    Firmware wishlist and priorities for Duet WiFi and Duet Ethernet
    Firmware wishlist
    113
    236
    50.8k
    • Aelinonundefined
      Aelinon
      @boelle:
      @Aelinon:
      Consider: Use Stallguard to perform bed levelling/compensation.
      that would only work where the Z steppers are able to push the nozzle down
      if the X ends rest on Z isolators there will be no resistance when the nozzle touches the bed, but maybe the load will lighten enough that you can say that you are at the bed
      You have a valid point - in all fairness I admit that I was particularly focused on deltas, because, I design/build/use deltas. 🙂
      This idea does seem to me to be a very similar concept to the accelerometers recently being used, without having to implement any new hardware. And pretty cool that Duet is the only board that I'm familiar with that could do it.
        @Aelinon:
        Consider: Use Stallguard to perform bed levelling/compensation. GCode that sets lower current, slower moves, low Stallguard Threshold (SGT) and uses this to find the bed with the hotend by treating stall notification as trigger. Once complete, returns to normal current/speed/accel settings. Complications that may arise and require a lot of custom tuning per individual printer are outlined very well in section 4.1 of the datasheet: https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2660_datasheet.pdf.
        Perhaps flag that allows SGT triggers for each driver to be displayed as they are triggered to assist in tuning the individual printer's motors?
        Sadly not possible. StallGuard only updates the stall status every full step, so the resolution would be too low. Also StallGuard doesn't work at low speed because the motor back EMF is too low.
        What might be possible is to use StallGuard and reduced motor current to eliminate the homing switches on a Delta printer. The homing positions do not need to be accurate if auto calibration is run after homing.
        • Merlinundefined
          Merlin
          My vote~;
          14
          13
          16
          • Nuffeundefined
            Nuffe
            14
            20
            19
            • paul12undefined
              paul12
              15
              • educaundefined
                educa
                If you do it, do it good.
                  Thanks for all your votes. I am currently working on #1, and when that is complete I will total the votes up.
                  • magicmushroom666undefined
                    magicmushroom666
                    16
                    15
                    • boelleundefined
                      boelle
                      What happens with ideas that made it to the list but got no votes?
                      will they stay for a next round of voting?
                        @boelle:
                        Probably, and if not then you can suggest them again.
                        • Russ Griesundefined
                          Russ Gries
                          Is there current support for bed probing more than once ? ( i dont think there is?)
                          Probing the same point lets say 5 times then taking the average of that point?
                          when i was using other firmware that was nice because some probes were just not that accurate. so this helped even out that problem.
                          also just a simple Request, on a G30 command we can also have the Max and Min values?
                          so the code that comes back looks like this:
                          [c] 8:52:14 PM
                          M98 P0:/macros/probetesting/Probe Testing moving 100 -100 probe 0,0 25 Point.p values .gcode
                          Bed probe heights: -0.009 -0.006 -0.006 -0.006 -0.006 -0.006 -0.006 -0.003 -0.006 -0.006 -0.006 -0.006 -0.006 -0.006 -0.006 -0.003 -0.003 -0.003 -0.003 -0.003 -0.003 -0.003 -0.003 -0.003 -0.003,
                          mean -0.005, deviation from mean 0.002[/c]
                          Could we also have the max and min value from the mean? ( the span)
                          i use (=ABS) in excel to handle the + and - values.
                          Thanks,
                          ~Russ
                          One Day At A Time…
                          My Main Research Page:
                          http://rwgresearch.com/open-projects/3d-printing-research/
                          • inachisiojexusundefined
                            inachisiojexus
                            17
                            15
                            • NoSkillzEngineerundefined
                              NoSkillzEngineer
                              With 12, if 3 Phase BLDC with 3 channel magnetic encoders could be supported generally, I'll help in any way I can, I have nema 23 servos (I think) they were donated so three thick wires from the motor and five thinner wires coming from the bottom cap looking end…I'm going to assume they are servos.
                              Is hdmi 1080p support difficult? I'm going to prototype a few boards in a few months.
                              Would it be easier to use an android computer to interface with it over wifi? Probably. I'm thinking of a small hdmi or tablet or general touch screen to make it nicer to use, always powered and connected to the internet as well (obviously).
                              Is it possible to have a way to retrieve files from a NAS or a macro or sub program or list of commands, stored in cache or ram to upload new files after a print without it getting interrupted? If I print a file that is set to print for 8 hours, and an hour into the print I want to upload a file, I want to be able to do it. I don't care if it does it right then or wait until the file is finished printing and then uploads it as a new command after, retrieving it from the attempted directory, as long as I can walk away or go to sleep and leave not needing to remember to do it after a print for later.
                              It might sound like I'm being picky at times, it is only because I believe that "Technology is truly at its best when it becomes invisible." Take a good router, if it's good, most people forget they have a router at all. I want that for my printer, I want it to be that tool for me when I need it.
                              • Adamfilipundefined
                                Adamfilip
                                18
                                • Shenundefined
                                  Shen
                                  • nytundefined
                                    nyt
                                    • Kulitorumundefined
                                      Kulitorum
                                      Fixing IDEX with R2 and proper Z-offset?
                                      • cbusilloundefined
                                        cbusillo
                                        Can you read the driver temps over SPI? If so it would be awesome if one of the PWM fan channels could be temperature controlled.
                                          deckingman
                                          @cbusillo:
                                          Apparently not but I believe there is a temperature warning alarm and an over temperature alarm which DC has it on his todo list to look at monitoring and maybe switching a fan or (in the case of over temperature) taking some more extreme action.
                                          You can however, do as I do and stick a thermistor on the chip (or anywhere else) with a small dab of epoxy adhesive then use one of the PWM channels to control a fan. I did a bit of a write up on my blog which you can view here if you are interested https://somei3deas.wordpress.com/2017/04/18/stepper-motor-and-electronics-cooling/
                                          • cbusilloundefined
                                            cbusillo
                                            I did that on my last control board. For now I have the control box fan connected to fan 3. My start and end scripts turn it on about 30%. It works fine. It would be nice to have them bumped up if nesessary though.
                                            Great write up!
