if condition RFF3 on GPIO Pin
Thanks for your answer.
The code is indented as you show. Just a copy-paste matter.
To be more precisely again, it works most of the time.
BUT sometimes, after some moves handling to test (home ALL, grab a tool, grab an other tool, home ALL, etc) Duet says "failed to grab the tool" without any reason...
I double check switch and code implementation, everything seems OK.
But of course there is something wrong I don't understand.
Thanks !
Can you upload the actual .g file you're trying to use?
I wonder if it could be a timing issue.
Assuming the code looks like thisG0/G1 ... ; move the print head, which causes the microswitched to be pressed if .... abort "Failed to grab tool" then the if statement and the abort can get executed before the move is finished. At least that's how I understand the documentation.
If your code looks like that, try adding an M400 before the line with the if.
But even with the M400, I wonder how quickly the object models gets updated. But that's something that probably only @dc42 can answer.
Here it is :
; tpost0.g ; called after tool 0 has been selected ;heatup M116 P0 ;prime nozzle ;M98 Pprime.g ;mesh levelling on G29 S1 ;PCF fan on M106 P2 S255 G4 S1 ; PAUSE if sensors.gpIn[0].value = 0 ;if the microswitch is not pressed... abort "Failed to grab tool 0" -
if sensors.gpIn[0].value = 0 ;if the microswitch is not pressed... abort "Failed to grab tool 0" if sensors.gpIn[0].value = 0 ;if the microswitch is not pressed... abort "Failed to grab tool" It looks like you're using multiple spaces for the indent rather than a tab. Can you tell the difference?
I'm not familiar with conditional gcode enough yet to say that's the answer for sure. And the documentation doesn't mention tab versus space, but tabs would be the usual convention in coding I think. I could be totally wrong.
In fact I use spaces instead of tab.
It could be the reason ?
Thanks
@sylvain You can use tabs or spaces, but it will complain if you use both.
I think as @RS said, it could be timing.
What happens if you put M400 in before the IF statement? -
So :
I well indented with tabs.
I had M400 before if condition.Random issue is still here. I would say that with these updates, wrong fails are more important than before
Thanks
I've added this to my list to look at. I hadn't considered using the abort command in a tool change file.
To confirm, after the G1 command that parks the tool, you will need to use M400 or G4 Pxx to ensure that the movement completes before testing the switch. If the switch is connected to a Duet 3 expansion board then there may be a latency of a millisecond or so before the new switch status is available on the main board, so a G4 command to delay a few milliseconds would be advisable.
Hi
I tried :
G4 S1
M400No better results.
Best regards
Sylvain
@sylvain: am I right to assume that moving the print head towards the tool and actuating the grabber is done is tpreX.g?
If I were to debug this issue, I think I would write a gcode file that would simulate tool changes in a while loop, without activating/deactivating the tool. That would take some of the variables out of the game (e.g. the tool-switching logic in the firmware).
The gcode would look like this:
while iteration < 500; you may want to play around with this G0 ... ; move print head towards the tool ; grab the tool M400 G4 S1 ; check if microswitch was triggered and abort if not G0 ... ; move away from the tool holder G0 ... ; move back to the tool holder ; release the tool G0 ... ; move away from the tool holder Try to get this as close as possible to your current setup, then let it run for a while. If this doesn't cause aborts any more, then the error is somehow related to the tool changing configuration. If it still fails, then at least we know it's not related to tool changing.
Divide and conquer
I am looking into this, and in the first instance it's a specification issue:
If the tfree file aborts:
- Should the whole tool change be cancelled?
- What state should RRF assume the machine is in: old tool still loaded, or no tool loaded, or something else?
Similarly if the tpre or tpost file aborts.
RRF does not currently have any concept of a tool change failing.
@dc42: That's certainly useful to look into. I really like the idea of verifying a successful tool lock before moving away and potentially dropping the tool on the bed.
But as I understand it, @sylvain has more issues than an undefined state after the abort. The abort occurs because the microswitch is not recognized as pressed, even though it apparently is, and right now he has no idea why that happens.
Do you think that could also have something to do with the tool change procedure?
Of course, once that's resolved, there's still the specification issue you've mentioned.
@RS said in if condition RFF3 on GPIO Pin:
In fact, at the moment the problem is the random answer of if condition. Sometimes it works, sometimes not...
To be sure this is not a connector issue, I deleted the last connector possible, soldered the wires => same issue !
So, yes, my real problem at the moment is this randoming process.
@dc42 : I'm working on tpost, not tfree
example with tpost :
; tpost0.g ; called after tool 0 has been selected ;heatup M116 P0 ;prime nozzle ;M98 Pprime.g ;mesh levelling on G29 S1 ;PCF fan on M106 P2 S255 M400 G4 P500 if sensors.gpIn[0].value = 0 ;if the microswitch is not pressed... abort "Failed to grab tool 0" ; end if -
I also tried with if condition at the beginning without success :
; tpost0.g ; called after tool 0 has been selected M400 G4 P500 if sensors.gpIn[0].value = 0 ;if the microswitch is not pressed... abort "Failed to grab tool 0" ;heatup M116 P0 ;prime nozzle ;M98 Pprime.g ;mesh levelling on G29 S1 ;PCF fan on M106 P2 S255 Same random behaviour
Could you also post your tpre0.g file?
Here it is :
; tpre0.g ; called before tool 0 is selected ;Ensure no tool is selected ;T-1 if sensors.gpIn[0].value = 1 ;if the microswitch is pressed... abort "Tool 0 still mounted" ;Unlock Coupler M98 P/macros/Coupler - Unlock ;Move to location G1 X-10.5 Y200 F50000 ;Move in G1 X-10.5 Y230 F50000 ;Collect G1 X-10.5 Y242.5 F2500 ;Close Coupler M98 P/macros/Coupler - Lock ;WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! ;if you are using non-standard length hotends ensure the bed is lowered enough BEFORE undocking the tool! G91 G1 Z10 F1000 G90 ;Move Out G1 X-10.5 Y150 F4000 -
Hm. The whole sequence of movements, plus M400 and G4, looks good to me.
Maybe double and triple check that the microswitch is really pressed correctly every single time? Or check if the cable from the switch to the boards runs close to other cables, where it could pick up noise. No idea how sensitive it would be to noise, but checking it and trying to move it away from other cables can't hurt.
Besides that, I have no more ideas than what I've suggested earlier: try writing a gcode file that simulates the tool change without actually invoking the T command. Just grab the tool, then release it again, in a while loop, and see what happens. In my experience, having a minimal example that reproduces the issue often helps.
When it fails to detect that the tool has been picked up, if you query the switch position using an echo command or M409, does it report the correct switch state?
@dc42 I will echo just before and just after condition test
How should I write it ?
just:echo sensors.gpIn[0].value
Thanks
