G28 Delta towers crash
594
    chris
    I have a delta and when i run G28 even though limit switches activate in machine specific section on dashboard they keep trying to go past and are trying to run motors past limit switches. these are wired in a active low configuration at the top of the delta towers. i am using a duet smart effector.
      chris
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat May 16 2020 12:10:05 GMT+0100 (British Summer Time)
      M550 P"kossel" ; set printer name
      M665 R204 L288 B110 H200 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S1 ; enable Telnet
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X160.00 Y160.00 Z160.00 E663.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X2000 Y2000 Z2000 E1800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 Y2 Z2 S0 ; set active low and disabled endstops
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 R100 S20 ; define mesh grid
      M106 P0 S0 I0 F500 H0 T30 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
        rodek
        Set M574 to S1
        undefined 1 Reply Last reply 17 May 2020, 10:00 Reply Quote 1
          Please post your homedelta.g file too.
          What firmware version are you using?
            chris
            Hi David, I am using the firmware:
            Duet WiFi 1.02 or later (duetwifi102)
            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
            Duet WiFi Server Version: 1.23
              chris
              ; homedelta.g
              ; called to home all towers on a delta printer
              G91 ; relative positioning
              G1 H1 X265 Y265 Z265 F1800 ; move all towers to the high end stopping at the endstops (first pass)
              G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
              G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
              G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
              G90 ; absolute positioning
              G1 X0 Y0 F6000 ; move X+Y to the centre
                chris @rodek
                @rodek wouldn't that persume they are active when high?
                  I didn't see anything wrong with your configuration and homing files.
                  I suspect that you have swapped a couple of motor or endstop cables over. Use G91 followed by G1 H2 Xnnn moves to identify which tower has the X motor. Then check that when you trigger the endstop on that tower, M119 shows that it is the X endstop that is triggered. Repeat for Y and Z.
                  undefined 1 Reply Last reply 17 May 2020, 20:52 Reply Quote 1
                    chris @dc42
                    @dc42 Cheers David, the endstops seem to trigger and are confirmed under endstop status under machine specific tab.
                    undefined 1 Reply Last reply 18 May 2020, 19:38 Reply Quote 0
                      chris
                      does it matter which tower is the x , y and z on a delta as long as it goes in a clockwise direction?
                        themelle
                        I assume it does matter in the way the endstops correlate to the towers.
                        It may just be best practice to call the left tower "X", the right one "Y", and the back one "Z", but it really does help in preventing (or at least resolving) this type of issues.
                          dc42 administrators @chris
                          @chris said in G28 Delta towers crash:
                          What I was trying to as was: Is the endstop that shows as X when triggered on the same tower as the motor that moves when you command X movement with a G1 H2 Xnnn move?
                          Instances of the behaviour you describe are typically caused by the motor and the corresponding endstop (e.g. X motor and X endstop) not being on the same tower.
                          undefined 1 Reply Last reply 19 May 2020, 07:29 Reply Quote 1
                            chris @dc42
                            @dc42 Cheers david X and Y limit switches got swapped
                            10 out of 13
