    Probe problem.
    2.8k
      If you are certain that power is reaching the sensor solidly, then you should ask your supplier for a replacement sensor. if you have a multimeter, please check for power on the sensor first. Put the positive multimeter lead on either side of L1, and the negative on the ground test point just above D2. You should get 3.3V.
      • adavidmundefined
        adavidm
        I had the exact same symptoms the other day. It turns out I was using the wiring diagram from the production Duet with my beta (white) board. The probe connection is inverted between the two.
        Could that be a factor here?
        David
        • Loffy770undefined
          Loffy770
          I have no power on the probe volt socket on my duet.
          Do I need to enable it or is it always on?
            It's always on. Check that you have the right connections - see adavidm's post. The pins are also labelled on the underside of the Duet.
            • Loffy770undefined
              Loffy770
              Somehow I manage to read the pinout mirrored but its corrected and it works as it should from a power on perspective.
              Are the only FW changes needed those that I made below? Should Z1 still be in M574?
              Have tested to put my hand under the probe when homing Z but it does not stop but the LED turns red… Doing a safe test here..
              M574 X1 Y1 Z1 S0
              M558 P1 X0 Y0 Z1 H5 F120 T6000
              G31 P500 X0 Y0 Z0.5
              ;M557 X15:355 Y15:235 S20
              • Loffy770undefined
                Loffy770
                Now I have set it exactly as in https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer
                M558 P1 X0 Y0 Z1 H3 F200 T5000 R0 ; smart IR Z probe, used for homing Z axis only, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min, no recovery time
                G31 P500 X11.0 Y0.5 Z1.65 ; set threshold and offsets
                it still does not stop..
                • iDeveloundefined
                  iDevelo
                  M558 should be P5 not P1
                  • Loffy770undefined
                    Loffy770
                    The P value on Z probe reacts and output 538 when I hold my hand so I assume its the configuration I need to fix…
                    • Loffy770undefined
                      Loffy770
                      P5 but on the Wiki it is clearly stated that it should be P1 for a IR probe.
                      • Dougal1957undefined
                        Dougal1957
                        Yes mine is P1 as well and works
                        • iDeveloundefined
                          iDevelo
                          My fault I was thinking of a different kind of setup!
                          • Loffy770undefined
                            Loffy770
                            Could you please post your config.g Dougal?
                              Dougal1957
                              Are you on a delta
                                Dougal1957
                                But here it is
                                ; Configuration file for Mini Kossel kit from Think3DPrint3D
                                ; Communication and general
                                M111 S0 ; Debug off
                                M550 PMidiKossel ; Machine name and Netbios name (can be anything you like)
                                M551 Preprap ; Machine password (used for FTP)
                                ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
                                M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEF ; MAC Address
                                ;*** Wifi Networking
                                M552 S1 ; Enable WiFi
                                M555 P2 ; Set output to look like Marlin
                                M575 P1 B57600 S1 ; Comms parameters for PanelDue
                                G21 ; Work in millimetres
                                G90 ; Send absolute coordinates…
                                ; Axis and motor configuration
                                M569 P3 S0 ; Drive 3 goes forwards
                                M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
                                ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
                                M665 R261.30 L520 B175 H336.93 X0.14 Y0.09 Z0 ; set delta radius, diagonal rod length, printable radius and homed height
                                M666 X-1.51 Y0.61 Z1.15 ; put your endstop adjustments here, or let auto calibration find them
                                M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
                                M92 X80 Y80 Z80 ; Set axis steps/mm
                                M906 X1000 Y1000 Z1000 E400 I60 ; Set motor currents (mA) and increase idle current to 60%
                                M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
                                M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
                                M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
                                ; Thermistors
                                M305 P0 T100000 B4287 R4700 ;H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
                                M305 P1 X200 ;H30 L0 T100000 B4388 R4700 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
                                ;M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
                                M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
                                M143 S280
                                ;M307 H0 A182.6 C1031.3 D14.8 S0.8 B0
                                M307 H1 A491.4 C177.6 D4.5 B0
                                ; Tool definitions
                                M563 P0 D0 H1 ; Define tool 0
                                G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
                                ;*** If you have a single-nozzle build, comment the next 2 lines
                                ;M563 P1 D1 H2 ; Define tool 1
                                ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
                                M92 E397:663 ; Set extruder steps per mm
                                ; Z probe and compensation definition
                                ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
                                M558 P1 X0 Y0 Z0 H5 ; Z probe is a switch and is not used for homing any axes
                                G31 X0 Y0 Z2.55 P500 ; Set the zprobe height and threshold (put your own values here)
                                ;*** If you are using axis compensation, put the figures in the following command
                                M556 S78 X0 Y0 Z0 ; Axis compensation here
                                M557 R150 S20
                                M208 S1 Z-0.2 ; set minimum Z
                                M572 D0 S0.15
                                T0 ; select first hot end
                                • Loffy770undefined
                                  Loffy770
                                  Ok, I have a cartheasian.
                                  • Loffy770undefined
                                    Loffy770
                                    Do I need to make any changes to Bed.c HomeZ and Homeall?
                                    • iDeveloundefined
                                      iDevelo
                                      What's the contents of homez.g ?
                                      • Loffy770undefined
                                        Loffy770
                                        Its working now, took awhile but it all good now.
