Trying to figure out what is giving the Bad Command error
Duet Web Control
2.2k
    deckingman @Dragon
    @Dragon
    M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
    The wiki for M204 in RRF does not have an "R" parameter. https://duet3d.dozuki.com/Wiki/Gcode#Section_M204_Set_printing_and_travel_accelerations
      Dragon
      Thanks, I have already taken those 4 lines out but still get the error.
      Cheers.
        A Former User
        i thought it printed the line that had the bad command, maybe just to usb?
        anyways, i see a line with just whitespace below M109, so thats what made me think it may print the problem, its just not something we can see?
          Dragon
          I will try removing that Thanks!
          Cheers.
            Dragon
            Ugh, that didn't get rid of it. LOL
              What firmware version are you using? Most firmware versions usually report what the bad command was.
                Can you post your homeall.g as well? Perhaps your bad command is in there.
                  Dragon
                  Firmware 2.05.1
                  Here is the code from Cura a bit more of it in case that helps:
                  ;FLAVOR:RepRap
                  ;TIME:1841
                  ;Filament used: 1.10598m
                  ;Layer height: 0.2
                  ;MINX:96.5
                  ;MINY:96.5
                  ;MINZ:0.2
                  ;MAXX:138.5
                  ;MAXY:138.5
                  ;MAXZ:20.2
                  ;POSTPROCESSED
                  ;LINEARADVANCEPROCESSED
                  ;Generated with Cura_SteamEngine 4.6.1
                  T0
                  M83 ;absolute extrusion mode
                  ;M201 X500.00 Y500.00 Z140.00 E5000.00 ;Setup machine max acceleration
                  ;M203 X9000.00 Y9000.00 Z6000.00 E6000.00 ;Setup machine max feedrate
                  ;M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
                  ;M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                  M220 S100 ;Reset Feedrate
                  M221 S100 ;Reset Flowrate
                  G28 ;Home
                  M140 S65 ; start preheating the bed
                  M104 S215 T0 ; start preheating hotend
                  G28 ; home
                  G32
                  M190 S65 ; heat to Cura Bed setting
                  M109 S215 T0 ; heat to Cura Hotend
                  G32 E0 ;Reset Extruder
                  G1 Z2.0 F3000 ;Move Z Axis up
                  G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                  G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                  G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                  G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                  M83 ;relative extrusion mode
                  G1 F2700 E-5
                  ;LAYER_COUNT:100
                  M572 S0.000000 D0 ;added by LinearAdvanceSettingPlugin
                  ;LAYER:0
                  M107
                  G1 F300 Z0.4
                  G0 F6000 X127.637 Y97.311 Z0.4
                  ;TYPE:SKIRT
                  G1 F300 Z0.2
                  G1 F2700 E5
                  G1 F1200 X128.539 Y97.364 E0.03005
                  G1 X129.432 Y97.496 E0.03002
                  G1 X130.31 Y97.707 E0.03003
                  G1 X131.166 Y97.995 E0.03004
                  G1 X131.993 Y98.357 E0.03003
                  G1 X132.785 Y98.792 E0.03005
                  G1 X133.536 Y99.294 E0.03004
                  And the home all:
                  ; homeall.g
                  ; called to home all axes
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue May 26 2020 00:51:15 GMT-0700 (Pacific Daylight Time)
                  G91 ; relative positioning
                  G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H2 X5 Y5 F6000 ; go back a few mm
                  G1 H1 X-240 Y-240 F360 ; move slowly to X and Y axis endstops once more (second pass)
                  G90 ; absolute positioning
                  G1 X117 Y117 F6000 ; go to first bed probe point and home Z
                  G29 S1
                  ;G91 ; relative positioning
                  ;G90 ; absolute positioning
                  But this only happens with files from Cura.
                    @Dragon said in Trying to figure out what is giving the Bad Command error:
                    That looks wrong. I presume it should be: G92 E0
                    Edit: @Phaedrux already pointed that out.
                    Can you post your bed.g file too?
                      Dragon
                      Thanks, will try that change now.
