    Warning or Pause on heater failure detection
    580
    • toufou54undefined
      toufou54
      It happen on all my prusaslicer generated gcodes, just after the start gcode, I didn't found any M104 S1 in the code.
      I'll send the code tomorrow now, going to sleep right now.
      But yes the gcode seems to send a heater temp to 1 just before print and the warning came later when it detect that the temp is to low to extrude, but it does not stop the print !
      • toufou54undefined
        toufou54
        here the begining of one gcode file:
        ; generated by PrusaSlicer 2.2.0+win64 on 2020-05-24 at 17:05:55 UTC
        M107
        M582 T1 ; check if filament is present
        M220 S100 ;Reset Feedrate
        M221 S100 ;Reset Flowrate
        M140 S55 R40 ; set bed temp
        M190 S55-10 ; wait for bed temp
        M104 S210 ; set extruder temp
        M300 S40 P10 ; chirp
        M118 P3 S"HOMING" ; message HTTP
        M118 P4 S"HOMING" ; message TELNET
        G28 ; Home all axes
        ;M420 S1; restore manual mesh
        M300; beep
        G92 E0 ;Reset Extruder
        G1 Z2.0 F3000 ;Move Z Axis up
        G1 X5 Y20 Z2.0 F3000.0 ; Move to start position
        M109 S210 ; wait for extruder temp
        G1 X5 Z0.3
        G1 X5 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
        G1 X5 Y200.0 Z0.3 F5000.0 ; Move to side a little
        G1 X5.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
        G92 E0 ; Reset Extruder
        G10 S1; retract
        G1 Z10 F3000 ; Move Z Axis up
        G1 X30
        G11; recover after retraction G10
        M118 P4 S"PRINT_START" ; message TELNET
        G21 ; set units to millimeters
        G90 ; use absolute coordinates
        M82 ; use absolute distances for extrusion
        G92 E0
        ; Filament gcode
        G1 Z0.260 F30000.000
        G1 E-3.00000 F2700.00000
        G92 E0
        G1 X64.064 Y47.624 F30000.000
        G1 E3.00000 F2700.00000
        G1 F1200.000
        G1 X65.084 Y46.449 E3.07805
        G1 X66.328 Y45.514 E3.15611
        G1 X67.739 Y44.860 E3.23416
        G1 X100.092 Y36.264 E4.91391
        G1 X101.141 Y36.067 E4.96746
        zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
          Try adding T0 to the start of your start gcode so that the first tool is activated. You can also add it to the end of config.g if it's not there already to have the tool activated at startup.
          Also, M104 S210 ; set extruder temp sets the temp and does not wait. Use M109 instead if you want it to wait for the temp to be reached before proceeding.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M109_Set_Extruder_Temperature_and_Wait
          • zerspaner_gerdundefined
            zerspaner_gerd @toufou54
            @toufou54
            It doesn't look right to me:
            G10 S1; retract
            https://duet3d.dozuki.com/Wiki/Gcode#Section_G10_Retract
            Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
            toufou54undefined 2 Replies Last reply Reply Quote 1
            • toufou54undefined
              toufou54 @zerspaner_gerd
              @zerspaner_gerd you are certainly right, I will modify this (this is my gcodes than I uses on Marlin, I just went to Duet a few days ago...)
              And btw T0 is not the solution, tested without luck.
              Thanks guys, I'll post results when I could try
              • toufou54undefined
                @zerspaner_gerd It was that, thanks !!
                but now I have a new error, I don't think it's relative but appeared right after the change :
                Error: M106: Fan number 2 not found
                It appear twice, the only call to M106 en config is this :
                No call to a fan number 2...
                Thanks
                  Post the gcode file that produces that error please. Along with your full config.g
                  • toufou54undefined
                    toufou54
                    Very weird but errors disappears as they came...
                    My errors are disappears now (at least those, I have others..)
                    But what about the warning and not a critical default and automatic print stop in case of heater fault ???
                      • toufou54undefined
                        toufou54
                        that's ok now thank you , I just have Z stall height errors, I need to tune that.
                        I just want to know how can it be done, make an emergency stop in case of heater failure (or at least a pause during the print).
                        Is it possible ?
