    Temp sensor issues
    • Lokithegrinchundefined
      Lokithegrinch
      My bed temp sensor is reading a negative 273 degree reading and gives me an error in the web interface I tried plugging in the hot end temp sensor ( which reads correct) into the bed sensor location and it still reads negative any help would be appreciated
        What type of Duet is it, and what M305 P0 command (if any) do you have in your config.g file?
          Lokithegrinch
          its a duet wifi sorry and my config looks like this for the heaters
          M143 S260 ; Set maximum heater temperature to 260C
          M305 P0 T10000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
            Your bed heater thermistor is set up for a 10K bed thermistor (T10000) but you probably have a 100K thermistor. Try T100000 in the M305 P1 command.
              Lokithegrinch
              yhatzee!!! lol fixed it and sir again you are amazing thanks for putting up with all my questions its truly appreciated
