    I must be doing it wrong
    2.5k
    • Jackalundefined
      Jackal
      I believe a copy of you config.g and photos of your wiring may help us help you troubleshoot your problems.
      • Willy510undefined
        Willy510
        Have you tried the online configuator or are you making a config from scratch?
        https://configurator.reprapfirmware.org/
          I will assume this is a Cartesian printer, not a CoreXY or H-Bot.
          First of all, check whether the motors are moving in the right direction. +X should be to the right. If it isn't, edit the M569 P0 command in config.g by changing S0 to S1 or vice versa.
          Similarly, if the Y motor is moving the wrong way, edit the M569 P1 command.
          For Z homing without a Z probe, see https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z_without_a_Z_probe.
            deckingman
            Ref point 1a, once you have got X homing working, you won't be able to move the print head below X=0 (assuming you have defined X =0 as being the minimum using M208 S1 or some such. Similarly, you won't be able to move beyond X max (or Y and Z max for that matter), if you define the axes maxima using M208 S0 in your config g. However, you do need to successfully home all the axes first so that the printer "knows" where it's at to start with. As has been mentioned, you might be better off starting with the configuration tool.
            • funjonundefined
              funjon
              I apologize for the delay in response; I spent most of last week dealing with a death in the family.
              Last night I pulled the wiring out to take some pictures, as requested, and discovered the wiring loom for my Z-axis stepper had some crimp failures. I re-crimped the ends and rebuilt the plug, and it seems more solid now. I checked the rest and they seem good.
              I did use the configurator, but I also started from a config from another person who had a Wanhao Duplicator 6 and replaced the board with a DuetWifi. Both have yielded a relatively similar configuration.
              I've figured out my +/- issue, I need to tell it that the X axis goes backwards, and now when it homes to zero, X+ goes to the right as expected. Y+ still goes up, as expected. So that's solved.
              My problem however is still the Z axis. When I can get it to move, it still randomly goes up or down. Sometimes it just sits there and makes whining noises like David Tennant in The End Of Time[1]. I'll double-check all the wiring, and maybe hand-turn the lead screw to get the bed closer to home. Somewhat disturbingly, I told it to Home Z, and it sat, grinding and whimpering near the bottom of travel, and so I came here to finish my reply. When I went back to my Duet tab, it says the Z axis is homed and it's at Z=0. Which is hard to believe, since it never got to the endstop, and I don't have a probe (installed or configured: [c]M558 P0[/c]). Not sure where it gets that idea, since it's been told about the endswitch ([c]M574 X1 Y1 Z1 S0[/c]).
              I tried upping the current a bit to the Z motor, and now it consistently moves without grinding and pulling a Tennant, but it still bounces randomly backward and forward.
              My current running config:
              ; Configuration file for Duet WiFi (firmware version 1.16)
              ; generated by RepRapFirmware Configuration Tool on Sat Mar 25 2017 23:18:27 GMT-0700 (PDT)
              M111 S0 ; Debugging off
              G21 ; Work in millimetres
              M555 P2 ; Set firmware compatibility to look like Marlin
              M208 X200 Y200 Z180 S0 ; Set axis maxima
              M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
              M558 P0 ; no Z probe installed
              ;M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
              ;G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
              ;M557 X15:185 Y15:185 S20 ; Define mesh grid
              M569 P0 S0 ; Drive 0 goes backwards
              M92 X80.4 Y80.4 Z800 E95 ; Set steps per mm
              M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
              M203 X20000 Y20000 Z1000 E1000 ; Set maximum speeds (mm/min)
              M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
              M906 X1000 Y1000 Z1500 E1000 I60 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M143 S280 ; Set maximum heater temperature to 280C
              M305 P0 T100000 B3988 R4700 ; Set thermistor + ADC parameters for heater 0
              M305 P1 T100000 B4138 R4700 X200 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 200
              M563 P0 D0 H1 ; Define tool 0
              M550 Pdup6duet ; Set machine name
              M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
              M106 P0 S1 I0 F500 H1 T180 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P2 S0.5 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
              T0 ; Select first tool
              I appreciate any insight. Thanks!
              [1] "I don't want to go!"
