 X5000 Y5000 Z1000 U1000 V1000 E1000:1000:1000:1000:1000 ; Set maximum speeds (mm/min)
              M201 X200 Y200 Z200 U200 V200 E200:200:200:200:200 ; Set accelerations (mm/s^2)
              M906 X1200 Y1900 Z800 U1600 V1600 E800:800:800:800:800 I20 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S60 ; Set idle timeout
              M307 H0 A-1 C-1 D-1
              M307 H1 A-1 C-1 D-1
              M307 H2 A-1 C-1 D-1
              M307 H3 A-1 C-1 D-1
              M307 H4 A-1 C-1 D-1
              M307 H5 A-1 C-1 D-1
              M307 H6 A-1 C-1 D-1
              M307 H7 A-1 C-1 D-1
              ; Detach Fans
              M106 P0 H-1
              M106 P1 H-1
              M106 P2 H-1
              M106 P3 H-1
              M106 P4 H-1
              M106 P5 H-1
              M106 P6 H-1
              M106 P7 H-1
              M550 PAAA ; Set machine name
              M551 Paaa ; Set password
              M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
                Thanks, using your config.g file I can replicate the problem. Investigating now.
                  It's a bug in DuetWiFiFirmware. Will be fixed in 1.18RC2.
                  • PayTorundefined
                    PayTor
                    Awesome. Thanks for your time and your responsiveness. I'm just wondering when you are planning to release 1.18RC2?
                      @PayTor:
                      Tomorrow I hope.
                        I have just released version 1.18RC2.
                        • PayTorundefined
                          PayTor
                          I just updated the firmware to 1.18RC2 and the issue is fixed. Thank you so much for the help!
