    Using conditional gcode to evaluate a value
    Gcode meta commands
      jay_s_uk
      I've just added switches to detect when a tool is installed to my printer.
      I can then identify which one is fitted and dock it accordingly if needed.
      IO inputs are available in the OM but how do I evaluate them using conditional gcode?
      i've tried
      if sensors.gpIn[0] = 1
        That should work, You can use:
        echo sensors.gpIn[0]
        to check the state from the DWC console.
          jay_s_uk
          I get this if I try echo in the console
          Error: Failed to evaluate "sensors.gpIn[0]": unsupported type code 11
          The error from code I tried in post 1 is
          Failed to evaluate "sensors.gpIn[0] = 1": cannot convert operands to same type
            Which firmware version are you using?
              dc42 administrators @dc42
              PS - using recent firmware (preferably 3.01-RC12) you would need to use:
              if sensors.gpIn[0].value = 1
                jay_s_uk @dc42
                That worked. Thank you!
