    if condition RFF3 on GPIO Pin
    Gcode meta commands
    1.6k
    • duetloverundefined
      duetlover
      In fact I use spaces instead of tab.
      It could be the reason ?
      Thanks
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @duetlover
        @sylvain You can use tabs or spaces, but it will complain if you use both.
        I think as @RS said, it could be timing.
        What happens if you put M400 in before the IF statement?
          duetlover
          So :
          I well indented with tabs.
          I had M400 before if condition.
          Random issue is still here. I would say that with these updates, wrong fails are more important than before 😕
          Thanks
            I've added this to my list to look at. I hadn't considered using the abort command in a tool change file.
            To confirm, after the G1 command that parks the tool, you will need to use M400 or G4 Pxx to ensure that the movement completes before testing the switch. If the switch is connected to a Duet 3 expansion board then there may be a latency of a millisecond or so before the new switch status is available on the main board, so a G4 command to delay a few milliseconds would be advisable.
              duetlover
              Hi
              I tried :
              G4 S1
              M400
              No better results.
              Best regards
              Sylvain
              • RSundefined
                RS
                @sylvain: am I right to assume that moving the print head towards the tool and actuating the grabber is done is tpreX.g?
                If I were to debug this issue, I think I would write a gcode file that would simulate tool changes in a while loop, without activating/deactivating the tool. That would take some of the variables out of the game (e.g. the tool-switching logic in the firmware).
                The gcode would look like this:
                while iteration < 500; you may want to play around with this
                  G0 ... ; move print head towards the tool
                  ; grab the tool
                  M400
                  G4 S1
                  ; check if microswitch was triggered and abort if not
                  G0 ... ; move away from the tool holder
                  G0 ... ; move back to the tool holder
                  ; release the tool
                Try to get this as close as possible to your current setup, then let it run for a while. If this doesn't cause aborts any more, then the error is somehow related to the tool changing configuration. If it still fails, then at least we know it's not related to tool changing.
                Divide and conquer 😉
                  I am looking into this, and in the first instance it's a specification issue:
                  If the tfree file aborts:
                  • Should the whole tool change be cancelled?
                  • What state should RRF assume the machine is in: old tool still loaded, or no tool loaded, or something else?
                  Similarly if the tpre or tpost file aborts.
                  RRF does not currently have any concept of a tool change failing.
                  • RSundefined
                    RS
                    @dc42: That's certainly useful to look into. I really like the idea of verifying a successful tool lock before moving away and potentially dropping the tool on the bed.
                    But as I understand it, @sylvain has more issues than an undefined state after the abort. The abort occurs because the microswitch is not recognized as pressed, even though it apparently is, and right now he has no idea why that happens.
                    Do you think that could also have something to do with the tool change procedure?
                    Of course, once that's resolved, there's still the specification issue you've mentioned.
                    duetloverundefined 1 Reply Last reply Reply Quote 0
                      duetlover @RS
                      @RS said in if condition RFF3 on GPIO Pin:
                      In fact, at the moment the problem is the random answer of if condition. Sometimes it works, sometimes not...
                      To be sure this is not a connector issue, I deleted the last connector possible, soldered the wires => same issue !
                      So, yes, my real problem at the moment is this randoming process.
                      @dc42 : I'm working on tpost, not tfree
                      example with tpost :
                      ; tpost0.g
                      ; called after tool 0 has been selected
                      ;heatup
                      M116 P0
                      ;prime nozzle
                      ;M98 Pprime.g
                      ;mesh levelling on
                      G29 S1
                      ;PCF fan on
                      M106 P2 S255
                      M400
                      G4 P500
                      if sensors.gpIn[0].value = 0  ;if the microswitch is not pressed...
                      	abort "Failed to grab tool 0"
                      ; end if
                        duetlover
                        I also tried with if condition at the beginning without success :
                        ; tpost0.g
                        M400
                        G4 P500
                        ;heatup
                        M116 P0
                        ;prime nozzle
                        ;M98 Pprime.g
                        ;mesh levelling on
                        G29 S1
                        ;PCF fan on
                        M106 P2 S255
                        Same random behaviour 😕
                        • RSundefined
                          RS
                          Could you also post your tpre0.g file?
                            duetlover
                            Here it is :
                            ; tpre0.g
                            ; called before tool 0 is selected
                            ;Ensure no tool is selected
                            ;T-1
                            if sensors.gpIn[0].value = 1  ;if the microswitch is pressed...
                                abort "Tool 0 still mounted"
                            ;Unlock Coupler
                            M98 P/macros/Coupler - Unlock
                            ;Move to location
                            G1 X-10.5 Y200 F50000
                            ;Move in
                            G1 X-10.5 Y230 F50000
                            ;Collect
                            G1 X-10.5 Y242.5 F2500
                            ;Close Coupler
                            M98 P/macros/Coupler - Lock
                            ;WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING! WARNING!
                            ;if you are using non-standard length hotends ensure the bed is lowered enough BEFORE undocking the tool!
                            G91
                            G1 Z10 F1000
                            G90
                            ;Move Out
                            G1 X-10.5 Y150 F4000
                            • RSundefined
                              RS
                              Hm. The whole sequence of movements, plus M400 and G4, looks good to me.
                              Maybe double and triple check that the microswitch is really pressed correctly every single time? Or check if the cable from the switch to the boards runs close to other cables, where it could pick up noise. No idea how sensitive it would be to noise, but checking it and trying to move it away from other cables can't hurt.
                              Besides that, I have no more ideas than what I've suggested earlier: try writing a gcode file that simulates the tool change without actually invoking the T command. Just grab the tool, then release it again, in a while loop, and see what happens. In my experience, having a minimal example that reproduces the issue often helps.
                                When it fails to detect that the tool has been picked up, if you query the switch position using an echo command or M409, does it report the correct switch state?
                                duetloverundefined 2 Replies Last reply Reply Quote 0
                                  duetlover @dc42
                                  @dc42 I will echo just before and just after condition test
                                  How should I write it ?
                                  just:
                                  echo sensors.gpIn[0].value
                                  Thanks
                                    Yes, that should work.
                                      duetlover @dc42
                                      @dc42 So when it fails the echo command says 0. No problem here
                                      I finally change NO switch to NC one and now it seems to be OK !
                                      Thanks for your help.
                                      • jwalker55undefined
                                        jwalker55
                                        @dc42 Is it possible to read a sensor value twice within a single macro? For example, check the state of a switch at the beginning of tpre, then again at the end after the move out? When I do this (just by echoing to console) it outputs the state the switch was in when the macro started (or whenever the sensor was first read in the macro) for both instances despite the switch being pressed at the beginning and unpressed at the end. Aside from that it seems to work as expected if i'm only reading the sensor once.
                                        A Former User? jwalker55undefined 2 Replies Last reply Reply Quote 0
                                          A Former User @jwalker55
                                          @jwalker55 maybe post your actual files in a new topic? sounds like it should work if the testing is done in the same file as the move is made.
                                            jwalker55 @jwalker55
                                            Adding a short (10ms) pause using G4 prior to the second sensor reading seemed to fix it.
