    DUET 3 - PID control pressure sensor to run motor?
    • CJ.BRAVOundefined
      CJ.BRAVO
      Hey,
      is it plausible to connect a pressure sensor to the duet 3 with a pid control to run a stepper motor?
      cheers!
        If it's the Z motor you want to control, then yes. See M951 and M594. Caution, this feature is experimental.
        • CJ.BRAVOundefined
          CJ.BRAVO
          @dc42 said in DUET 3 - PID control pressure sensor to run motor?:
          M951
          I was actually looking to run an extruder.
            @CJ-BRAVO said in DUET 3 - PID control pressure sensor to run motor?:
            M951
            That would require a modification to the M951/M594 code, to generalise to allow a different axis to be used. If the intention is to extrude with constant pressure, then a further modification would be needed to allow the PID controller to control motor speed instead of position.
            • CJ.BRAVOundefined
              CJ.BRAVO
              I"f the intention is to extrude with constant pressure"
              yes, that's the idea.
              • CJ.BRAVOundefined
                CJ.BRAVO
                so thats something in my range?
                • soccerpaulundefined soccerpaul referenced this topic
