Power failure during firmware upgrade
    JTBrown
    Whilst upgrading my firmware to 3, I had a power cut and now I can't connect to the Duet2Wifi using the Duet Web Control. It says "Safari can't open page because the server where this page is located isn't responding".
    Please would someone guide me back to where I was. Many thanks
      aidar
      https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        You will need to program the Duet over USB using Bossa. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3.
          JTBrown
          All done now thanks guys. In the end I've reverted back to 2.05.1, out of my depth with this version really! Can you tell me how to mark in as Solved please? once again thanks.
          undefined 1 Reply Last reply 18 May 2020, 08:20 Reply Quote 0
            dc42 administrators @JTBrown
            @JTBrown said in Power failure during firmware upgrade:
            Click on Topic Tools and select Ask As Question. Then click on Topic Tools again and select Mark As Solved.
            4 out of 5
