    Z probe triggers far away from bed
    • civi123433undefined
      civi123433
      My printer was working fine until I had to pause a print because my print detached from the bed. So I paused the print, lifted the nozzle, cleared the bed and sprayed some hairspray on the bed. I restarted the print and when it went to home the Z axis, for some reason the probe would trigger far from the bed, like 80 mm away. Even when I manual move the nozzle through the Web Controller, I can see that the probe has a value of 0 up to a certain height at which it switches to 1000 (triggered). Although it shows that the probe is triggered on the Web Controller, physically on the probe, the LED light is still on (not triggered).
      This is the probe i'm using:
      https://www.aliexpress.com/item/32803870919.html?spm=a2g0s.9042311.0.0.27426c374V9P8g
        Share your configs please.
          civi123433
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Mar 27 2020 09:56:13 GMT-0400 (Eastern Daylight Time)
          M550 P"Voron 2.2" ; set printer name
          M667 S1 ; select CoreXY mode
          M552 S-1
          G4 S3
          M552 S0
          G4 S5
          M587 S"Rogers" P"QcRt34E5g"
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P3 S0 ; physical drive 3 goes forwards
          M569 P4 S1 ; physical drive 4 goes forwards
          M569 P5 S1 ; physical drive 5 goes forwards
          M569 P6 S0 ; physical drive 6 goes forwards
          M584 X0 Y1 Z2:3:4:6 E5 ; set drive mapping
          M671 X-55:-55:305:305 Y-7:320:320:-7 S10 ; set positions of Z belts
          M350 X16 Y16 Z16 E16 I1 ; configure microstepping without interpolation
          M92 X78.3 Y79.05 Z320.98 E411.72 ; set steps per mm
          M566 X600.00 Y600.00 Z3600 E900.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E7500 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z60 E10000.00 ; set accelerations (mm/s^2)
          M906 X1200 Y1200 Z1200 E1000 I70 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X280 Y300 Z260 S0 ; set axis maxima
          M574 X2 Y2 S1 ; set active high endstops
          M558 P5 H5 F120 T7200 R0.1 ; set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y-25 Z4.6 ; set Z probe trigger value, offset and trigger height
          M557 X20:260 Y-5:210 S120:107.5 ; define mesh grid
          M307 H1 A284.6 C91.0 D2.1 V12.1 B0
          M305 P1 T100000 B4138 R4700 X3 ; set thermistor + ADC parameters for heater 1 and remap it to channel 3
          M106 P0 S1 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P1 S0 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P2 S0 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M563 P0 D0 H1 F1:2 ; define tool 0
