    How to connect laser fire pin of K40 CO2 laser to Duet board.
    Laser Cutters
    1.3k
      jay_s_uk
      any chance you could post your config?
      j.dewitundefined 1 Reply Last reply Reply Quote 0
      • j.dewitundefined
        j.dewit @jay_s_uk
        @jay_s_uk Sorry for the late reply, my notifications were turned off.
        I will try to post the config tonight.
        Some update on the project, I now have added an controllable Air assist using a Relay. That is controlled via gcode commands. And I have added a motorized Z-table.
        Both were easy to configure in the Duet, and work great.
        I do have a fully working k40 now, with the option to control the laser intensity from software. Gcode generated from LaserWeb is working perfect. I then upload these to the Duet, and that seems the way to go.
        I haven't had any luck on getting the gcode from the Lightburn software to work to an acceptable level. The generated gcode does work, but whenever I use a fill, the results are bad. Jagged edges and wobbly lines.
        I will need to find some time, to post some example pictures and the used gcode. Since I haven't found out what exactly is going wrong with the gcode from LightBurn.
        • j.dewitundefined
          j.dewit
          I have added my config file: (Comments may be a mess....)
          G90 						; send absolute coordinates…
          M83 						; …but relative extruder moves
          M550 P"MPCNC" 					; Machine name and Netbios name (can be anything you like)
          G21						; Work in millimetres
          M555 P2						; Set output to look like Marlin
          ; Communication and general
          M111 S0                            		; Debug off
          M551 Preprap                   			; Machine password (used for FTP)
          ;*** Networking
          M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED		; MAC Address
          M552 P192.168.0.50				; IP address
          M554 P192.168.0.255				; Gateway
          M553 P255.255.255.0				; Netmask
          M552 S1						; Turn network on
          ; Pin for air assist via relay
          M950 P0 C"fan0"
          M569 P0 S0					; Drive 0 goes backwards
          M569 P1 S1					; Drive 1 goes forwards
          M569 P2 S1					; Drive 2 goes forwards
          M569 P3 S1					; Drive 3 goes forwards
          M569 P4 S1					; Drive 4 goes backwards
          ; Drive mapping
          M584 X0 Y1 Z2 E P3			        ; Drive mapping
          ; Drive settings
          M350 X16 Y16 Z16 E16 I1	         		; Configure microstepping with interpolation
          M92 X157.575 Y157.575 Z3232.57		        ; Set steps per mm
          ;M350 X32 Y502 E128 I1				; Set steps per mm for the extruder to x128 (776 steps per mm) and X and Y to x32 (160 steps per mm)
          M566 X800 Y800 Z60 E3000 P1		        ; Set maximum instantaneous speed changes (mm/min)
          M203 X16000 Y16000 Z40		                ; Set maximum speeds (mm/min)
          M201 X2500 Y2500 Z80		                ; Set accelerations (mm/s^2)
          M204 P600 T2000					; Set accelerations (mm/s^2) for print and travel moves
          M906 X400 Y600 Z600 I30		                ; Set motor currents (mA) and motor idle factor in per cent
          M84 S0						; Set idle timeout
          M208 X0 Y-30 Z-13.6 U0 V0 S1	                ; Set axis minima
          M208 X300 Y200 Z70 S0		        	; Set axis maxima
          M574 X1 S1 P"xstop"  ; X min active high endstop switch
          M574 Y2 S1 P"ystop"   ; Y max active high endstop switch
          M574 Z1 S1 P"!zstop"  ; Z min active high endstop switch
          ; Allow movement before homing
          ;M564 S0 H0
          ; Laser Mode
          M452 C"e0heat" R1.0 S1 Q200                          ; laser uses !e0heat pin,  PWM frequency 100Hz
            jay_s_uk
            thanks @j-dewit
            I ran my K40 with a duet for about 2 hours and gave up as I couldn't get any good engraving out of it.
            The firing of the laser didn't want to keep up with the movement of the machine so just looked awful.
            I might revisit it at some point, but getting even something remotely useful out of lightburn was difficult
            • j.dewitundefined
              j.dewit @jay_s_uk
              @jay_s_uk Seem to be having the same results here, but the gcode from laserweb is working absolutely perfect.
              I have done some g-code comparisation:
              LaserWeb:
              ; Pass 0 Path 1
              G0 X40.18 Y4.49
              G1 X39.07 Y4.49 S0.40 F10000
              ; Pass 0 Path 2
              G0 X39.07 Y4.59
              G1 X40.18 Y4.59 S0.40 F10000
              LightBurn:
              G1X13.92F10000S0.4
              G1Y0.1S0
              G1X-13.92S0.4
              G1Y0.1S0
              So far the only difference I see is the G0 moves in laserweb, when the laser is off by default. And in lightburn it is using a G1 with laser power to 0.
              And the difference in absolute and relative movements. But why the duet is having problems with the lightburn gcode is a mystery to me.
                jay_s_uk
                I'll look at using laserweb as an option then.
                I used to use it before I got lightburn and changed as I just never got on with it.
                I'll add this bad on my jobs list to look at.
                is the engraving working well using laserweb then?
                • j.dewitundefined
                  j.dewit @jay_s_uk
                  @jay_s_uk I have not tried images etc.
                  But filling vectors works well.
                  LaserWeb is a good piece of software, but it being totally free. It just can't be compared to lightburn as this is a far superior piece of software.
                    jay_s_uk @j.dewit
                    @j-dewit
                    ok, thanks.
                    Its more vector engraving I do so I'll look into it.
                    • j.dewitundefined
                      j.dewit @jay_s_uk
                      @jay_s_uk And I am planning to spend some more time testing why the g-code from Lightburn is a mess, I have ordered a cheap MKS S-base board since it should be compatible with lightburn, but I would rather keep using the Duet, since everything on the s-base is a big downgrade compared to the duet.
                        jay_s_uk @j.dewit
                        @j-dewit
                        I currently run mine with the SBase (running grbl-lpc https://github.com/cprezzi/grbl-LPC) and the performance is spot on.
                        It may be down to grbl having next to no features compared to RRF.
                        I'd just prefer to have wireless support so I can run my machine without being tethered to USB. And I'm a fan of the duet ecosystem.
                        The lightburn gcode could also do with way better structure. I think the outputted file is quite messy
