    Want to try Kisslicer 1.6.3, need config for Delta
    Example setups and prints
    • Traveler0612undefined
      Traveler0612
      Good evening I have spent the better part of two hours searching the web for a starting point.
      I am getting the dreaded:
      Error: G0/G1: insufficient axes homed
      If someone has one of Dave's Meter Deltas like I do, please share your Kisslicer configuration.
        Did you home the printer before starting the print, or else have a G28 command in your slicer start GCode?
          Traveler0612
          Yes, It did put it in the gcode file. I didn't do a fresh install of 1.6.3.
          ; Home the axes
          G28
          ; Wait till the Bed is heated
          M190 S110
            Traveler0612
            Okay, fresh install, this is the error code.
            Cancelled printing file 0:/gcodes/G5 Cap FDM.gcode, print time was 0h 0m
            Error: G0/G1: target position not reachable from current position
              dc42 administrators @Traveler0612
              Try moving down in Z after the G28 command. My guess is that the first movement command in the GCode file is moving the head in X and Y but not Z.
                Traveler0612
                Okay, found a simple solution. Changed the following settings.
                Under:
                Profile settings - Printer G-code - Select New Ext & Warm:
                ; Head to the start of the next path
                G1 X<NEXTX> Y<NEXTY> F6000
                To:
                G1 X<NEXTX> Y<NEXTY> Z50 F6000
                Under:
                Profile settings - Printer G-code - Warm Same Ext:
                ; Move to the start of the next path
                To:
