Duet 2 wifi not homing and other issues
Describe how you measured the trigger height.
Post your config.g and homing files. -
Well i did these steps that are in the dozuki for duet3d about 4 times the readings where only off by .003 so i figured lets choose the middle one and go with it. And with the babystepping set to how i said 1.25 i was able to get a print off for my bltouch mount. Which you would think id be excited since i dont have to worry about a ziptie holding the bltouch on. Guess again lol once i switched to the new mount some how its changed the entire bed. i truly dont understand it.
Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
Jog the head up by 5 to 10mm
Send command G30 S-1. The nozzle will descend or the bed rise until the probe triggers and the Z height at which the probe stopped will be reported. If you are using a nozzle-contact Z probe, the trigger height will be slightly negative. For any other type of Z probe where the probe triggers before the nozzle contacts the bed, it will be positive.
Repeat from step 5 two or three times to make sure that the trigger height is consistent.; Configuration file for Duet WiFi (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v3.1.1 on Wed Jun 03 2020 20:30:38 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"Tronxy X5sa Pro" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M350 X16 Y16 Z16 E16 I0 ; configure microstepping without interpolation
M92 X80.00 Y80.00 Z400.00 E436.5 ; set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M906 X950 Y950 Z950 E1260 I10 ; set motor currents (mA) and motor idle factor in per cent
M84 S5 ; Set idle timeout; Axis Limits
M208 X330 Y330 Z375 S0 ; set axis maxima; Endstops
M574 X1 Y1 S0 ; set active low and disabled endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-32.8 Y0 Z1.722 ; set Z probe trigger value, offset and trigger height
M557 X25:275 Y25:275 S50 ; define mesh grid
M307 H3 A-1 C-1 D-1; Heaters
M143 H0 S80 ; set temperature limit for heater 0 to 80C
M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-335 ; home X axis
G1 H1 Y-335 ; home Y axis
G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-335 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X63 Y35 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; homex.g
; called to home the X axis
G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 H1 Y-335 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 H1 Y-335 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 X63 Y35 F6000 ; go to first probe point
;G90 ; absolute positioning -
That is my bed after the mount was attached with all of the screws turned up to about 2 threads each screw. to be honest im getting one heck of a laugh but its also frustrating.
Keep in mind the visualization is exaggerated. The actual tilt is only 1.2mmish.
I'll have to take a closer look a little later. -
ok let me know if you want any more files.
Ok i can say this for real. The mesh compensation doesnt work worth a darn. If it did the tip would be the perfect distance from the bed to get the perfect first layer not jam the nozzle. And cause the filament to not flow.
Ok how the heck does the bed switch from front being high to the side being high? in just one restart at that.
What does your mount look like?
Did you remeasure the XY offset after changing the mount?G1 X63 Y35 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bedChange the X Y position to move the probe to the center of the bed.
Have you manually leveled the bed to confirm the bed is touching the nozzle at all the leveling screw points?
its a tronxy x5sa pro its got a flat bar with the lead screw and two smooth rods running through it on each side and square stock running to each flat bar on both sides of the hotbed. Yes i have leveled the bed and made sure its touching at all points. So far i have gotten it to print its on layer 10 with your help 99% of the way lol the last 1% is from a random youtube post that talked about m500 to save everything which none of the documents talk about. thankfully when i found the m500 i setup everything saved with it and then reset the board and checked and m500 again just to make sure and it worked like a charm.
i think im gonna have to do a pully setup at the motors to fix any bed floppyness. But so far the semi fix is to not save power and to just let the motors have full power all the time.
The mount i got luckily kept the nozzle in the exact some spot and the probe is in the exact same spot as the original one aswell so woohoo gotta love luck.
M500 works a bit differently in Reprap than on an 8bit controller.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M500_Store_parameters
Only a very specific range of things will be saved by M500. It's mainly used for saving delta calibration, PID tuning, and maybe some offsets.
I wouldnt know, this is my first 3d printer. I knew it didnt have any thermal runaway so i bought this board on the reccomendation of reviewers. But from what i have seen sofar is the software support for it sucks. The configurator doesnt even have a decent library of printers it only has a handful. If anything duet needs to get their act together on the library and start putting more in. And not rely on strangers to hopefully give them all of the info they need. This board and the configurator is still in alpha stage. Im gonna switch to a marlin based board since its has way more printers already in the database which also includes mine.
Sorry you feel that way. Good luck with the Marlin board.
