    Dual X endstop homing
    576
    • Boulet_Fritesundefined
      Boulet_Frites
      I'm very happy to use Duet3D boards for custom machines and i didn't have trouble with the setup of a Duet2 wifi and stalldetection endstops.
      My new project is using a Duet Maestro and for this i need to use mecanical endstops and a dual X carriage.
      I've got one motor on X and the other one on E0, same for the endstops.
      Endstops are connected with two wires :
      NC --> Ground
      C ---> Stop
      In my config.g :
      M584 X0:3 Y1 Z2 U3 P3
      M569 P0 S0
      M569 P1 S1
      M569 P2 S1
      M569 P3 S0
      M574 X1 Y1 Z1 U1 S1
      For my homex :
      M584 X0 U3
      G1 S1 X-605 U-605 F360
      G91
      G1 S2 X5 U5
      G90
      M584 X0:3
      M119 shows me that the endstop works well.
      But only the X motor homes, the E0 motor is not moving.
      Would you know what is the problem here?
      Thank you very much
      Etienne
        I presume you are using RepRapFirmware 2, because homing using dual endstops is different (easier) in RepRapFirmware 3.
        In order to move the U axis when homing, you need to temporarily make the U axis visible. So change your homex.g file to this:
        M584 X0 U3 P4
        G91
        G1 S2 X5 U5
        G90
        M584 X0:3 P3
          Boulet_Frites
          Sorry i didn't mention it :
          Firmware Name: RepRapFirmware for Duet 2 Maestro
          Firmware Electronics: Duet Maestro 1.0
          Firmware Version: 2.03 (2019-06-13b2)
          Web Interface Version: 1.22.6
          Is Maestro compatible with RepRapFirmware 3 ? i've had trouble to find the latest firmware for my hardware.
          Edit : found
          I followed you advice and now the U axis is moving for homing but the motor is turning very slowly; not at the same rate than the X motor.
          DeltaConundefined 1 Reply Last reply Reply Quote 0
            Please post your entire config.g
            • DeltaConundefined
              DeltaCon @Boulet_Frites
              @Boulet_Frites said in Dual X endstop homing:
              Yes it is, I am running RRF 3.01 (RC11) on a Maestro.
              Check your Steps/mm for the E0 motor, it needs to be the same as your X motor of course.
              I am doing the same thing, in RRF3, also on a Maestro, but with a double Y instead. I do not have that working completely either 😉
              If you think trial and error is dangerous, try routine. That's even more so!
                dc42 administrators @DeltaCon
                @DeltaCon said in Dual X endstop homing:
                No need, as long as the M92 command comes after the M584 command then it will set the steps/mm for both X motors.
                  Boulet_Frites
                  In order to simplify the resolution of the problem (and maybe help @DeltaCon ); i've upgraded to 3.01 RC11 too.
                  Behavior of the machine :
                  X move goes well with the two motors synchronised.
                  M119 reports good behavior of the endstops.
                  Homing is not working at all. If i ask for homing X,Y or Z the color of the button on the touchscreen goes from blue to red. Nothing moves.
                  Here is my config.g :
                  Colorator 4000
                  M119
                  Status
                  Idle
                  Mode: FFF
                  Tool Position
                  X
                  0.0
                  Y
                  0.0
                  Z
                  0.00
                  U
                  0.0
                  Extruder Drives
                  Drive 0
                  0.0
                  Speeds
                  Requested Speed
                  0 mm/s
                  Top Speed
                  0 mm/s
                  Sensors
                  Vin
                  12.4 V
                  MCU Temperature
                  29.6 C
                  Tools
                  Extra
                  Control All
                  Tool Heater Current Active Standby
                  Tool 0
                  T0 - Load Filament n/a n/a
                  0
                  0
                  Temperature Chart
                  No Data
                  System Directory
                  0:/sys/config.g
                  ; CONFIGURATION FILE FOR DUET MAESTRO SELF TEST
                  ;-------------------------------------NOTE---------------------------------------
                  ;-- THIS FILE IS FOR FACTORY TESTING ONLY --
                  ;-- DO NOT USE THIS CONFIGURATION FILE FOR A 3D PRINTER --
                  ;-- Use the reprapfirmware configurator to generate a configuration file --
                  ;-- for your printer: --
