    datetime -> RRF
    Duet Web Control wishlist
    318
    • arhiundefined
      arhi
      If I understand correctly, now when I open web to the RRF it will set the correct datetime on RRF. This works rather ok, but if I'm in DWC, I send M999, board reboots, DWC reconnect but datetime is gone. Or I'm in DWC, I powercycle the printer, DWC reconnect and datetime is gone. Can we have a "button" that "set datetime from browser on RRF" ?
        DWC should always set the datetime when it connects or reconnects. Which version are you using?
        arhiundefined 2 Replies Last reply Reply Quote 0
        • arhiundefined
          arhi @dc42
          @dc42 2.1.7
          I look at it like this, if I open DWC and then upload file using curl the file has ok datetime set, if I reboot the RRF, dwc reconnects automatically, upload file using curl, file in most cases has no datetime set
          • arhiundefined
            arhi @dc42
            @dc42 connected, used a bit, 2:38:31AM - powercycle, it reconnected, datetime is ok, 2:39:25 sent M112, clicked on "reboot", clock after that - not set
            now click on emergency stop button (top right)
            again time not set
            clicking trough DWC, diagnostic .. code still not set ... need to go to initial page ( / ) for clock to be set
            now again, emergency stop button...
            and again, clock not set
            • arhiundefined
              arhi
              it looks like "green - connected to" info happens when it sets datetime and orange "attempting to reconnect" does not, probably after the orange one the green one should happen but it does not even as the connection is back
                This is being fixed in the next release of DWC.
                • arhiundefined
                  arhi
                  confirmed - fixed in 3.1.0
                    Thanks for confirming.