              • funjonundefined
                funjon
                The broken wiring:
                Green = Z axis
                Yellow = Y axis
                • funjonundefined
                  funjon
                  Well, crap. I was trying to calibrate my extruder while waiting for some help on the Z axis, and it wouldn't turn - like it was jammed. After it tried briefly, I heard a pop and smelled smoke. Looks like the driver for E0 grenaded.
                  I double-checked this wiring, it's not bad. Wondering if the stepper itself is jacked up somehow.
                  Guess I can try to go on E1, but I'd rather not kill another driver.
                  sigh Starting to feel like this isn't meant to be.
                    Ask your Duet supplier for a repair under warranty.
                    I'm trying to collect data on blown drivers, so please tell me what VIN voltage you were using and what current was set.
                    • funjonundefined
                      funjon
                      I am running a 24V system (my multimeter currently says the PSU is outputting 24.1V DC). Motor current for E0 was 1500mA.
                      I will email Filastruder tomorrow. Thanks!
                      • jrledererundefined
                        jrlederer
                        while a replacement under warranty certainly is generous, to the OP: 1500mA at 24V is pretty much the highest (right, or is it 2A max?) you are to push the built in drivers, so feel fortunate that dc42 is being very cool about this. I run 24V on a delta bot and my currents are all around 800mA (obviously, the values are motor-dependent, but still, (I am inclined to say) it's unnecessary under normal circumstances to ever run the drivers at their upper limit…lest you get results such as the ones you've gotten. Just a thought for the future!
                        Have a nice day. Also, the intermittent direction changes in your Z stepper point to wiring problems for that motor. Before popping that driver too, please re-do the wiring and ensure you've got the correct pairs going to the correct locations as well as no intermittent shorting. Just in case you didn't know this: ensure your power is completely off prior to connecting or disconnecting stepper motor wires, as often doing so while powered up leads to blowing the associated driver, prob. the majority of the time (which is akin to an intermittent short).
                        HTH.
                        --jonathan
                        "Insanity is doing the same thing over again, yet expecting different results..." --Albert Einstein
                          @jrlederer:
                          We've been conservative in limiting the maximum current to 2.0A so far, even though the drivers are theoretically rated to more than 3A. But we've done some more thermal testing, and I have recently been testing a Duet WiFi with nema 23 motors at up to 2.5A. So we'll announce an increase in maximum current soon. I've also been testing the effects of connecting and disconnecting stepper motors under load, and the TMC2660 drivers are more resilient than I expected them to be. I think the most likely thing to damage them is over-voltage, which in some printers can be caused by moving the carriage(s) by hand very quickly.
                          @jrlederer:
                          I agree, reversals in direction could be caused by a bad connection.
                          • funjonundefined
                            funjon
                            So I've spent a ton of time troubleshooting (very carefully, as blowing a driver has scared the crap out of me). Lots of things.
                            1. The Z stepper - I redid the wiring, but I finally got mad and replaced the stepper. Some decent NEMA 17's on Amazon were $15, so I bought 5 (in case, you know, I go mad and build a replacement printer - more later). Replaced the stepper, and used the wire that came with it, bam, perfect Z axis.
                            2. The extruder - Replaced that one too, because as I was looking into the Z stepper, I determined that Wanhao has some funky wiring for some of the motors. The X and Y have always behaved perfectly, but the Z motor was wired straight through, where it should've had some wires crossed over for the (a,b)(1,2) positions. Same for the extruder. Just finished testing and validating steps/mm for E0, and we're good to go.
                            The lack of markings (both of brand/model of the stepper, and which pin is which) scared me, and I was concerned about the lack of movement/random movement in both E0 when I was testing, and Z when it was acting psychotic. $30 worth of steppers has given me much peace of mind.
                            I believe I have a working printer! Thank you all so much for your help.
                            And, now that it's working again, I think I'm going to start printing parts for a D-bot (after I print the housing for the PanelDue!). I'll be putting a Duet in that one, too. At least I'll be building it from scratch, and won't be able to blame any blown parts on anyone but me.
                            • funjonundefined
                              funjon
                              lol i spoke too soon my new extruder stepper's shaft is too long. BRB getting out the dremel… 😉