                        Dragon
                        Nope that wasn't it 😞
                          Dragon
                          Here is the end Gcode if it could be there:
                          G0 F9000 X114.795 Y108.649
                          G1 F1500 X111.208 Y112.237 E0.16875
                          G1 X110.926 Y112.519
                          ;TIME_ELAPSED:1841.048257
                          G1 F2700 E-5
                          M140 S0
                          M107
                          G91 ;Relative positionning
                          G1 E-2 F2700 ;Retract a bit
                          G1 E-2 Z0.2 F2400 ;Retract and raise Z
                          G1 X5 Y5 F3000 ;Wipe out
                          G1 Z10 ;Raise Z more
                          G90 ;Absolute positionning
                          G1 X0 Y235 ;Present print
                          M106 S0 ;Turn-off fan
                          M104 S0 ;Turn-off hotend
                          M140 S0 ;Turn-off bed
                          M84 X Y E ;Disable all steppers but Z
                          M104 S0
                          ;End of Gcode
                          ;SETTING_3 {"global_quality": "[general]\nversion = 4\nname = Standard Quality
                          ;SETTING_3 #3\ndefinition = creality_ender3\n\n[metadata]\nquality_type = s
                          ;SETTING_3 tandard\ntype = quality_changes\n\n[values]\nadhesion_type = skir
                          ;SETTING_3 t\nmaterial_bed_temperature = 65\n\n", "extruder_quality": ["[gene
                          ;SETTING_3 ral]\nversion = 4\nname = Standard Quality #3\ndefinition = creali
                          ;SETTING_3 ty_ender3\n\n[metadata]\nquality_type = standard\nposition = 0\n
                          ;SETTING_3 type = quality_changes\n\n[values]\ninfill_overlap = 10.0\ninfill
                          ;SETTING_3 _pattern = gyroid\ninfill_sparse_density = 10\ninfill_wipe_dist = 0
                          ;SETTING_3 .4\nmaterial_flow = 100\nmaterial_flow_layer_0 = 100\nmaterial_pri
                          ;SETTING_3 nt_temperature = 215\nretraction_hop_enabled = True\nretraction_hop
                          ;SETTING_3 _only_when_collides = True\nskirt_gap = 10\nspeed_wall_0 = 30.0\ns
                          ;SETTING_3 peed_wall_x = 30.0\ntop_bottom_thickness = =layer_height_0+layer_hei
                          ;SETTING_3 ght*3\nwall_0_material_flow = 100\n\n"]}
                            Can you upload the file itself so we could check it in a text editor?
                            Another thing you can try is to send each command copy and pasted from the file in the gcode console and see if any give an error.
                            M572 S0.000000
                            Maybe try fewer zeroes?
                            undefined 1 Reply Last reply 27 Jun 2020, 18:30 Reply Quote 0
                              Dragon
                              Here:
                              30min Benchy.gcode
                              It doesn't seem to cause any problems other than driving me nuts not knowing what's causing it.
                              undefined 1 Reply Last reply 27 Jun 2020, 21:15 Reply Quote 0
                                Dragon
                                Bed file:
                                ; bed.g
                                ;M561 ; clear any bed transform
                                G30 X20 Y20
                                G29 S1 ; probe the bed and enable compensation
                                ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                                ; 16 points, 6 factors, probing radius: 115, probe offset (-42, -12)
                                ;M98 Pdeployprobe.g
                                ;G30 P0 X0.00 Y115.00 Z-99999 H0
                                ;G30 P1 X57.50 Y99.59 Z-99999 H0
                                ;G30 P2 X99.59 Y57.50 Z-99999 H0
                                ;G30 P3 X115.00 Y0.00 Z-99999 H0
                                ;G30 P4 X99.59 Y-57.50 Z-99999 H0
                                ;G30 P5 X57.50 Y-99.59 Z-99999 H0
                                ;G30 P6 X0.00 Y-98.87 Z-99999 H0
                                ;G30 P7 X-44.23 Y-76.60 Z-99999 H0
                                ;G30 P8 X-72.61 Y-41.92 Z-99999 H0
                                ;G30 P9 X-83.99 Y-0.00 Z-99999 H0
                                ;G30 P10 X-77.01 Y44.46 Z-99999 H0
                                ;G30 P11 X-49.88 Y86.40 Z-99999 H0
                                ;G30 P12 X0.00 Y53.39 Z-99999 H0
                                ;G30 P13 X49.80 Y-28.75 Z-99999 H0
                                ;G30 P14 X-28.51 Y-16.46 Z-99999 H0
                                ;G30 P15 X0 Y0 Z-99999 S6
                                ;M98 Pretractprobe.g
                                Again this only happens with files from Cura files from Prusa Slicer don't give the error.
                                  Dragon @Phaedrux
                                  @Phaedrux said in Trying to figure out what is giving the Bad Command error:
                                  M572 S0.000000
                                  I have tried commenting that line out and it did not fix the error.
                                    Upload the homeall. and bed.g as well.
                                      I don't think M104 takes a T parameter, but I don't think it would complain about it...
                                      undefined 1 Reply Last reply 27 Jun 2020, 20:54 Reply Quote 0
                                        Dragon
                                        Bed is above here is home:
                                        ; homeall.g
                                        G29 S1
                                          I meant the actual file so we can check for bogus characters.
                                          23 out of 40
