    Replaced heatbrake and nozzle, now Z offset does not work.
    • wickedracerundefined
      wickedracer
      Cleaned my E3D V6 Hotend and replaced the nozzle, probably changing the overall length, but not by much and now when I go to use the Move Z on the PanelDue (to change the Z offset, closer to the bed), it doesn't change anything. what did I do that could've caused this? Any help would be great!
      • aidarundefined
        aidar
        Probably your new nozzle is higher if you want to move it closer to bed. But you didnt probably change Z minimum, thats why it does not go lower.
          If you're using a probe, you must redo this calibration.
          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
          If you're using an endstop, you may need to change your homeall if you use G92 Z to set the z height.
