    Bad read value from dc42 IR sensor
    IR Height Sensor
    817
      Try increasing your dive height from H3 to H10 and see if it improves.
      • Charpyundefined
        Charpy
        Thank's for your answer !
        I have the same result : the value of the probe is the same : 986...
          Is this a new probe?
          • Charpyundefined
            Charpy
            I hope ! i've buy it last 2 month on RepRapworld.com
            On the back of the pcb it's writed ver1.3.
              Can you try cleaning the sensor gently with a cotton bud and some isopropyl?
              • Charpyundefined
                Charpy
                I did it,
                Now the result is 984
                • Charpyundefined
                  Charpy
                  Finally I found it!
                  based on the diagram here: https://raw.githubusercontent.com/dc42/OrmerodSensorBoard/master/SchematicAndPCB/Mini-differential-IR/V1.2/schematic.png
                  I saw that the value of the R5 resistor was +10M ohms.
                  In fact the resistor was poorly soldered and is not possible to see it with naked eye!
                  Now the probe read correctly 465 and 535.
                  Luckly i'm not bad with electronics. someone else would just have tossed it in the trash! ...
                    Well done!
                    • Charpyundefined
                      Charpy
                      I still have a mistake...
                      I've leveled my bed as best as i can by hand but the height map look like this :2020-05-07 15_59_03-CoreXY.png
                      And is impossible I have 1.4 mm higher on the back
                      The probe seems to "drift" by the time. (as you can see on the X moves)
                      I tried other cables and different microstepping setup but the result is the same
                      This is possible ?
                      Any idears ?
                      thank's in advence
                      • Charpyundefined
                        Charpy
                        It is possible that the sensor is damaged by the bad solder of the resistance ?
                        I think i have tried all i can do... I need some help ! ...
                          I'm affraid it may be time to replace the probe.