                  ;-- https://configurator.reprapfirmware.org/ --
                  ; CREATED: 2018.06.21 MJC from Quad / Maestro / MB as baseline
                  ; Edited by tony@duet3d.com 2018.08.28
                  ; --- SECTION: GENERAL PREFERENCES ( ) ---
                  M555 P2 ; Set output to look like Marlin
                  G21 ; Work in millimetres
                  ; --- SECTION: Z-PROBE & MESH COMPENSATION (Z PROBE SECTION) ---
                  ; --- SECTION: DRIVES (MOVEMENT SECTION) & ENDSTOPS ---
                  M569 P0 S0
                  M569 P1 S1
                  M569 P2 S1
                  M569 P3 S0
                  M350 X8 Y8 Z8 U8 I1
                  M92 X64 Y64 Z64 U8
                  M906 X600 Y600 Z600 U600 I60 ; Set motor currents (mA) and increase idle current to 60%
                  M201 X1000 Y1000 Z1000 U1000 ; Accelerations (mm/s^2)
                  M203 X20000 Y20000 Z20000 U20000 ; Maximum speeds (mm/min)
                  M566 X1200 Y1200 Z1200 U1200 ; Maximum instant speed changes mm/minute
                  M574 Z1 S1 P"zstop"
                  M574 U1 S1 P"e0stop" ; configure active-high endstop for low end on Z via pin zstop
                  ; --- SECTION: HEATERS (HEATER & THERMISTOR SECTION) ---
                  M302 P1 ; Allow Cold extrudes
                  ; Thermistors
                  M305 P0 T100000 B3950 R2200 H30 L0
                  M305 P1 T100000 B3950 R2200 H30 L0
                  M305 P2 T100000 B3950 R2200 H30 L0
                  M570 S180 ; allow it 180 seconds before gving a heating warning and test hotends wont be tuned.
                  ; Tool definitions
                  M563 P0 D0 H1 ; Define tool 0
                  G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
                  M563 P1 D1 H2 ; Define tool 1
                  G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
                  ; --- SECTION: FANS ( ) ---
                  ; Disable Fan 1 thermostatic mode
                  M106 P1 H-1
                  ;Define the 4th fan
                  ; --- SECTION: TOOLS (TOOL DEFINITION SECTION) ---
                  ; --- SECTION: NETWORKS (PROLOGUE & COMMUNCATIONS SECTION) ---
                  M550 PColorator 4000 ; Set machine name
                  M552 P192.168.5.151 S1 ; Enable network and set IP address
                  M553 P255.255.255.0 ; Set netmask
                  M554 P192.168.5.1 ; Set gateway
                  M586 P0 S1 ; Enable HTTP
                  M918 P1
                  ; --- SECTION: MISCELLANEOUS ---
                  G92 X0 Y0 Z0
                  G91
                  Thank you for your help !
                    As you are now using 3.01-RC11, you don't need to create the U axis. So:
                    • Remove everything to do with U in config.g
                    • Change your M574 X command to: M574 X1 S1 P"xstop+e0stop"
                    • Change homex.g and homeall.g to home the X axis just as if you had only one motor
                    In M119 and in the Endstops list in DWC, X will show as stopped if either X endstop switch is triggered.
                      Boulet_Frites
                      I did whay you said, here is my :
                      config.g
                      M584 X0:3 Y1 Z2 P3
                      M569 P0 S0
                      M569 P1 S1
                      M569 P2 S1
                      M569 P3 S0
                      M350 X8 Y8 Z8 I1
                      M92 X64 Y64 Z64
                      M906 X600 Y600 Z600 I60 ; Set motor currents (mA) and increase idle current to 60%
                      M201 X1000 Y1000 Z1000 ; Accelerations (mm/s^2)
                      M203 X20000 Y20000 Z20000 ; Maximum speeds (mm/min)
                      M566 X1200 Y1200 Z1200 ; Maximum instant speed changes mm/minute
                      M574 X1 S1 P"xstop+e0stop" ; configure active-high endstop for low end on X via pin xstop
                      M574 Z1 S1 P"zstop"
                      ; Thermistors
                      ; Tool definitions
                      M106 P1 H-1
                      ;Define the 4th fan
                      M918 P1
                      G92 X0 Y0 Z0
                      G91
                      homex.g
                      G1 X-605 F1360
                      G91
                      G1 X5
                      G90
                      G1 X-5 F360
                      Nothing has changed. Moving is still good but for homing nothing happens.
                      Edit : If i ask with the console "G28 X" it says me that Error : G0/G1 : insufficient axes homed
                        Boulet_Frites
                        Edit 2 : Adding "H1" in the homex.g made everything works very well ! Problem solved 🙂 Thank you very much.
