SD card not recognized
It's not showing up. The USB light illuminates on the duet, but the device is not showing up in the control panel. have tried two different, known to be working USB cables.
I also can't get into the Amtel site to download their software. They have no problem subscribing me to their lists (I've tried two different e-mail addresses), but I never get the "verification" e-mail…...
I've temporarily put a copy of sam-ba 2.16 for Windows at https://dl.dropboxusercontent.com/u/19369680/sam-ba_2.16_windows.exe.
When you first start it you need to select the correct board and not the default you have there it should be at91sam4e8-ek instead of the at91cap9-dk_mem18
Yeah… the board isn't being recognized by windows. Do I have any options here other than getting another board? Tried three cables now, on two different computers, and even though the LED on the duet lights up, neither computer "sees" the duet wifi board. I have a V.8.5 board here and the computers see that just fine.
Have you pressed the Erase and Reset buttons on the board?
If yes, have you tried another USB cable?
Reset and erase both pressed several times and both held for 20+ seconds. Several cables tried, two of which were the brand new ones that came with the Duet and the Duet wifi. I think I'm fuxored.
Well, I finally had the time to figure it out.
The problem was with the endstop switches. I unplugged everything and the duet wifi board was recognized by the computer. I then started plugging components in, one at a time and rebooting, until it had a problem.
Stupid error on my part. I was switching over from a Duet .8.5 to the wifi and I assumed the plugs were oriented the same. Apparently the endstop switches are reversed.
Sorry to waste your time with this. Live and learn how to read, I guess.
Thanks for letting us know. I guess you must be using 3-wire endstop switches and an un-polarised connector.
Yeah, I'm using this one on a FolgerTech Kossel 2020 kit at my house. I've set up three other Duet's at work with no issues, but they weren't the wifi ones.
