    SOLVED - Duet2Wifi - WiFI not accessible after RRF3.1.0 upgrade
    Firmware installation
    • pro3dundefined
      pro3d
      Is it gone forever?
      After trying to upgrade from some release candidate of RRF 3 to RRF3.1.0 stable I could not longer connect to the wifi and I decided to reflash from scratch erasing the board
      I managed to flash with the panel due bin file and not the duet bin file and now I can connect. Is it gone forever?
      Thanks in advance
      Valkyrie DIY High Temp 3D Printer
      R&D - Engineering Designer - Viking 3D Printers
      https://vkingprinter.com/
        Go through these steps: https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        Should still be able to reflash with the proper firmware.
        • pro3dundefined
          pro3d
          I managed to connect by usb again and re flash but it seems something is wrong with the wifi module?
          M587
          Error: M587: Failed to retrieve network list<LF>ok<LF>
          M552 S1
          Turn off the current WiFi mode before selecting a new one<LF>ok<LF>
          M552
          WiFi module is being started<LF>ok<LF>
          • pro3dundefined
            pro3d
            When I try to define my network I get this:
            M557 S"ssid" P"password"
            Error: M557: specify at least radius or X and Y ranges in M557<LF>ok<LF>
              dc42 administrators @pro3d
              @pro3d said in Duet 2 Wifi - WiFI not accessible after RRF3.1.0 upgrade:
              The correct command is M587, not M557.
              • pro3dundefined
                pro3d
                Looks like the wifi module has some issues. The status is either disabled or like this:
                M552
                It never goes to started and light is constant on or off with M552S-1
                Network list can not be reached or saved
                M587
                • pro3dundefined
                  pro3d
                  SOLVED!
                  I had to install DuetWiFiServer.bin and now I have connection
                  Thanks for helping
