Problem when Homing X & Y "Alone"
    Nylkos
    Recently I noticed that when I home X or Y, after it homed, my carriage move more on the X Axis.
    When I home All it works great.
    Also when I finish a print it homes to -2.5mm on the X-Axis.
    I honestly do not know what causes this.
    Here is my HomeX:
    ; homex.g
    ; called to home the X axis
    ; generated by RepRapFirmware Configuration Tool v2.1.3 on Sat Nov 30 2019 14:18:00 GMT-0500 (heure normale de l’Est nord-américain)
    G91 ; relative positioning
    G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
    G1 H2 X5 F6000 ; go back a few mm
    G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
    G1 H2 Z-5 F6000 ; lower Z again
    G90 ; absolute positioning
    Thanks you
      Please post your other homing files and your config.g
      What kind of a printer is it?
      What firmware version are you using?
      What Duet board?
        Nylkos
        I own a home built CoreXY with a DuetWifi
        Config
        ; generated by RepRapFirmware Configuration Tool v2.1.3 on Sat Nov 30 2019 14:17:59 GMT-0500 (heure normale de l’Est nord-américain)
        M550 P"My Printer" ; set printer name
        M667 S1 ; select CoreXY mode
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P3 S0 ; physical drive 3 goes forwards
        M92 X160.00 Y160.00 Z800.00 E837.00 ; set steps per mm
        M84 S30 ; Set idle timeout
        M208 X330 Y270 Z295 S0 ; set axis maxima
        M574 X1 Y2 S1 ; set active high endstops
        M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
        M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X0 Y40 Z0 ; set Z probe trigger value, offset and trigger height
        M557 X15:315 Y40:265 S20 ; define mesh grid
        M106 P2 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        HomeY
        ; homey.g
        ; called to home the Y axis
        G1 H1 Y285 F1800 ; move quickly to Y axis endstop and stop there (first pass)
        G1 H2 Y-5 F6000 ; go back a few mm
        G1 H1 Y285 F360 ; move slowly to Y axis endstop once more (second pass)
        HomeAll
        ; homeall.g
        ; called to home all axes
        G1 H1 X-335 Y285 F1800 ; move quickly to X or Y endstop and stop there (first pass)
        G1 H1 X-335 ; home X axis
        G1 H1 Y285 ; home Y axis
        G1 X5 Y-5 F6000 ; go back a few mm
        G1 H1 Y285 ; then move slowly to Y axis endstop
        G1 H2 X15 Y15 F6000 ; go to first bed probe point and home Z
        ;G91 ; relative positioning
        ;G1 S2 Z5 F100 ; lift Z relative to current position
        ;G90 ; absolute positioning
          @Nylkos said in Problem when Homing X & Y "Alone":
          Do not use H2 in that command in homeall. Remove the H2. You should also position the probe in the center of the bed rather than the corner.
          Also, remove the H2 from the second move to back away from the endstop. It's not needed after the axis is homed once, and on a corexy printer the H2 will move the independent motor, which can cause issues.
          From homex and homey
          Note that homeall doesn't have the H2 on the X and Y moves.
          You're missing a trigger height in this command. See here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          3 out of 4
